POV-Ray : Newsgroups : povray.binaries.images : Sand Server Time
8 May 2026 23:12:13 EDT (-0400)
  Sand (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Sand
Date: 23 Nov 2007 11:50:00
Message: <web.47470378ee83a16cc150d4c10@news.povray.org>
Looking pretty good.  Sand can be a difficult thing to simulate.  God idea
trying some SSS with it.
A few things you can try too.
-as stated before, maybe don't use a uniform colour, but have a patterned
varition as real sand tends to be
-maybe try different normal types: instead of granite or bumps, you may get
better result using either a solid crackle, or cells pattern.  This will give
you flat surfaces with varying normals, and sharp transitions betwen rather
than the continuous transitions of other types.  You can also colour (or
texture) map in cordination with the pattern used.  You may need good AA though
to get nice results.
keep up the good work.
-tgq
Subject: Re: Sand
Date: 23 Nov 2007 13:13:41
Message: <47471855$1@news.povray.org>
Hash: SHA1
I've been looking at this scene:
http://www.irtc.org/ftp/pub/stills/2004-08-31/em_giza.jpg
My sand texture is already better than that ;-) but I need to look into
how the sloping sand shapes at the base of the pyramids was done. My
geometry is still pretty hacked-together.
Bruno Cabasson wrote:
> I was busy in RL those two last weeks and could not read much here. William,
> your work seems very interesting. Would you mind, when achieved or partial,
> sharing things so that I can integrate this nice stuff in TerraPOV?
Cool, is it that good? :-)
Anyway, for anyone who wants to play around, here's I have so far, minus
the heightfield. As others have pointed out, there's a bunch of ways to
improve this. :-)
You'll probably want to tweak the colors and the media (right now I have
it set up for red sand), and you'll probably have to play with scaling
the bozo map (the extra special sand grains) to fit your scene.
Finally, a heads-up that terrain with SSS can take a while to render.
:-) On a ~2GHz processor, the little bitty images I've been rendering
take about 30 seconds.
#declare sand_shape = height_field {
object {
	sand_shape
                pigment {color rgb <0.75, 0.25, 0.25>}
object {
        sand_shape
        hollow
        translate y * 0.1
                        bozo
                        color_map {
                                [0 color rgb <0.3, 0.3, 0.2>]
                                [0.25 color rgbt <0.9, 0.9, 0.6, 1.0>]
                                [0.75 color rgbt <0.9, 0.9, 0.6, 1.0>]
                                [1 color rgb <1.8, 1.8, 1.2>]
                        scale 0.005
                finish {crand 0.03}
        interior {
                media {scattering {1 color rgb <0.15, 0.15, 0.05>}
samples 10, 10}
William Tracy
You know you've been raytracing too long when you can remember the 4
digit decimal equivelents to measurements down to 1 sixtyfourth of an inch.
    -- David Kraics
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFHRxhWKrVIcTMekC8RAl2BAKDI/VhfpNpv2DOi3Zp5LX2R69ntSgCfSYDJ
1xJg21JBoGTZ2DyhxxEXcus=
=gAL4
-----END PGP SIGNATURE-----
Subject: Re: Sand
Date: 23 Nov 2007 13:22:04
Message: <47471a4c$1@news.povray.org>
Hash: SHA1
Thomas de Groot wrote:
> Another possibility, I guess, would be to use the boxed or the cylindrical
> patterns. Maybe cylindrical would be better than spherical in a landscape?
> What do you think?
The last time I was working on my "Alien Desert" image (which will
eventually use my improved sand...), I used a boxed pattern as
described. I had a bozo pattern for sand grains in the foreground, and
solid in the background.
The transition between the two was far enough away where you couldn't
even tell the difference between the two textures, so I don't know how
useful it would be for creating smooth transitions.
But it did make a big improvement in my render times. :-) Having bozo
all over a virtually limitless heightfield is slow. (I can't wait to see
how much slower SSS is!)
William Tracy
You know you've been raytracing too long when you downloaded and printed
the Renderman Interface documentation, so you'd have a little light
reading to take on holiday.
    -- Alex McLeod a.k.a. Giant Robot Messiah
[Come to think of it, yours truly has done that before with the Java
documentation...]
iD8DBQFHRxpNKrVIcTMekC8RAtRMAKCU3txMhEy6i88BABydEekxzxAUCQCg0KAJ
rTLvkiK8BORgDqyJ3FkunXI=
=k0XJ
Subject: Re: Sand
Date: 23 Nov 2007 13:27:40
Message: <47471b9c$1@news.povray.org>
Hash: SHA1
Very good idea.
Take a peek at the code I posted farther up in the thread. Normals
aren't really helpful here, because the surface is transparent. :-(
Early on I tried normals on the solid surface *below* the SSS, but that
made the patterns only visible on the dark side of the sand dunes, which
is why my first screenshots were all backlit. :-)
Oddly enough, crand *does* work on a transparent surface. I'm still on
the fence whether that's a good long-term solution.
