POV-Ray : Newsgroups : povray.binaries.images : Sven's SL Heli Chopper 02 Server Time
14 Apr 2026 14:16:41 EDT (-0400)
  Sven's SL Heli Chopper 02 (Message 11 to 15 of 15)
Subject: Re: Sven's SL Heli Chopper 02
Date: 31 Jan 2008 00:35:26
Message: <47a15e1e$1@news.povray.org>
Hey - that's interesting! Your colors look better than the colors in my
image! I wonder, why.
What version of POV-Ray do you use, Nicolas?
Sven
"Nicolas Alvarez" <nic### [at] gmailisthebestcom> schrieb im
Newsbeitrag news:47a111e5@news.povray.org...
> Description from the scene file:
>> About: My persistence of the vision of a small ultra-light helicoper,
>> featuring a small engine and made of fiber glass (the case) and plexi
>> glass (for the canopy). Note the two conter-rotating rotors beside
>> each other.  This helicopter could carry, as concepted with this
>> file, one adult normally and probably another one in some cases, or
>> some light freight beside the pilot.
> Full credits go to Sven Littkowski, all I did was the 50-hour render :)
Date: 31 Jan 2008 01:51:43
Message: <47a16fff$1@news.povray.org>
Nicolas Alvarez wrote:
> This heavy usage indeed lowers CPU life, but not enough to be an issue,
Significantly more of an issue is the extra amount of electricity you
chew through doing this.
William Tracy
You know you've been raytracing too long when you get lots of "undefined
or invalid # directive"-errors when programming in C++.
    -- Warp
(...I have discovered that Warp is quite correct about this.)
Date: 31 Jan 2008 11:33:01
Message: <47a1f83d@news.povray.org>
> oh!  there are photons?!  *scrutinizes image*
> yes, there seems there are photons after all:  they seem to show up in the
> ground just below the shiny reflective chopper fronts.  But problem is:  from
> the point-of-view chosen, it's hardly visible.  Luckly, the photon map is
> saved, and getting a close-up shot of the effect should be much easier.  It
> seems the only reason for the insane photon map build time is the high number
> of reflective geometries there.
Remember the statistics I posted before: the number of photons finally
stored was quite low, 0.1% of the photons shot.
Date: 31 Jan 2008 11:37:41
Message: <47a1f955$1@news.povray.org>
3.6.1a
Note I disabled radiosity, that could be related... :)
Date: 31 Jan 2008 23:15:33
Message: <47a29ce5$4@news.povray.org>
Yes, that might be it. I use the same version. Hmm, it looks better without
radiosity.
I made a list of TO-DOs:
- Render again but without radiosity
- remove the interior to get a better canopy glass
- correct the rotor blade joints on the right rotors
The positive side effect with the first two points in that list is, that
they will speed up the render time.
I would like to invite you all, to get my scene file and do your own
textures on my little helichopper baby. Also, the entire chopper is a
macro - you can animate it (doors, rotors, rotor angle)! Would you like? If
I get a positive feedback, I will release my source code to the publicity
(after the neccessary corrections are done). So: WHO WOULD LIEK TO GET THE
HELICHOPPER SOURCECODE?
Sven
Newsbeitrag news:47a1f955$1@news.povray.org...
> 3.6.1a
