POV-Ray : Newsgroups : povray.binaries.images : YARSOCP Server Time
1 Aug 2026 17:04:47 EDT (-0400)
  YARSOCP (Message 31 to 40 of 43)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: YARSOCP
Date: 15 Apr 2007 12:09:15
Message: <nkc9f4-3o7.ln1@badulaque.unex.es>
Among other things, Darren New saw fit to write:
> Except that back-scattering off the atmosphere provides a much larger
> area of light. Contrast the sky with the moon vs the sun, both of which
> are about the same size. It's difficult to even look close to the sun on
> a clear day.
So similar are their sizes, indeed, that we can experience both total and
anular eclipses... I find that amazing.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 15 Apr 2007 12:18:46
Message: <46225066$1@news.povray.org>
Tek wrote:
> The reason it's hard to look at the sun is it's brighter than the moon.
Right. I meant, it's difficult to even look within about 5 degrees of
the sun. I think the disk that's projecting light is a lot larger than
0.5%. Of course, in POV you have to do things somewhat differently to
get the same effect.
     His kernel fu is strong.
     He studied at the Shao Linux Temple.
Date: 15 Apr 2007 13:06:33
Message: <46225b99$1@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:46225066$1@news.povray.org...
> Right. I meant, it's difficult to even look within about 5 degrees of the
> sun. I think the disk that's projecting light is a lot larger than 0.5%.
> Of course, in POV you have to do things somewhat differently to get the
> same effect.
I'm not sure I follow. The sun's disk is 5 degrees in radius from earth, the
brightness of it doesn't make it any larger (like I say you can use a filter
to see that all the suns direct light comes from that disk). Povray can
simulate a circular area light of the same angle and brightness. The only
reason I'm using a larger one is because I'm taking some artistic license,
in truth a small ball on a table would have an almost perfectly sharp
shadow.
Tek
http://evilsuperbrain.com
Date: 15 Apr 2007 15:05:59
Message: <46227797@news.povray.org>
The sun might appear as a larger apparent "disk" of brightness
due to directional scattering in the atmosphere. In fact, compare
the two attached WIP images. The sun really appears quite small
in the version without scattering (and that was already 4 times
larger than physically correct).
Download 'beach-320.jpg' (10 KB) Download 'beach-scatter-320.jpg' (10 KB)
Preview of image 'beach-320.jpg'
Preview of image 'beach-scatter-320.jpg'
Date: 15 Apr 2007 21:30:42
Message: <4622D1C7.4080709@die.spammer.die.isite.net.au>
Tek wrote:
> Any suggestions on how I can make this more real?
I think my biggest problem is the reflection in the sphere is perfectly
focused, but then so is the sphere itself. With a short focal length,
only one should be in focus as you're either focused the (very short)
distance to the sphere, or the (very long) distance to the trees behind you.
Cheers!
Rick Measham
Date: 15 Apr 2007 23:34:55
Message: <4622eedf@news.povray.org>
Actually because it's a curved reflective surface the reflection will tend
to appear very sharp. What you said is certainly true of flat mirrors but
the distortion in a convex mirror makes the image appear sharp (because the
image appears much smaller than in a flat mirror, so the blur is relatively
unnoticeable).
Here's a great example google image search found:
http://colourblind.ca/images/20050807233841_shiny_sphere.jpg
You'll notice the background is blurry but both the ball & reflection appear
sharp.
In any case, I'm using focal blur when rendering now, and pov's simulation
is good enough to accurately apply focal blur to reflections.
Tek
"Rick Measham" <ric### [at] diespammerdieisitenetau> wrote in message
news:462### [at] diespammerdieisitenetau...
> focused, but then so is the sphere itself. With a short focal length, only
> one should be in focus as you're either focused the (very short) distance
> Cheers!
> Rick Measham
Date: 16 Apr 2007 03:10:25
Message: <46232161$1@news.povray.org>
"Jellby" <me### [at] privacynet> schreef in bericht
news:nkc### [at] badulaqueunexes...
>> a clear day.
It is one of those random chances that nature offers us  :-)
If I am correct, we are also at the right time too, while the Moon is slowly
receding. So there might come a moment when only anular eclipses will happen
I believe. The astronomers among us can tell.
Date: 16 Apr 2007 03:39:24
Message: <4623282C.2020002@die.spammer.die.isite.net.au>
> unnoticeable).
Bah! I sat here thinking about it before I posted that. Decided I was
right and hit the "Send" button. Now I regret it. Of course you're right.
Cheers!
Rick Measham
Date: 16 Apr 2007 17:12:49
Message: <4623e6d1$1@news.povray.org>
Tek nous apporta ses lumieres en ce 15-04-2007 13:09:
>> same effect.
> shadow.
The Sun's real apparent radius is 0.5 degrees. It's extreem brightness does make
it look much larger, as even with a very small amount of scettering, that
scattered light is still blinding.
I can read your mind, and you should be ashamed of yourself.
Date: 16 Apr 2007 17:26:27
Message: <4623ea03$1@news.povray.org>
Nonetheless we're not discussing how it looks, rather how to simulate it
with an area_light. The majority of the light comes from the sun itself, not
the scattering (since if you look at the sun through a filter you can see
it's disk clearly), hence I'm using a lightsource to simulate the sun and
radiosity from the HDR dome to simulate scattered light from the sky.
Tek
"Alain" <ele### [at] netscapenet> wrote in message
news:4623e6d1$1@news.povray.org...
>> the brightness of it doesn't make it any larger (like I say you can use a
>> filter to see that all the suns direct light comes from that disk).
>> Povray can simulate a circular area light of the same angle and
>> brightness. The only reason I'm using a larger one is because I'm taking
>> some artistic license, in truth a small ball on a table would have an
>> almost perfectly sharp shadow.
> does make it look much larger, as even with a very small amount of
> scettering, that scattered light is still blinding.
> Alain
