POV-Ray : Newsgroups : povray.binaries.images : just for fun (132kb jpg) Server Time
25 Jul 2025 20:20:39 EDT (-0400)
  just for fun (132kb jpg) (Message 1 to 7 of 7)
Subject: just for fun (132kb jpg)
Date: 15 Jul 2007 22:59:43
Message: <469adf1f@news.povray.org>
Hi all,
This idea came about earlier, while I was drawing with and ink. The
technique isn't new, but I can't remember who originated it. Basically,
it involves a sphere with high transmittance placed around the camera.
The textures are gradients. They are turned into lines under the
influence of the contrast-inducing sphere mentioned beforehand.
Rendered in a single pass. Sized and framed with the Gimp. Questions and
comments are always welcome!
~Sam
Download 'woodcut.jpg' (133 KB)
Preview of image 'woodcut.jpg'
Subject: Re: just for fun (132kb jpg)
Date: 16 Jul 2007 06:31:18
Message: <469b48f6$1@news.povray.org>
Samuel Benge wrote:
> Hi all,
> Basically, it involves a sphere with high transmittance placed around
> the camera. The textures are gradients. They are turned into lines
> under the influence of the contrast-inducing sphere mentioned
> beforehand.
> and comments are always welcome!
Ooh, that looks nice! Even knowing the technique, I can't quite figure out
how the image must look before the contrast enhancement.
The technique is demonstrated in the POV-Ray demo files
\scenes\textures\pigments\transmitfx.pov and scenes\advanced\bwstripe.pov
Unfortunately, since POV-Ray 3.6, when using really high contrast, the
effects looks aliased even if antialias is used. This is because of the
controversial decision to make POV-Ray do clipping *after* antialiasing
rather than before. In POV-Ray 3.5 it looked perfect. However, you can
always render at a higher resolution and scale down.
Rune
http://runevision.com
Date: 17 Jul 2007 03:54:24
Message: <469c75b0$1@news.povray.org>
"Rune" <new### [at] runevisioncom> schreef in bericht
news:469b48f6$1@news.povray.org...
I think this is addressed in Megapov's Clip_Colors() if I am not mistaken.
Date: 17 Jul 2007 07:30:27
Message: <469ca853$1@news.povray.org>
Thomas de Groot wrote:
> "Rune" schreef in bericht:
>> the effects looks aliased even if antialias is used. This is because
>> of the controversial decision to make POV-Ray do clipping *after*
>> antialiasing rather than before. In POV-Ray 3.5 it looked perfect.
>> However, you can always render at a higher resolution and scale down.
> mistaken.
That's a workaround, but as far as I remember, the post-processing in
MegaPOV is rather slow. Or has that changed since I last used it?
Rune
Date: 17 Jul 2007 10:18:38
Message: <469ccfbe$1@news.povray.org>
news:469ca853$1@news.povray.org...
Well I am not sure. As far as I can tell this workaround does not seem
slower. However, I didn't test speed really.
Date: 17 Jul 2007 22:59:48
Message: <469d8224@news.povray.org>
Hey, thanks!
It's a reflective eye which has an outside surface with an ior of 1.33.
A simple gradient z for the sclera, radial for the iris.
Hmm, what do you know. I'll have to look at it.
> Rune
Gah, I don't know why it was changed!
Speaking of odd aa behavior, I don't even use +am1 anymore because of
the strange artifacts. Is that also due to post-clipping of averaged
samples? It's unfortunate, since method 2 is faster.... at least I think
it is.
~Sam
Date: 18 Jul 2007 05:36:31
Message: <469ddf1f$1@news.povray.org>
>> Rune
Thorsten (I believe it was) explained something along the lines that the
pixels in the raytraced image should simulate the light-sensitive cells in a
digital camera, which covers an area, but which can be over-exposed even if
just one small sub-pixel dot is really bright. In effect, it meant that you
can create a scene with stars in the sky that are much smaller than one
pixel but still show up if they are sufficiently bright.
This then is the justification for a feature that makes all very bright
things with sharp edges look jagged.
> samples?
Hmm, I don't know...
Rune
