POV-Ray : Newsgroups : povray.binaries.images : Sand Server Time
16 Sep 2025 04:37:27 EDT (-0400)
  Sand (Message 15 to 24 of 24)
Subject: Re: Sand
Date: 23 Nov 2007 13:29:52
Message: <47471c20@news.povray.org>
Hash: SHA1
Incidentally, I bet snow would look fantastic with heavy SSS.
Hmm, something else to try. ;-)
William Tracy
You know you've been raytracing too long when you've ever thought or
said out-loud, "I'll bet I can raytrace that!"
    -- Neil Clark
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFHRxwhKrVIcTMekC8RAllAAJ99JI6cDtK0fBTwKR/opQa1B+i5KACfcMJs
Q++218oF9kVmNHpZ3LYDVdU=
=m/AX
-----END PGP SIGNATURE-----
Subject: Re: Sand
Date: 23 Nov 2007 15:15:01
Message: <web.474733ebee83a16cc150d4c10@news.povray.org>
William Tracy <wtr### [at] calpolyedu> wrote:
> Trevor G Quayle wrote:
> > -maybe try different normal types: instead of granite or bumps,
> Take a peek at the code I posted farther up in the thread. Normals
> aren't really helpful here, because the surface is transparent. :-(
> Early on I tried normals on the solid surface *below* the SSS, but that
> made the patterns only visible on the dark side of the sand dunes, which
> is why my first screenshots were all backlit. :-)
Ah right, I see what you mean.  Forgot about the SSS.  Still, maybe try to use
the crackle or cell pattern for your density instead.
-tgq
Subject: Re: Sand
Date: 23 Nov 2007 15:25:00
Message: <web.474736c6ee83a16cc150d4c10@news.povray.org>
Some further thoughts on this.
Maybe you can still use normals, but try adding fresnel (or variable)
reflection.
Have a look at this photo: http://www.benzor.com/misc/desert.jpg
Part of the colouring and look of the sand appears to come from actual specular
reflection.
-tgq
Subject: Re: Sand
Date: 24 Nov 2007 04:16:25
Message: <4747ebe9$1@news.povray.org>
"Trevor G Quayle" <Tin### [at] hotmailcom> schreef in bericht
news:web.47470378ee83a16cc150d4c10@news.povray.org...
> Looking pretty good.  Sand can be a difficult thing to simulate.  God idea
> trying some SSS with it.
> A few things you can try too.
> -as stated before, maybe don't use a uniform colour, but have a patterned
> varition as real sand tends to be
> -maybe try different normal types: instead of granite or bumps, you may
> get
> better result using either a solid crackle, or cells pattern.  This will
> give
> you flat surfaces with varying normals, and sharp transitions betwen
> rather
> than the continuous transitions of other types.  You can also colour (or
> texture) map in cordination with the pattern used.  You may need good AA
> though
> to get nice results.
> keep up the good work.
With the example William provided above, the cells pattern gives an
excellent result!
Subject: Re: Sand
Date: 24 Nov 2007 04:19:33
Message: <4747eca5@news.povray.org>
"Thomas de Groot" <t.d### [at] internlDOTnet> schreef in bericht
news:4747ebe9$1@news.povray.org...
> excellent result!
I forgot to say that I changed the scale to 0.0005 too, but that may vary
with the scene involved.
Good work William!
Subject: Re: Sand
Date: 24 Nov 2007 20:03:37
Message: <4748c9e9$1@news.povray.org>
Hash: SHA1
Thomas de Groot wrote:
> Another possibility, I guess, would be to use the boxed or the cylindrical
> patterns. Maybe cylindrical would be better than spherical in a landscape?
> What do you think?
