POV-Ray : Newsgroups : povray.binaries.images : Making clothes in Poser - Take 1 Server Time
1 Aug 2026 15:41:06 EDT (-0400)
  Making clothes in Poser - Take 1 (Message 21 to 22 of 22)
Subject: Re: Making clothes in Poser - Take 2
Date: 3 May 2007 08:05:42
Message: <4639d016$1@news.povray.org>
"Stephen" <mcavoysATaolDOTcom@> schreef in bericht
news:3vog33pkg90aiilummgoeigiaff1e82po8@4ax.com...
> On Wed, 2 May 2007 11:32:02 +0200, "Thomas de Groot"
> <t.d### [at] internlDOTnet>
> wrote:
>>What I am still puzzled about is saving as dynamic cloth. That works - I
>>think - but loading it again doesn't show anything...
> What do you mean? "loading it again doesn't show anything."
> Show what?
Well, I thought that saving in Poser as a dynamic cloth, you could load it
again another time with all its characteristics, but what really happens
then is that a green cross appears, but no object, nor does the recalculate
dynamics work then. Oh well, I think I have to read the manual more
carefully...
> I have been saving (exporting) the objects as OBJ's. Remember that you
> have to
> export as multi-frame with the range 30 to 30. Where 30 is the number of
> frames
> in the animation. You loose the dynamic groups but I generally used
> materials
> for grouping.
Yes, usually I do that (although not multi-frame as yet). Still part of my
future experimentations.
> When the cloth folds in on itself don't be afraid to use a high number of
> steps
> per frame. For some of the dresses I tried I went as high as 80 and often
> used
> 60 steps per frame with an offset of 0.1
Yes, that is certainly true! I went as high as 10 till now, but just for
experimental purposes. I also noticed that the number of draping frames is
very important for the quality of the folding. I am going to increase that
too.
Date: 3 May 2007 10:03:50
Message: <onqj33d6nicjd72hpngnj2k701gdn4f44q@4ax.com>
On Thu, 3 May 2007 14:05:41 +0200, "Thomas de Groot" <t.d### [at] internlDOTnet>
>carefully...
Green Cross?
I tried it out and I can save my dress as a Prop. It is saved with an image but
in the "Zero" position. It does keep the clothing groups. I did it by selecting
the skirt opening the props menu and pressing the + sign. In the Set Name pop
up, change the text, press Select subset, then select the prop and OK. Click OK
and it was saved with the preview image.
>> have to
>> frames
>> materials
>> for grouping.
I've tried to cut out the start from zero pose.
>> steps
>> used
>too.
Minimum draping frames 20, I've found. You have a super duper machine I'm sure
it's fast :-)
Regards
