POV-Ray : Newsgroups : povray.binaries.images : high school math Server Time
1 Aug 2026 10:40:21 EDT (-0400)
  high school math (Message 21 to 28 of 28)
Subject: Re: high school math
Date: 11 Aug 2007 08:47:45
Message: <46bdaff1$1@news.povray.org>
Grassblade wrote:
> Nice pic
Thank you.
> although I preferred the Only for Geeks pic, possibly because
> it looks more finished. Am I imagining things or does this pic bear
> more than a passing resemblance with the other one? Apart from having
> more vertices, that is.
Conceptually they do resemble each other. Geometrically, they are in no
way similar.
> I'm also curious on how you can state that it doesn't intersect. I'm
> not doubting it, just wondering.
I built it; I would know if it intersected. I've been working similarly
- though less elaborately - for years; All of the "what if's" and "how
about's" have long since been explored. Nothing intersects.
- Shay
Date: 12 Aug 2007 03:00:36
Message: <46beb014$1@news.povray.org>
I feel that what makes this (and also 'only for geeks') image so appealing
to the eye is the 'randomness' enclosed in a very strict crystal shape. I am
not sure, a dodecaedron? And the randomness shows several elaborate
symmetries and mirrored rotations. The more I look at it, the more I get the
impression to look at a crystal lattice.
Date: 12 Aug 2007 17:19:09
Message: <46bf794d$1@news.povray.org>
>> And I should add that the image is simply amazing and instructive - in
>> the purist sense.
> Don't know if you're talking about the image in this post or the link
> image. I imagine you'd be diplomatic and say "both" or "either."
> Whatever the case, thank you for the compliment.
Well, for the first image I said "Amazing! Bathsheba Grossman-esque." and
meant every word of it.
This is more complex, if less textural, and it simply amazes me that you can
figure out such a convoluted non-intersecting path.
How many closed circuits are there? One? More? Are they knotted? I see at
least some superficial symmetry which would suggest at least two. If so
coloring them differently would be truly instructive - I get lost too
easily!
DLM
Date: 13 Aug 2007 00:55:00
Message: <web.46bfe3a0292548dd3574c6bd0@news.povray.org>
> >> the purist sense.
> easily!
> DLM
I'd like to see a simple 360 degree looped spin of this.
Charles
Date: 13 Aug 2007 11:40:03
Message: <46c07b53@news.povray.org>
> see at least some superficial symmetry which would suggest at least
> two. If so coloring them differently would be truly instructive
Too instructive!! I had a street-magician friend named "Magic Mike."
Magic Mike, when asked to repeat a trick, would always reply that "Once
is entertainment. Twice is education." There's no once ... twice in a
still picture, but the heart of his rule survives: over-exposition
destroys the magic.
And the magic is there for more than just bragging rights. Back in
February 2004, I posted the first in a "series" of pictures with the
intent of presenting my colors and lines with such extreme flourishes
that a viewer would be unable to dismiss my abstract images as
"something a child could do."
That 2004 picture was "magical" to me, and I thought I had correctly
identified the source of that magic as these flourishes. Now, I'm not so
sure. Slowly, through subsequent and even one previous work, I
identified the magic of iteration. So this idea from 2004 has split into
two branches: the flourish branch, which has become nearly all flourish,
and the iteration branch which has become so unflourished that it is no
longer appropriate for this group.
 -Shay
Date: 13 Aug 2007 11:46:30
Message: <46c07cd6$1@news.povray.org>
Rune wrote:
> I really like the style. Shape, color and lighting work beautifully
> together. :)
> Rune
Thank you, Rune. Colors are reverse engineered by taking test-render
colors and comparing them with the colors from my scene file. This tells
me how the colors change in the given setup and where to start to end up
where I want to be.
 -Shay
Date: 13 Aug 2007 12:01:03
Message: <46c0803f$1@news.povray.org>
> Thomas
Thank you. I agree the constraints under which the form was created are
what make the image a success. Monochromatic, hard-line "flutterings"
are a popular (passe) CG theme. A viewer may not immediately and
consciously identify the strict Formalism of this "fluttering," but he
will, I believe, be affected by it.
 -Shay
Subject: Re: BTW
Date: 13 Aug 2007 14:46:03
Message: <46c0a6eb$1@news.povray.org>
> Shay
  More to the point, I like the way you've done the soft shadows.
      ~Steve~
