POV-Ray : Newsgroups : povray.binaries.images : Making clothes in Poser - Take 5 Server Time
25 Dec 2025 21:44:13 EST (-0500)
  Making clothes in Poser - Take 5 (Message 1 to 10 of 38)
Subject: Making clothes in Poser - Take 5
Date: 24 May 2007 05:18:02
Message: <4655584a@news.povray.org>
Here is a piece of more complicated clothing: a pantaloon.
uv mapping is not easy. Note the stripes getting wider downwards. Not easy
to avoid that.
The t-shirt is a conforming prop from Poser. I note that conforming clothes
are much more difficult to move than dynamic clothes!! The underlying skin
tends to get through much more rapidly  :-(
Download 'Poser_figuretest_08b.jpg' (69 KB)
Preview of image 'Poser_figuretest_08b.jpg'
Subject: Re: Making clothes in Poser - Take 5
Date: 24 May 2007 06:40:35
Message: <46556ba3$1@news.povray.org>
news: 4655584a@news.povray.org...
> to avoid that.
> clothes are much more difficult to move than dynamic clothes!! The
> underlying skin tends to get through much more rapidly  :-(
> Thomas
Nice shaping :-)
For the uv_mapping problem couldn't you scale smaller the coordinates at the
wide part?
Marc
Date: 24 May 2007 07:15:01
Message: <web.465572442b96b31b3e3af320@news.povray.org>
> to avoid that.
> Thomas
Are you using conforming clothes as cloth? If so did you have problems
removing the end caps?
IIRC I could discard the skin parts of conforming clothes for
most of the ones that I tested. Also/or make them invisible and switch off
Date: 24 May 2007 07:22:24
Message: <46557570$1@news.povray.org>
"Marc" <jac### [at] wanadoofr> schreef in bericht
news:46556ba3$1@news.povray.org...
> Nice shaping :-)
Thanks Marc!
This figure is going eventually to
http://news.povray.org/povray.binaries.images/thread/%3C45097171%40news.povray.org%3E/?ttop=242333&mtop=232563&moff=20
which I shall revisit and update with new/better figures. It is going to be
a series called "Iskander the Sailor" (the name of this particular chap
here).
> the wide part?
Hmm... I am not sure I can do that in Silo 2.
As is, the problem is not too visible, but if I add a bump map for the
weave, it becomes really horrible.
Date: 24 May 2007 07:25:02
Message: <web.4655753e2b96b31b3e3af320@news.povray.org>
"Marc" <jac### [at] wanadoofr> wrote:
> Nice shaping :-)
> wide part?
If the stripes are getting wider due to the material stretching you might
get unpredictable results.
Also in RL pantaloons have inserts and darts to give them the ballooned
break in the pattern. Although it is perfect for testing, Rupert the bear
trousers might be better, IMHO.
http://en.wikipedia.org/wiki/Rupert_Bear
Date: 24 May 2007 07:36:07
Message: <465578a7$1@news.povray.org>
"Stephen" <mcavoys_AT_aolDOT.com> schreef in bericht
news:web.465572442b96b31b3e3af320@news.povray.org...
> So we are going to have a "Clothes Room" expert here, excellent!
> "Collide against".
He He!! Expert? Who knows? Anyway, I want to explore these avenues because
of the complex stories I have in mind. And it is worthwhile to know
'everything' about the programs you are using, isn't it?  :-)
I have to make the step between conforming and dynamic clothes yet. So I
guess I first have to export one, edit it in Silo (or Wings), and import it
again as dynamic clothing. Looks like an interesting experiment.
Yes indeed. I forgot that possibility to switch of the skin under the
conforming clothes. That would solve the problem indeed.
Date: 24 May 2007 07:49:46
Message: <46557bda$1@news.povray.org>
news:web.4655753e2b96b31b3e3af320@news.povray.org...
That is what happens in fact, as the mesh is stretched, thus stretching the
map.
> shape. That would make stripes an unsuitable design unless you don't mind
> a
There are breaks anyway along the seams (which you don't really see in this
particular image). In accordance with RL, I provided vertical seams along
the front and back, and along the inner and outer sides, thus making four
panels, that were then rotated and oriented as well as possible according to
the stripe pattern. Inserts and darts would be difficult to simulate/model I
believe.
Oh God! Dear old Rupert! Long time no see!!
His trousers would also show stretching, but maybe less visible? I shall
experiment.
Date: 24 May 2007 08:10:01
Message: <web.46557ef32b96b31b3e3af320@news.povray.org>
population is naked :-)
Maybe Janet might do the girlie thing, I bet she is a dab hand with the
pinking shears :-)
Careful, I did that at first and Poser made end caps that had to be removed.
For skirts the bottom end cap was located half way up the body. Giving the
OBJ an inside hem which I found very time consuming to delete. Without
retesting I think that it is better to convert the conforming clothes to
cloth in the Clothes Room. There are some restraints, I think that you
short term memory it was only a month or two ago :-)
Or remove it in a modeler.
Date: 24 May 2007 08:20:02
Message: <web.465582862b96b31b3e3af320@news.povray.org>
> map.
I thought that it looked like stretching. You will need to tweak the cloth
parameters. What does a square centimeter of cotton weigh?
> > a
> believe.
Hmm, impressive! It is little things like that, that add to the look.
Thinking about it. It might not be too difficult using subdivision for
for someone else to do :-)
> experiment.
Sad when you model things from your childhood.
Date: 24 May 2007 08:43:19
Message: <46558867$1@news.povray.org>
news:web.465582862b96b31b3e3af320@news.povray.org...
>> the
>> map.
What I mean is something different. The stretching does not happen in the
Cloth Room during the simulation, it is already there in the basic mesh
where the width of the faces at the bulges is wider than at the waist or at
the ankles. Now, this is a thought indeed. Maybe, if I could model the
pantaloon in such a way that more faces were produced at the bulges than at
waist or ankles.... Hmm... I'm not sure...
>> this
>> to
>> simulate/model I
>> believe.
> inserts and deleting lines and joining points for darts. But I'll leave it
It is knowledge of tayloring that is beginning to be needed in the first
place!
>> experiment.
<grin> As yet, I don't feel at all alzheimerish  :-)
