POV-Ray : Newsgroups : povray.binaries.images : Making clothes in Poser - Take 1 Server Time
1 Aug 2026 14:13:40 EDT (-0400)
  Making clothes in Poser - Take 1 (Message 13 to 22 of 22)
Subject: Re: Making clothes in Poser - Take 1
Date: 1 May 2007 03:40:36
Message: <4636eef4$1@news.povray.org>
"Mike Williams" <nos### [at] econymdemoncouk> schreef in bericht
news:vKM### [at] econymdemoncouk...
> It's more complicated than my first poser dynamic clothes attempt, back
> in 2002 (well, at least the first where the material actually stayed on
> the body).
> http://www.econym.demon.co.uk/pictures/laceface.jpg
Well that looks very good, Mike!
I suppose that Poser has become better since 2002, I don't know. I am fairly
new to it. This was relatively easy to do after a couple of trial and
errors, and reading the manual of course :-)  This particular example is
working in a similar way to the tablecloth utility in Megapov.
Date: 1 May 2007 04:35:01
Message: <1tud331ck3pd4ukegner9s9ftsq2atf2rf@4ax.com>
On Tue, 1 May 2007 07:18:34 +0100, Mike Williams <nos### [at] econymdemoncouk>
>the body).
LOL
Regards
Date: 1 May 2007 04:54:38
Message: <4637004e@news.povray.org>
"St." <dot### [at] dotcom> schreef in bericht news:46360f32@news.povray.org...
>   Great work! Now he needs a cheroot, a six-gun, and a mule.
>   Oh yes, and a wrinkled squint look...    ;)
>      ~Steve~
Here you are!!
Download 'PoserFiguretest.jpg' (56 KB)
Preview of image 'PoserFiguretest.jpg'
Date: 1 May 2007 09:14:46
Message: <o8fe3395id1la5v997tpvgifdhhacnom8v@4ax.com>
On Tue, 1 May 2007 10:54:35 +0200, "Thomas de Groot" <t.d### [at] internlDOTnet> wrote:
>Here you are!!
But, where's his cowboy hat?!?  :-p
Date: 1 May 2007 10:47:55
Message: <4637531b$1@news.povray.org>
"Kyle" <hob### [at] gatenet> schreef in bericht
news:o8fe3395id1la5v997tpvgifdhhacnom8v@4ax.com...
>>Here you are!!
Yeah... I know! He lost it! It was shot from his head probably.
Date: 1 May 2007 13:00:49
Message: <46377241@news.povray.org>
"Thomas de Groot" <t.d### [at] internlDOTnet> wrote in message
news:4637004e@news.povray.org...
> Here you are!!
 LOL! Thank you Thomas!   :o)
   ~Steve~
> Thomas
Subject: Re: Making clothes in Poser - Take 2
Date: 2 May 2007 05:32:05
Message: <46385a95@news.povray.org>
Even with a simple poncho, there is much to learn!!
This is a much better version.
I edited the poncho itself first of all, making it narrower (Argentinan vs.
Chilean, from my own experience).
The trials are now about better draping and binding the cloth to the figure
while changing the pose. So far so good.
What I am still puzzled about is saving as dynamic cloth. That works - I
think - but loading it again doesn't show anything...
Back to the drawing board....
Download 'PoserFiguretest.jpg' (48 KB)
Date: 2 May 2007 06:21:25
Message: <3vog33pkg90aiilummgoeigiaff1e82po8@4ax.com>
On Wed, 2 May 2007 11:32:02 +0200, "Thomas de Groot" <t.d### [at] internlDOTnet>
What do you mean? "loading it again doesn't show anything."
Show what?
I have been saving (exporting) the objects as OBJ's. Remember that you have to
export as multi-frame with the range 30 to 30. Where 30 is the number of frames
in the animation. You loose the dynamic groups but I generally used materials
for grouping.
When the cloth folds in on itself don't be afraid to use a high number of steps
per frame. For some of the dresses I tried I went as high as 80 and often used
60 steps per frame with an offset of 0.1
Regards
Date: 3 May 2007 08:05:42
Message: <4639d016$1@news.povray.org>
"Stephen" <mcavoysATaolDOTcom@> schreef in bericht
news:3vog33pkg90aiilummgoeigiaff1e82po8@4ax.com...
> Show what?
Well, I thought that saving in Poser as a dynamic cloth, you could load it
again another time with all its characteristics, but what really happens
then is that a green cross appears, but no object, nor does the recalculate
dynamics work then. Oh well, I think I have to read the manual more
carefully...
> have to
> frames
> materials
> for grouping.
Yes, usually I do that (although not multi-frame as yet). Still part of my
future experimentations.
> steps
> used
Yes, that is certainly true! I went as high as 10 till now, but just for
experimental purposes. I also noticed that the number of draping frames is
very important for the quality of the folding. I am going to increase that
too.
Date: 3 May 2007 10:03:50
Message: <onqj33d6nicjd72hpngnj2k701gdn4f44q@4ax.com>
On Thu, 3 May 2007 14:05:41 +0200, "Thomas de Groot" <t.d### [at] internlDOTnet>
>carefully...
Green Cross?
I tried it out and I can save my dress as a Prop. It is saved with an image but
in the "Zero" position. It does keep the clothing groups. I did it by selecting
the skirt opening the props menu and pressing the + sign. In the Set Name pop
up, change the text, press Select subset, then select the prop and OK. Click OK
and it was saved with the preview image.
>> have to
>> frames
>> materials
>> for grouping.
I've tried to cut out the start from zero pose.
>> steps
>> used
>too.
Minimum draping frames 20, I've found. You have a super duper machine I'm sure
it's fast :-)
Regards
