POV-Ray : Newsgroups : povray.binaries.images : stone and brick wall Server Time
1 Aug 2026 10:39:24 EDT (-0400)
  stone and brick wall (Message 13 to 22 of 22)
Subject: Re: stone and brick wall
Date: 25 Jul 2007 06:40:47
Message: <46a728af$1@news.povray.org>
"kike" <dry### [at] hotmailcom> wrote in message
news:web.46a70f54206a8a8bbe7bfb550@news.povray.org...
>I have two things to tell you Zeger
> 1. GREAT JOB!!!
> 2. I love the way you do the clouds. I have visited your page and seen
> your
> fast clouds system. Is that "system" available? I would like to check it,
> results look quite good.
I know it's not really the right place for this, but I'm too lazy to direct
you to p.b.s-f, so see attachment :)
it's used like this:
fastclouds(Sun_Location, Cast, Fluffyness, Translate, SkyScale, CloudScale,
MinimalTransparency, Sun_Color, Ambient)
(skyscale is multiplied by 500 internally, don't ask me why :))
you can change the pattern used for the clouds by declaring CloudForm (which
is a pigment)
It only creates the clouds, not the sky, so you should add your own sky.
The full code for the clouds used in these images is:
//--start code--//
#include "fastclouds.inc"
fastclouds(<600,750,-500>*1000,.455,.1,1000,10,.05,0,<1.5,1.3,1.1>,1)
fog {
  fog_type 2
  distance 75
  color rgb <213,205,194>/255
  transmit 0
  fog_offset -1
  fog_alt 2
sky_sphere {
  planar
  color_map {
   [0 rgb <22,44,68>/255]
   [.5 rgb <88,120,179>/255]
   [1 rgb <213,205,194>/255]
//--end code--//
cu!
Download 'fastclouds.inc.txt' (2 KB)
Date: 25 Jul 2007 06:42:42
Message: <46a72922$1@news.povray.org>
"Bonsai" <bon### [at] b0n541net> wrote in message
news:46a71b62@news.povray.org...
> Hi,
> very nice start!
thank you !
> You should avoid splices that are shaped like an "+". In the real world
> they lead to weaker walls.
I know, but I'm not quite sure yet how to avoid them :-/
> Some years ago I did an arch macro for generating brick archs. Maybe it's
> of use for you:
it sure is! thanks!!!
cu!
Date: 25 Jul 2007 11:04:44
Message: <46a7668c$1@news.povray.org>
"Bonsai" <bon### [at] b0n541net> schreef in bericht
> Hi,
> very nice start!
True. However, I know Real World buildings where they exist... already for
centuries  :-)
I have to admit that those walls are thick too. So, that compensates.
Date: 26 Jul 2007 03:50:01
Message: <web.46a851a6206a8a8b119a37fe0@news.povray.org>
Very nice work
you can upload the source of the macro? I could want take a eye over the
source
Date: 26 Jul 2007 04:24:11
Message: <46a85a2b$1@news.povray.org>
"Agustin Britait Molina" <agu### [at] hotmailcom> wrote in message
news:web.46a851a6206a8a8b119a37fe0@news.povray.org...
> Very nice work
> source
once I've found the time to clean up the code, I'll post it to p.b.s-f
cu!
Date: 4 Apr 2018 09:05:01
Message: <web.5ac4cd18206a8a8b9300d48f0@news.povray.org>
Now after 10 years, Zeger, did you finally clean up the code? :-D
I, too, would be very interested. Hope you get still notifications of this
newsgroup and can respond. :-)#
I still love your SciFi greebles!!!
> > Very nice work
> > source
> cu!
> #macro G(b,e)b+(e-b)*C/50#end#macro _(b,e,k,l)#local C=0;#while(C<50)
> sphere{G(b,e)+3*z.1pigment{rgb G(k,l)}finish{ambient 1}}#local C=C+1;
> #end#end _(y-x,y,x,x+y)_(y,-x-y,x+y,y)_(-x-y,-y,y,y+z)_(-y,y,y+z,x+y)
> _(0x+y.5+y/2x)_(0x-y.5+y/2x)            // ZK http://www.povplace.com
Date: 30 Jan 2021 07:55:00
Message: <web.601556ff206a8a8b4e933a390@news.povray.org>
It may be in the object collection. It looks familiar.
Mike
Date: 30 Jan 2021 11:56:16
Message: <60158fb0$1@news.povray.org>
The block wall in the Object Collection is by Chris Bartlett, written
about a year and a half after Zeger started this thread.
http://lib.povray.org/searchcollection/index2.php?objectName=BlockWall&contributorTag=chrisb
Date: 30 Jan 2021 14:25:56
Message: <6015b2c4$1@news.povray.org>
Whoops, I'm not much into POV-Ray anymore, I'm not even sure I still
have the source for this image :/
And if I do, I'd probably not understand the code anymore :(
Sorry
Date: 6 Feb 2021 21:06:42
Message: <601f4b32$1@news.povray.org>
I ended up using something mesh-based.
https://github.com/mjhorvath/Mike-Wikipedia-Illustrations/blob/master/Color/rbg_spotlights/rgb_spotlights_d.pov
http://www.infradead.org/~wmp/macro_meshrelief.html
Mike
