"Thomas de Groot" <t.d### [at] inter nlDOTnet> wrote:
> The gap at the base of the ribbon can be filled I think, if you scale down
> the skullcap a bit before growing the hair. Typically, I scaled it at 99%
> intuitively, without being aware of the gap.
That's a good idea.
> The twists are something FlyerX mentioned in his answer above. He is
> experimenting with tubes now and that might be an excellent alternative.
> Thomas
Oops, I guess I missed that part about the twists.
> This is an ugly image. Never mind. There are a couple of puzzling features.
> I used here Janet's hair maps, uv-scaled x500 along u, and on fairly wide
> ribbons (default Poseray values). Other values might give better results of
> course.
> Puzzling feature 1: The background shines through the figure! Not only the
> hair but also the underlying skin. I had noticed this in a much earlier
> experiment but forgot about it.
> Puzzling feature 2: the transparency at the hair tips casts shadows on the
> underlying skin.
I'd be curious to see this rendered without any uv scaling.
> Additional comment: I am still not sure about the usefulness of the ribbon
> roots. They are detached from the hair proper. Why not grow the hair
> directly from the line origin?
I don't understand the point of the root material either. It just assigns
the first face a new material. The ribbons still start at the same spot
with or without it.
Janet
Subject: Re: Poser's dynamic hair in POV-Ray (WIP 4)
Date: 26 Oct 2007 03:49:02
Message: <47219bee@news.povray.org>
"Janet" <par### [at] att net> schreef in bericht
news:web.472092d6c64416986697168f0@news.povray.org...
I had been carried away by my enthousiasm to manipulate the uv's :-)
Here is the same, without scaling and without ribbon roots. The textures
looks indeed much better. However, the puzzling features remain.... :-(
> with or without it.
Indeed. That is what I was also wondering about...
Download 'PoserFiguretest.png' (235 KB)
Preview of image 'PoserFiguretest.png'
Subject: Re: Poser's dynamic hair in POV-Ray (WIP 4 without transparency)
Date: 26 Oct 2007 04:24:12
Message: <4721a42c@news.povray.org>
The figure without hair transparency map renders correctly as far as the
backgropund is concerned. So what goes wrong with the transparency map?
This is the material code as generated by Poseray (comments added by me):
#declare p_map10=pigment {image_map{jpeg "C:\....\Janet_hair.jpg"
interpolate 2 transmit all 0 filter all 0} }
#declare p_map11=pigment {image_map{jpeg "C:\....\Janet_trans.jpg"
interpolate 2 }}
#declare Hair__opaque=
texture{ pigment{ p_map10} //this is the hair map
finish{specular 0.5019608 roughness 0.00286312 ambient rgb <0,0,0>
diffuse 0.8 reflection{0 metallic} conserve_energy}}
#declare Hair_=
material{
texture{ pigment_pattern{ p_map11} //this is the transparency map
texture_map{[0 pigment{Clear}]
[1 Hair__opaque]
Somebody with a smart idea??? :-)
Download 'PoserFiguretest.png' (237 KB)
Thomas de Groot nous apporta ses lumieres en ce 2007/10/26 03:48:
>> with or without it.
> Thomas
You still see trough his head. Is that what puzzles you?
You know you've been raytracing too long when you see the movie credits going by
and instead of seeing Lenses by Panaflex it always seems to say Lens Effects by
Chris Colefax.
Ken Tyler
"Alain" <ele### [at] netscape net> schreef in bericht
news:4721e90e$1@news.povray.org...
Yes indeed!
comment reserved until we know if this is a self portrait.
alphaQuad wants to upload new mesh for experimentation.
sorry had to be sed.
Date: 26 Oct 2007 22:38:09
Message: <4722a491@news.povray.org>
Hash: SHA1
Mmm, bacon for hair. (Sorry, couldn't resist.)
William Tracy
afi### [at] gmail com -- wtr### [at] calpoly edu
You know you've been raytracing too long when other people's Images
directories contain N00D G1F$ downloaded from the Net. Your Images
directory contains raytraces that you upload *to* the Net.
-- Jeff Lee
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFHIqSRKrVIcTMekC8RAkDeAJ0daeSgCRVjssU5+X7D2xlXk/OhzwCfZOGl
rhYD5fOF6IRPXyrCdWGIm3c=
=w1Rz
-----END PGP SIGNATURE-----
"alphaQuad" <alp### [at] earthlink net> schreef in bericht
news:web.472246b5c644169862b5d7be0@news.povray.org...
Of course it is a self portrait! All my figures are self portraits one way
or another :-)
Date: 27 Oct 2007 03:21:56
Message: <4722e714$1@news.povray.org>
"William Tracy" <wtr### [at] calpoly edu> schreef in bericht
news:4722a491@news.povray.org...
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
That makes chewing the ends of your hair or beard so enjoyable (although
somewhat nauseating...) :-)
