POV-Ray : Newsgroups : povray.binaries.images : Tree Photo (wip1) Server Time
21 Feb 2026 02:22:01 EST (-0500)
  Tree Photo (wip1) (Message 1 to 4 of 4)
Subject: Tree Photo (wip1)
Date: 16 Nov 2007 01:29:57
Message: <473d38e5@news.povray.org>
So, I'm doing this for art class.  It isn't finished yet, and I don't
have too much time to get it finished.  But, it is a start.  One thing
that stands out to me is the clouds... the sphere is way too small for
me, so I'll replace that with a plane instead... only problem is the
27hour render times.
Comments and Critique welcomed and requested...
Thanks,
Allen
Download 'trees.jpg' (106 KB)
Preview of image 'trees.jpg'
Subject: Re: Tree Photo (wip1)
Date: 16 Nov 2007 03:52:07
Message: <473d5a37@news.povray.org>
"Allen Dotson" <all### [at] emailnutscom> schreef in bericht
news:473d38e5@news.povray.org...
For different reasons, the clouds seem to press down on the landscape, not
necessarily because the sphere is too small. The first reason is that a
proper atmosphere is missing, either a fog or a media, in order to give some
depth to horizon distance and sky heights. A second, more psychological
reason, is the elongated format and high horizon, which increase the weight
of the clouds. However, imo, the first reason is the most important.
Otherwise, good work! I like this scene.
Date: 16 Nov 2007 08:25:02
Message: <web.473d9998b3ad60bdd21a49b0@news.povray.org>
> Thanks,
> Allen
Ufda!  27hrs!  I don't have that kind of patience.  That must be why I never
bother with trying to do media clouds anymore.  Nevertheless, the image looks
good!  Patience pays off!
One thing I might suggest trying:  to add more interest to your grass, try using
a pigment function to vary the length and color of the grass.  For example:
#declare TheFunction =
function {
    bumps
    poly_wave 4
    color_map {
      [0 rgb 0 ]
      [1 rgb 1 ]
And then, when you are planting your grass (through whatever method you prefer):
(if POS is the current grass position)
  object {GRASS scale (1+TheFunction(POS.x,POS.y,POS.z).red) translate POS}
Depending on how you've done your Grass object, you can use a similar method to
vary the color of your grass.
Just something you might try.
Date: 17 Nov 2007 04:42:54
Message: <473eb79e$1@news.povray.org>
"Kirk Andrews" <kir### [at] tektonartcom> schreef in bericht
news:web.473d9998b3ad60bdd21a49b0@news.povray.org...
> using
> example:
> function {
>  pigment {
>    bumps
>    poly_wave 4
>    color_map {
>      [0 rgb 0 ]
>      [1 rgb 1 ]
> prefer):
> method to
Another, alternative, method you might like to try, is using RRand(A,B,seed)
for putting some randomness in scale, position and color.
