POV-Ray : Newsgroups : povray.binaries.images : TC-RTC WIP Server Time
11 Oct 2024 00:16:04 EDT (-0400)
  TC-RTC WIP (Message 1 to 3 of 3)
Subject: TC-RTC WIP
Date: 23 Sep 2007 01:04:46
Message: <46f5f3ee@news.povray.org>
Hash: SHA1
On the off chance that anyone cares what I'm doing, here's a pic. There
must be something with me and extraterrestrial desert scenes. :-)
Took about an hour and a half at 1GHz (if I didn't still need MegaPOV
for another project, I'd upgrade to 3.7 so I could use both cores) and I
haven't even turned on radiosity. Everything is an isosurface (okay,
except the sky, but you knew that).
I like how my alien termite mounds look right now, so maybe I'll futz
with the terrain again. It's way too flat, and just a little too regular.
Oh, yeah, and I want to add swarming creatures coming out of the hive. :-)
Alternatively, I could skip the TC-RTC, and turn this into an ad for the
prevention of sexually transmitted diseases... 8-O
William Tracy
afi### [at] gmailcom wtr### [at] calpolyedu
You know you've been raytracing too long when you have ever snuck out of
your bedroom to moniter the progress of an overnight render.
    -- Stephan Ahonen
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD4DBQFG9fPtcCmTzQ++ZncRAm40AJsFlaYdjRKiwleFeCzc+hfHqO6gjgCYvEwd
Uym1259kTzxYlc4AfxH3Tg==
=xwkU
-----END PGP SIGNATURE-----
Download 'swarm.jpg' (182 KB) Download 'swarm.jpg.sig.dat' (1 KB)
Preview of image 'swarm.jpg'
Subject: Re: TC-RTC WIP
Date: 23 Sep 2007 19:22:05
Message: <46f6f51d$1@news.povray.org>
A couple comments:  I think you need a closer viewpoint, just too much
empty space as it is.  Perhaps a very close and low viewpoint making
them tower into the sky.  Also I'm a bit bothered by the way the mounds
simply sit on the ground -- there should be at least some transition,
like the mud going a little way up their bases.
The horizon in the exact center of the image is generally, aesthetically
considered a no-no, too static.  Either lower the horizon to emphasize
the sky or raise it to emphasize the ground.  I think a low, close
viewpoint (low horizon) whould give you a much stronger image.  But
that's just one person's personal opinion -- take it for what it is.   ;-)
     -=- Larry -=-
Date: 23 Sep 2007 19:46:48
Message: <46f6fae8$1@news.povray.org>
Hash: SHA1
Thanks for the feedback. :-)
Right now, I'm playing with getting textures and shapes to work; the
composition will probably change a bit as the work progresses.
I put the camera at such a distance because I was trying to create a
feel of something that's too dangerous to get close too. That may or may
not be such a good idea.
I'm wavering on whether or not I should have the mounds blend into the
land more or not; part of me likes how much more "alien" they look this
way. It's also less work. ;-)
I will agree with you on the horizon line. I will fiddle with that as
the scene evolves; I plan on changing the terrain a bit here, so the
horizon will definitely change.
William Tracy
You know you've been raytracing too long when you spend hours setting up
a slide show of all your pov generated images, then invite friends,
neighbors and relatives over and no one will watch it with you.
    -- Ken Tyler
iD8DBQFG9vrocCmTzQ++ZncRAkXHAKClJcVZYic33FSWMx/yjxsZUQczcwCePkyR
MNxBILpXly+0NIeketDiD7o=
=pnQm
