POV-Ray : Newsgroups : povray.binaries.images : stone and brick wall Server Time
1 Aug 2026 11:59:08 EDT (-0400)
  stone and brick wall (Message 3 to 12 of 22)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: stone and brick wall
Date: 24 Jul 2007 14:02:34
Message: <46a63eba$1@news.povray.org>
Stefan Viljoen wrote:
> Are you going to make the macros available somewhere...? *hint!*
<AOL> Me too! </AOL>
     I bet exercise equipment would be a lot more
     expensive if we had evolved from starfish.
Date: 24 Jul 2007 19:38:25
Message: <46a68d71@news.povray.org>
Very nice stone wall.  Some suggestions:
- Perhaps tone down the colour variation and degree of pitting of the
stones.  In practice the stones would likely be quarried from the same
place and would have less variation.  Still this is very pretty so make
it a parameter ?
- A real stone wall would also need to be much thicker to stand safely
- The lintel would also have to be thicker (in height) and more deeply
set (extending further beyond the left and right sides of the window space
The brick wall looks good at a distance.  In closeup I'd say that the
mortar needs to be thinner and with a much finer pattern.  The brick
texture looks smoother than in reality but of course adding the required
roughness would be quite difficult.  I like the dirt / mold overlay.
I'd love to see progress so please keep us posted.
Date: 24 Jul 2007 23:21:03
Message: <46a6c19f$1@news.povray.org>
> So far I have a more or less convincing brick texture (not perfectly
> suitable for close-ups as can be seen in brickwall-zoomedin.jpg),
Good stuff Zeger,
Do you allow variability in the dimensions of bricks? I'm used to English
style bricks which are not so elongated.
See http://www.sizes.com/materls/modular_brick.htm for a reference for
different styles and dimensions. When bricks are laid and dressed some sort
of bar (often cylindrical or square) is pulled along the cement leaving a
concave depression - the grain follows the brick edges. Your closeup bricks
appear to be projected over the cement resulting in an unreal feeling. Also
there is too much cement.
As always, I look forward to more of your excellent work.
dlm
Date: 25 Jul 2007 01:17:07
Message: <46a6dcd3$1@news.povray.org>
"Stefan Viljoen" <spa### [at] removethispolardcom> wrote in message
news:46a63dd7@news.povray.org...
> Nice - looks like the stonework in the old Bitmap Bros. Game "Gods"...
don't know that game though
I hope to publish the macros one day, but I'll have to clean up the code
first.
cu!
Date: 25 Jul 2007 01:25:10
Message: <46a6deb6$1@news.povray.org>
"Paul Fuller" <pgf### [at] optusnetcomau> wrote in message
news:46a68d71@news.povray.org...
thank you!
> place and would have less variation.  Still this is very pretty so make it
> a parameter ?
very true! as it is now, the macro only defines the location and size of the
stones, another macro makes random stones, with random textures, which get
scaled and positioned accordingly, so in a way, it already is a parameter,
albeit not explicitely.  I believe this approach gives you the most
flexibility.
no problem, that can be adjusted
> - The lintel would also have to be thicker (in height) and more deeply set
again no problem :)
I might have an idea of how to make it look better, using the accuracy
keyword in the normal-block.  The default value of .02 is way too high to
make a rough look on that scale.
I'll have to do some tests though
will do :)
cu!
Date: 25 Jul 2007 01:31:25
Message: <46a6e02d@news.povray.org>
"dlm" <me### [at] addressinvalid> wrote in message
news:46a6c19f$1@news.povray.org...
> Good stuff Zeger,
thank you :)
absolutely, you can adjust the size of the bricks, and the way they're
placed.  Currently, there are 2 types: type 0 (which looks like the normal
brick pattern, but with more control over the shape and smoothness), and
type 1 (which is what I showed here)
> I'm used to English style bricks which are not so elongated.
that's interesting, I could use that for some default settings! thanks!
> When bricks are laid and dressed some sort of bar (often cylindrical or
> square) is pulled along the cement leaving a concave depression - the
> grain follows the brick edges. Your closeup bricks appear to be projected
> over the cement resulting in an unreal feeling. Also there is too much
> cement.
currently the cement is not affected in any way by the bricks, it's just a
very simple granite-pattern.  I might change that, but as long as the bricks
look too smooth for close-ups, I don't think it's worth the trouble, because
you won't notice it anyway from a distance :)
thank you :)
cu!
Date: 25 Jul 2007 02:59:22
Message: <46a6f4ca$1@news.povray.org>
Excellent start, Zeger! Impatient to see next stages.
Date: 25 Jul 2007 04:55:01
Message: <web.46a70f54206a8a8bbe7bfb550@news.povray.org>
I have two things to tell you Zeger
1. GREAT JOB!!!
2. I love the way you do the clouds. I have visited your page and seen your
fast clouds system. Is that "system" available? I would like to check it,
results look quite good.
http://personales.ya.com/robertoullan/index.htm
Date: 25 Jul 2007 05:44:02
Message: <46a71b62@news.povray.org>
very nice start!
You should avoid splices that are shaped like an "+". In the real world
they lead to weaker walls.
Some years ago I did an arch macro for generating brick archs. Maybe
it's of use for you:
http://b0n541.net/povray/povmacro.html
Just my two eurocents,
Bonsai
    ___ __ __  _ ___ ___  _
   | _ )  \  \( )  _) _ )( )
   | _ \() |\ \ |\ \/ _ \| |
   |___/__/_)\__)___)/ \_)_)
        www.b0n541.net
Date: 25 Jul 2007 06:32:31
Message: <46a726bf$1@news.povray.org>
"Thomas de Groot" <t.d### [at] internlDOTnet> wrote in message
news:46a6f4ca$1@news.povray.org...
thank you !
as am I :p
cu!