I just finished picking apart the code for "Picnic at Giza":
http://www.irtc.org/ftp/pub/stills/2004-08-31/em_giza.jpg
emkaah uses the following heightfield for the sand:
#declare PF0 = pigment{
  bumps
  turbulence 0.1
  color_map { [0 rgb .12] [1 rgb .1] } scale <1,.9,1>*0.1 translate x*-5
#declare PF1 = pigment{
  crackle
  form<.86,0,0>
  turbulence 0.4
  color_map { [0 rgb .105] [1 rgb .08] }
  scale <1,.8,10>*0.1
  translate <-2,-1,0>
#declare PF2 = pigment{
  bumps
  color_map { [0 rgb .11] [1 rgb .072] }
  scale .2
  translate x*-1
#declare PF=function {
  pigment{
    gradient z
    pigment_map{
      [0 PF0]
      [.40 PF0]
      [.50 PF1]
      [.60 PF2]
      [1 PF2]
    turbulence .3
#declare sandh1 = height_field{function 600,600 {PF(x,0,y).grey} /* lots
of extraneous parameters removed */ }
So, there's a gradient used as a pattern map, with PF0 being the pattern
in the foreground, PF1 in the midground, and PF2 in the distance.
There's some turbulence to keep the transitions from being too sharp.
PF2 is the pattern for the slope up just before the base of the
pyramids. It's a crackle pattern; that's how he got those neat little
valleys running down the slope.
I also want to fiddle with the source for "Mirage", from the same IRTC
round:
http://www.irtc.org/ftp/pub/stills/2004-08-31/mirage.jpg
What struck me about that image is that there's no doubt that the sand
in the image is *sand*. That's more than you can say for a lot of the
entries in that round. :-P
It's very stylized, but still instantly recognizable as sand.
William Tracy
> >  - Type 0 are tesselated dynamically during render time and the
> > tesselation results are discarded immediately once the intersections
> > are found. In particular, I noticed that POV accessed the u_order
> > and v_order variables and repetitively called the DeCasteljau
> > subdivision functions during intersection computations...
I see.
    -- Warp
iD8DBQFHSMnpKrVIcTMekC8RAmNKAJ4y7D43pY6etFSEndPRYTS9MrEo2ACgmukT
pmx/BoFOt404ZlgNF7qw8tI=
=N5xF
Subject: Re: Sand
Date: 24 Nov 2007 20:09:46
Message: <4748cb5a$1@news.povray.org>
Hash: SHA1
> Good work William!
Well thank-you. :-)
I've started playing with phong highlighting on the upper surface
coupled with noisy normals, though I don't really have anything to show yet.
It seems to me that phong or specular highlights are going to be much
more helpful than reflections.
William Tracy
You know you've been raytracing too long when you have archived more
than thousand rendered frames of an animation onto a CD to avoid ever
having to re-render.
    -- Aaron Gage a.k.a Slartibartfast
iD8DBQFHSMtZKrVIcTMekC8RAvQHAJ9/UERSKvZAoGIR+Iifvkb9I+TxMwCgre85
wqrWlaOhCmJD4d8XhOKELDY=
=nVtM
Subject: Re: Sand
Date: 26 Nov 2007 02:40:00
Message: <web.474a77e7ee83a16ce8ba46670@news.povray.org>
> "Bruno Cabasson" <bru### [at] alcatelaleniaspacefr> schreef in bericht
> news:web.4746b46aee83a16ce8ba46670@news.povray.org...
> > I used a kind of 'fadeaway' technique for my snow texture for TerraPOV,
> > and I
> > posted recently and test render here. It is based on the distance wrt
> > camera
> > (use of spherical pattern): when near it is one texture, when far it tends
> > to
> > be a plain color (or whatever else). I intend to integrate fadeaway
> > texturing
> > macros like this in TerraPOV, because terrain pigments become plain colors
> > with
> > distance. Something like this can be applied to sand (same problem). It
> > can also
> > be used for other purposes, of course.
> What do you think?
> Thomas
Spherical and cylindrical patterns are equivalent when the camera is near the
ground. But if the camera is positionned high, only spherical is correct to
make things depend on distance.
    Bruno
Subject: Re: Sand
Date: 26 Nov 2007 03:03:21
Message: <474a7dc9@news.povray.org>
news:web.474a77e7ee83a16ce8ba46670@news.povray.org...
>> cylindrical
>> landscape?
>> What do you think?
>> Thomas
> the
> to
>    Bruno
Yes, that makes sense indeed. Thanks Bruno.
Subject: Re: Sand
Date: 26 Nov 2007 11:45:43
Message: <474af837$1@news.povray.org>
that looks pretty darn good.