Heh, you have no idea how I abuse AA. :-) I've posted images here before
with textures that look gorgeous under 0.1 AA, but which look like vomit
on the screen without AA. ;-)
William Tracy
You know you've been raytracing too long when you have to buy a new
computer to do your homework on because the other 5 are still rendering
that cool finale of "Godzilla meets the Julia monster ... with
volumetric lights".
    00 AmaltheaJ5
iD8DBQFHRxudKrVIcTMekC8RAmVCAKCVImDS7nH90y0d53KUKyGgtUWkPACgg7lu
tvCMXYGghMN+ALKKI6O1KzQ=
=lEgj
Subject: Re: Sand
Date: 23 Nov 2007 13:29:52
Message: <47471c20@news.povray.org>
Hash: SHA1
Incidentally, I bet snow would look fantastic with heavy SSS.
Hmm, something else to try. ;-)
William Tracy
You know you've been raytracing too long when you've ever thought or
said out-loud, "I'll bet I can raytrace that!"
    -- Neil Clark
iD8DBQFHRxwhKrVIcTMekC8RAllAAJ99JI6cDtK0fBTwKR/opQa1B+i5KACfcMJs
Q++218oF9kVmNHpZ3LYDVdU=
=m/AX
Subject: Re: Sand
Date: 23 Nov 2007 15:15:01
Message: <web.474733ebee83a16cc150d4c10@news.povray.org>
Ah right, I see what you mean.  Forgot about the SSS.  Still, maybe try to use
the crackle or cell pattern for your density instead.
-tgq
Subject: Re: Sand
Date: 23 Nov 2007 15:25:00
Message: <web.474736c6ee83a16cc150d4c10@news.povray.org>
Some further thoughts on this.
Maybe you can still use normals, but try adding fresnel (or variable)
reflection.
Have a look at this photo: http://www.benzor.com/misc/desert.jpg
Part of the colouring and look of the sand appears to come from actual specular
reflection.
-tgq
Subject: Re: Sand
Date: 24 Nov 2007 04:16:25
Message: <4747ebe9$1@news.povray.org>
"Trevor G Quayle" <Tin### [at] hotmailcom> schreef in bericht
news:web.47470378ee83a16cc150d4c10@news.povray.org...
> get
> give
> rather
> though
With the example William provided above, the cells pattern gives an
excellent result!
Subject: Re: Sand
Date: 24 Nov 2007 04:19:33
Message: <4747eca5@news.povray.org>
"Thomas de Groot" <t.d### [at] internlDOTnet> schreef in bericht
news:4747ebe9$1@news.povray.org...
> excellent result!
I forgot to say that I changed the scale to 0.0005 too, but that may vary
with the scene involved.
Good work William!
Subject: Re: Sand
Date: 24 Nov 2007 20:03:37
Message: <4748c9e9$1@news.povray.org>
Hash: SHA1
> What do you think?
I just finished picking apart the code for "Picnic at Giza":
emkaah uses the following heightfield for the sand:
#declare PF0 = pigment{
  bumps
  turbulence 0.1
  color_map { [0 rgb .12] [1 rgb .1] } scale <1,.9,1>*0.1 translate x*-5
#declare PF1 = pigment{
  crackle
  form<.86,0,0>
  turbulence 0.4
  color_map { [0 rgb .105] [1 rgb .08] }
  scale <1,.8,10>*0.1
  translate <-2,-1,0>
#declare PF2 = pigment{
  bumps
  color_map { [0 rgb .11] [1 rgb .072] }
  scale .2
  translate x*-1
#declare PF=function {
  pigment{
    gradient z
    pigment_map{
      [0 PF0]
      [.40 PF0]
      [.50 PF1]
      [.60 PF2]
      [1 PF2]
    turbulence .3
#declare sandh1 = height_field{function 600,600 {PF(x,0,y).grey} /* lots
of extraneous parameters removed */ }
So, there's a gradient used as a pattern map, with PF0 being the pattern
in the foreground, PF1 in the midground, and PF2 in the distance.
There's some turbulence to keep the transitions from being too sharp.
PF2 is the pattern for the slope up just before the base of the
pyramids. It's a crackle pattern; that's how he got those neat little
valleys running down the slope.
I also want to fiddle with the source for "Mirage", from the same IRTC
round:
http://www.irtc.org/ftp/pub/stills/2004-08-31/mirage.jpg
What struck me about that image is that there's no doubt that the sand
in the image is *sand*. That's more than you can say for a lot of the
entries in that round. :-P
It's very stylized, but still instantly recognizable as sand.
William Tracy
> >  - Type 0 are tesselated dynamically during render time and the
> > tesselation results are discarded immediately once the intersections
> > are found. In particular, I noticed that POV accessed the u_order
> > and v_order variables and repetitively called the DeCasteljau
> > subdivision functions during intersection computations...
I see.
    -- Warp
iD8DBQFHSMnpKrVIcTMekC8RAmNKAJ4y7D43pY6etFSEndPRYTS9MrEo2ACgmukT
pmx/BoFOt404ZlgNF7qw8tI=
=N5xF
