POV-Ray : Newsgroups : povray.binaries.images : Wood screws Server Time
1 Aug 2026 12:56:30 EDT (-0400)
  Wood screws (Message 11 to 20 of 21)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: Wood screws
Date: 14 May 2007 12:58:28
Message: <46489534$1@news.povray.org>
Alain wrote:
> The slot's depth is typical for that king of screw, I ocasionaly find
> myself using a metal saw on those slots. I prefer robertson screw heads:
> no sliding (like slot heads) and no poping off (like phillips heads).
Torx is also one great beast of grip.
http://www.daviddarling.info/images/screw_heads.gif
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 14 May 2007 22:37:25
Message: <46491ce5$1@news.povray.org>
Eero Ahonen nous apporta ses lumieres en ce 14 / 05 / 2007 12:58:
I agree with you on that point, you can put more tork with torx screws. But
robertson is beter for "ordinary" every-days use, while torx is more oriented
toward technical uses. At least, here in Canada.
Date: 15 May 2007 00:38:29
Message: <46493945$1@news.povray.org>
> But robertson is beter for "ordinary" every-days use, while torx is more
> oriented toward technical uses. At least, here in Canada.
I can imagine Robertson as practical, but unfortunately it's damn rare
here, so I can't know for sure. Robertson is easier to make than torx
and for Robertson you can make a perfect key by yourself (well, you
_can_ for torx too, but it's not so trivial).
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 15 May 2007 03:49:56
Message: <46496624$1@news.povray.org>
"Eero Ahonen" <aer### [at] removethiszbxtnetinvalid> schreef in bericht
news:46493945$1@news.povray.org...
Never saw it in my place, to tell the truth. First time I even heard about
it! So, it may be inexistant here...
Date: 15 May 2007 03:57:30
Message: <464967ea@news.povray.org>
news: 46496624$1@news.povray.org...
> Thomas
Here the most common for wood screws is 'posidriv' , an enhancement of
phillips, secure if you use the good size key
Marc
Date: 15 May 2007 07:50:01
Message: <web.46499e1fc076759ab3e3af320@news.povray.org>
> Nice, Warp! My only critisism would be that the slots have very little
> depth to take a flat-blade, maybe a touch more depth would do it.
Alan screws for metal (nothing wrong with a bent bit of metal :-).
Date: 15 May 2007 10:37:56
Message: <4649c5c4$1@news.povray.org>
Yes, but only to certain limit. Pozidriv won't be delivering even near
the torque torx does easily. The reason is also simple, while torx's
head is flat when looked from the side:
Pozidriv:
Torx:
My ASCII is hidious, but if someone doesn't understand, I'll continue
with a photo :).
> Marc
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 15 May 2007 16:23:27
Message: <464a16bf$1@news.povray.org>
news: 4649c5c4$1@news.povray.org...
I agree but you don't want to give too much torque to a wood screw :-)
Marc
Date: 15 May 2007 17:17:14
Message: <464a235a@news.povray.org>
Depends. I've had problems with pz's when the wood is really tight. But
generally, yes, usually the situation is as you said ;).
> Marc
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 17 May 2007 10:20:01
Message: <web.464c641bc076759ac150d4c10@news.povray.org>
> Thomas
Yes, a Canadian invention and arguably one of the best screwdriver types
that never got the international (or at least American) exposure it perhaps
deserves.
http://en.wikipedia.org/wiki/Robertson_screwdriver
It is one of the most common used here in Canada for everything from wood
screws to metal screws.
However they can strip hideously if you use the wrong size head or don't
seat it well as I found out quite often while building my deck...
-tgq
