POV-Ray : Newsgroups : povray.binaries.images : Eavesdropping - new WIP (~130kB) Server Time
1 Aug 2026 12:06:12 EDT (-0400)
  Eavesdropping - new WIP (~130kB) (Message 21 to 30 of 37)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: Eavesdropping - new WIP (~130kB)
Date: 15 Aug 2007 05:15:26
Message: <46c2c42e@news.povray.org>
"Stephen" <mcavoys_AT_aolDOT.com> schreef in bericht
news:web.46af290816060248c4e49fa40@news.povray.org...
> This is coming along nicely. Will we see a glimpse of Cathy skipping along
> the quay?
Well Stephen, look at this little vignette, taken from the lower right-hand
corner of the image. I have added Cathy (and her little brother), and it
seems that the observer/beholder has been exposed  :-)
This is a small test render using radiosity to see how that is going to
affect the scene.
Not so visible here, but I have used Soft Decoration Groups (Poser Cloth
Room) for the yellow braids on Cathy's dress. Up close, these show as the
three dimensional decorations they are in reality.
Download 'Oreille Indiscrete.png' (40 KB)
Preview of image 'Oreille Indiscrete.png'
Date: 15 Aug 2007 06:10:00
Message: <web.46c2d09716060248c4e49fa40@news.povray.org>
> > the quay?
> affect the scene.
> Thomas
Oh! That is intriguing. A bit small and out of context not to mention it is
something wrong with their eyes? When I adjusted the size and contrast to
getting a white eye look.
Date: 15 Aug 2007 07:23:04
Message: <46c2e218@news.povray.org>
news:web.46c2d09716060248c4e49fa40@news.povray.org...
> is
> a bit dark for my monitor. But I've mentioned that before :-) Is there
> see it better the eyes look strange. I've noticed in a couple of my models
> that I had to tweak the "Eyeball" material's transparency because I was
It is the same scale as the main image and is not intended to intrude too
much on the main story. It is a kind of sideline. And remember, we are in
the shadow here, the only light coming from the sunlight reflection on the
wall to the right, and diffused light coming from the left.
The eyeballs have been corrected with M_Glass3 (which FlyerX advised me to
use). I suppose that what you see is the reflection of the sunlight that is
reflected from the wall. However, the anti aliasing (0.3) is too coarse for
this image and should be finer. In the final render this will be brought
down to 0.1. Otherwise, I 'know' that the eyes are rendered correctly. Both
of them looking upwards increases in fact the amount of white visible too.
Date: 15 Aug 2007 08:13:26
Message: <46c2ede6$1@news.povray.org>
"Thomas de Groot" <t.d### [at] internlDOTnet> schreef in bericht
news:46c2e218@news.povray.org...
> is reflected from the wall. However, the anti aliasing (0.3) is too coarse
> for this image and should be finer. In the final render this will be
> brought down to 0.1. Otherwise, I 'know' that the eyes are rendered
> correctly. Both of them looking upwards increases in fact the amount of
> white visible too.
I can confirm this now: I rendered only the eyes with aa=0.01 and they
appear correctly, without white glare.
Date: 15 Aug 2007 10:35:00
Message: <web.46c30e8216060248c4e49fa40@news.povray.org>
> > white visible too.
> Thomas
I like the idea of having a little in joke that is unobtrusive. The problem
here is, any image will be looked at critically with respect to the poster,
yours, amongst others more than most. (Your own fault for being so good :-)
PoseRay transparency.
I'm looking forward to the next version.
Date: 16 Aug 2007 03:02:07
Message: <46c3f66f$1@news.povray.org>
news:web.46c30e8216060248c4e49fa40@news.povray.org...
> problem
> poster,
Hm hm hm... I shall refrain from posting from now on..... :-)
Well, there is nothing wrong with a good bunch of criticism. Over the years
that has helped me a lot, sometimes by just discarding it as nonsense   :-)
In the end, one has to make one's own choices.
The idea of a little joke embedded in the image is always at the back of my
mind. Sometimes it is functional, sometimes not. In this case, I believe it
can add an interesting item: the observer is confronted to different story
lines, one as a neutral observer, one as a participant into the main drama
plot, one as an actor in the juvenile side story. Others may come to mind I
am sure. That is left to the observer.
> It's interesting that FlyerX suggested M_Glass3 I've just been maxing the
To a question I asked him about the transparency issue with the eyes (Apollo
Maximus), FlyerX answered as follows
<quote>
In my opinion the iris for this model should not have any highlight. All the
surface gloss should come from the cornea and EyeWhite materials. If the
cornea is set to material{M_Glass3} and the iris set to black highlight you
should get a better result. See attached image. You can go into the POV-Ray
material tab and add the Glass3 material to the cornea. PoseRay will send
that material to POV-Ray at render time. For Victoria 2 models I also use
M_Glass3 as the eyeball material that covers the eye and gives much better
results that any Poser related material.
<unquote>
> Anti aliasing is something I've been experimenting with recently, trying
> to
> get the fastest acceptable value for an animation. I'm having fun.
I suppose that for an animation you can get away with a coarser anti
aliasing?
Wait and see :-) May take some time now because I am going to render with
radiosity...
Date: 16 Aug 2007 05:15:00
Message: <web.46c4154216060248c4e49fa40@news.povray.org>
> > problem
> > poster,
confirm what a bunch of nitpicker we are :-)
said earlier about the way scenes are built. IIRC she preferred to build
scenes from the top down while I prefer to build them from the bottom up. I
find that my final image can vary considerably from my original concept as
each new object/character influences the way the scene develops. Sometimes
another direction. Keep up including you family as a motif.
[snip]
Kung Fu master. So I just eliminated the problem.
> > to
> aliasing?
I certainly hope so but as there is a lot of static components and I made
the mistake of using a CSG to make fluting on a couple of columns that give
> radiosity...
Have a book to hand.
BTW I've kept a couple of Ken Macleod paperbacks if you want them. Now I'm
here the postage would not signify
Subject: Eavesdropping - final pre-radiosity WIP (~120kB)
Date: 16 Aug 2007 06:04:07
Message: <46c42117@news.povray.org>
news:web.46c4154216060248c4e49fa40@news.povray.org...
> Oh please don't stop posting. Peer review is always useful even if only to
Allright. You asked for it. Here is a final WIP in pre-radiosity format,
with all latest changes (amongst others the use of LightSys)
Hey! That would be fantastic! Thank you! I'll send you my address
separately.
Download 'Eavesdropping.jpg' (120 KB)
Preview of image 'Eavesdropping.jpg'
Subject: Re: Eavesdropping - final pre-radiosity WIP (~120kB)
Date: 16 Aug 2007 08:05:01
Message: <web.46c43c5a5f3407c1c4e49fa40@news.povray.org>
> separately.
Date: 17 Aug 2007 13:28:30
Message: <46c5dabe$1@news.povray.org>
Shay wrote:
> How about sphere_sweeps for column and flutes? Evaluating the spline
> functions would give any circumference you need.
I am not really sure there is support for an interpolated or function
driven reduction of the radius in the sphere_sweep syntax but I have
only ever looked at it briefly. In any case I still would not be able to
compose such a function.
So I'll take a look. Of course I can improvise my own.  (I guess I do
that sort of thing a lot an so was hoping for some other way.)  Since
you prodded me with this post, though, I will probably improvise
something with spheres and cones along a spline.  I'll build the spline
using the trace function and sample the sphere surface after it is
already scaled.  I'll do it just to see how it works.
But constructing the thing in mesh is far and away the pragmatic
approach, it now seems obvious.
