POV-Ray : Newsgroups : povray.binaries.images : Making clothes in Poser - Take 5 Server Time
1 Aug 2026 15:51:15 EDT (-0400)
  Making clothes in Poser - Take 5 (Message 9 to 18 of 38)
<<< Previous 8 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Making clothes in Poser - Take 5
Date: 24 May 2007 08:20:02
Message: <web.465582862b96b31b3e3af320@news.povray.org>
> "Stephen" <mcavoys_AT_aolDOT.com> schreef in bericht
> news:web.4655753e2b96b31b3e3af320@news.povray.org...
> > If the stripes are getting wider due to the material stretching you might
> > get unpredictable results.
> That is what happens in fact, as the mesh is stretched, thus stretching the
> map.
I thought that it looked like stretching. You will need to tweak the cloth
parameters. What does a square centimeter of cotton weigh?
> > Also in RL pantaloons have inserts and darts to give them the ballooned
> > shape. That would make stripes an unsuitable design unless you don't mind
> > a
> > break in the pattern.
> There are breaks anyway along the seams (which you don't really see in this
> particular image). In accordance with RL, I provided vertical seams along
> the front and back, and along the inner and outer sides, thus making four
> panels, that were then rotated and oriented as well as possible according to
> the stripe pattern. Inserts and darts would be difficult to simulate/model I
> believe.
Hmm, impressive! It is little things like that, that add to the look.
Thinking about it. It might not be too difficult using subdivision for
for someone else to do :-)
> Oh God! Dear old Rupert! Long time no see!!
> His trousers would also show stretching, but maybe less visible? I shall
> experiment.
Sad when you model things from your childhood.
Date: 24 May 2007 08:43:19
Message: <46558867$1@news.povray.org>
news:web.465582862b96b31b3e3af320@news.povray.org...
>> the
>> map.
What I mean is something different. The stretching does not happen in the
Cloth Room during the simulation, it is already there in the basic mesh
where the width of the faces at the bulges is wider than at the waist or at
the ankles. Now, this is a thought indeed. Maybe, if I could model the
pantaloon in such a way that more faces were produced at the bulges than at
waist or ankles.... Hmm... I'm not sure...
>> this
>> to
>> simulate/model I
>> believe.
> inserts and deleting lines and joining points for darts. But I'll leave it
It is knowledge of tayloring that is beginning to be needed in the first
place!
>> experiment.
<grin> As yet, I don't feel at all alzheimerish  :-)
Date: 24 May 2007 08:53:58
Message: <46558ae6@news.povray.org>
news:web.46557ef32b96b31b3e3af320@news.povray.org...
> "Thomas de Groot" <t.d### [at] internlDOTnet> wrote:
>> He He!! Expert? Who knows? Anyway, I want to explore these avenues
>> because
>> of the complex stories I have in mind. And it is worthwhile to know
>> 'everything' about the programs you are using, isn't it?  :-)
> You had better become one, because I've made myself sick of Poser clothes
> for a while. My current project doesn't need any because the world's
> population is naked :-)
Now, that is the easy way out!  :-)
> Maybe Janet might do the girlie thing, I bet she is a dab hand with the
> pinking shears :-)
I am really curious to see that!
>> I have to make the step between conforming and dynamic clothes yet. So I
>> guess I first have to export one, edit it in Silo (or Wings), and import
>> it
>> again as dynamic clothing. Looks like an interesting experiment.
> Careful, I did that at first and Poser made end caps that had to be
> removed.
> For skirts the bottom end cap was located half way up the body. Giving the
> OBJ an inside hem which I found very time consuming to delete. Without
> retesting I think that it is better to convert the conforming clothes to
> cloth in the Clothes Room. There are some restraints, I think that you
> might need to convert body parts separately. I think that I'm loosing my
> short term memory it was only a month or two ago :-)
Hm.. Have to be careful. See what I can do.
>> Yes indeed. I forgot that possibility to switch of the skin under the
>> conforming clothes. That would solve the problem indeed.
> Or remove it in a modeler.
Oh, yes, of course. Good idea.
Date: 24 May 2007 09:30:01
Message: <web.465592532b96b31c4e49fa40@news.povray.org>
principles, and it is all done in the best possible taste. :-)
> > pinking shears :-)
> >> it
> > removed.
I made things more difficult for myself than I needed to.
Date: 24 May 2007 09:40:02
Message: <web.465594df2b96b31c4e49fa40@news.povray.org>
> >> the
> >> map.
> the ankles.
I see, my misunderstanding.
[snip]
> place!
section to the inside seam of rectangular sections and draw in the hem.
> >> experiment.
<g>
Date: 24 May 2007 23:50:02
Message: <web.46565b6a2b96b31f07d58b80@news.povray.org>
I used to have pinking shears, a long time ago. :)
If the pants are seamed as real pants are, you can try to create the UV map
as 4 pieces and also minimize any deformation of the mesh when its
flattened out to the UV map. Thinking of it as pants pieces you will sew
together is a good way of approaching it. I know I am a Blender fan, but,
really, Blender has some great UV mapping options.
As for skin poking through, I know Poser magnets can be used to pull the
clothing out a bit. But, I never quite got the hang of those magnets.
Eliminating the body part is fast and easy, if its that simple. But
sometimes its not.
Poser 7 has a morphing tool you could use to get rid of "poke through", and
also modify the figure, check out:
http://www.renderosity.com/news.php?viewStory=13544
You can also do this sort of thing in a 3D modeller. Ha, ha like Blender! :)
Cheers, Janet
Date: 25 May 2007 03:21:00
Message: <46568e5c@news.povray.org>
news:web.465594df2b96b31c4e49fa40@news.povray.org...
>> place!
> From my memory of the 70's flares; Stitch (insert and join) a triangular
Yes, but will a modeller with uv mapping give the same result?
There is a work around that I have just started testing and which might be
the answer. I am adding vertical seams through those parts that widen
towards the bulges, from the top and from the bottom. This way, the cloth
panels are flattened out much more with less distortion as a result. Look at
the two highlighted panels to the left on the attached image, to see what I
have started to do in the ankle area.
Download 'SiloScreenShot.jpg' (313 KB)
Preview of image 'SiloScreenShot.jpg'
Date: 25 May 2007 03:40:37
Message: <465692f5$1@news.povray.org>
"Janet" <par### [at] attnet> schreef in bericht
news:web.46565b6a2b96b31f07d58b80@news.povray.org...
> map
Well, what do you think of Silo (see the screenshot in my answer to Stephen,
above)?  :-)
However, I think that the RL approach and the modelling approach are
necessarily different. What no modeller like Wings or Silo can do (correct
me if Blender is different from this) is to deform a mesh, keeping the same
net surface area. You always scale the mesh one way or another by bending,
translating, or rotating vertexes, edges or whole surfaces. In RL this only
happens with really stretch-prone materials like spandex.
> sometimes its not.
Ah yes, magnets. Still have to learn to use those. Thanks for reminding me
Janet!
> and
Another tool I have yet to learn to use!!
You really like to rub in the salt, don't you?  :-)
Date: 25 May 2007 07:15:02
Message: <web.4656c4a22b96b31c4e49fa40@news.povray.org>
an old copy of UV Mapper somewhere.
Date: 25 May 2007 07:20:02
Message: <web.4656c5562b96b31c4e49fa40@news.povray.org>
> sometimes its not.
There is a lot in Poser if you can get it to work.
