POV-Ray : Newsgroups : povray.binaries.images : YARSOCP Server Time
1 Aug 2026 17:04:46 EDT (-0400)
  YARSOCP (Message 14 to 23 of 43)
Subject: Re: YARSOCP
Date: 14 Apr 2007 04:31:47
Message: <46209173$1@news.povray.org>
I like it!
Florian
Date: 14 Apr 2007 07:09:43
Message: <4620b677@news.povray.org>
Here's a version with some camera effects (subtle vignetting and
dispersion), improved anti-aliasing (actually rendered at 1600x1200 and
resized), an area_light, and a redesigned chess board.
The vignetting should help vary the colours across the image, so hopefully
those green specks will look better now.
Tek
http://evilsuperbrain.com
"Sabrina Kilian" <"ykgp <at> wrote in message
news:462052bc$1@news.povray.org...
> Tek wrote:
>> "Sabrina Kilian" <ykg### [at] vtedu> wrote in message
>> news:461fea7c$1@news.povray.org...
>>> Lastly, the table edge itself. I love the pigment, it looks just like
>>> the composite stone I would expect to find in a park. My eyes say that
>>> each chip in the stone seems too flat. I would suggest normals, but it's
>>> the shadow that gives it away. The shadow of the board on the lower
>>> right looks too crisp as it passes over each little chip. Similerly, the
>>> green on the far top right looks just as bright as the near green
>>> specks, something I wouldn't expect looking at that table. The little
>>> bit of lens effects you mentioned might take care of all of that without
>>> resorting to anything more complecated.
>> The table actually has a reflective sheen, though it's not obvious at
>> this
>> angle, so it's supposed to be composite stone polished to a very smooth
>> finish. In any case I've added an area light which has now slightly
>> softened
>> the edge of the shade so that should fix the problem. Do you think the
>> green
>> specks are too bright or too dark? I put them in at the last minute and
>> I'm
>> not sure I like them!
> You are right, the table looked matte almost and the sheen did not show
> up like it did for the chess board. I'm not used to seeing composite
> stone brand new, so I was expecting the small pieces to be slightly
> varied in height or angle which would break up the near side's shadow.
> With the sheen being more obvious, or the shadow being softer, I think
> it will look great.
> I don't think the green specks are too bright or dark, I just can't
> reconcile that the chips on the top right look to be almost the same
> color as the ones on the nearest edge. It looks great on the near edge,
> but it seems too colorful on the far edge.
> All of this could be because I am picturing how this would look from a
> camera up close with a wide angle lens, not a far off zoom. I'll put a
> marble on my desk again, and find a telephoto lens, and see what I think
> then.
>>> I linked the picture to a friend, fellow computer geek but not into
>>> graphics. His response was, 'wow, wait, that's not real?' Personally,
>>> I'd want this as a desktop, or a poster as is. I can't wait to see it
>>> when you are finished.
>> Thanks for your comments!
> And thank you for another wonderful picture.
Download 'before+after.1-pp.jpg' (103 KB)
Preview of image 'before+after.1-pp.jpg'
Date: 14 Apr 2007 07:39:37
Message: <4620bd79$1@news.povray.org>
You should be forbidden to post such excellent wip images!!!  :-)
Date: 14 Apr 2007 09:25:12
Message: <4620d638$1@news.povray.org>
Hash: SHA1
	There's a problem with your photograph: it was taken by the
Invisible Man! Otherwise, he should be visible in the reflection on
the sphere ;)
		Jerome
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (GNU/Linux)
iD8DBQFGINY4d0kWM4JG3k8RApcGAJ9ekXG8sTpGNi7eWgKGDMSHulY0CQCfVwTB
eI2yZBYZPlxFw6AnwBOvzhA=
=pPWH
-----END PGP SIGNATURE-----
Date: 14 Apr 2007 10:19:26
Message: <4620e2ee$1@news.povray.org>
Nice. However, I think the black border around the board looks
a bit artificial. Maybe there should be just a groove centered
in the white border. Also, the board seems to be too perfectly
aligned with the table.
Date: 14 Apr 2007 12:43:18
Message: <462104a6$1@news.povray.org>
I am thinking of cheekily building a cameraman to be in the reflection!
Tek
news:4620d638$1@news.povray.org...
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> the sphere ;)
> Jerome
> =pPWH
Date: 14 Apr 2007 12:45:32
Message: <4621052c@news.povray.org>
"Christian Froeschlin" <chr### [at] chrfrde> wrote in message
news:4620e2ee$1@news.povray.org...
2 good points. I can't make my mind up about the border so I'll try some
variations. The alignment to the table is perfect because I havent decided
if the board is built into the table or not. Though I think it's not (since
it looks like an expensive marble board on a cheap stone table) so I'll
shift the positions a little.
Very useful comments, thanks!
Tek
Date: 14 Apr 2007 13:39:50
Message: <462111e6@news.povray.org>
> then.
Hmm... my camera might not be as zoomed as I thought, here's a render with
blur from a 35mm aperture. It's easily enough to tie the background to the
foreground.
But I think it's too blurry, so I'm gonna build some background objects.
Tek
Download 'before+after.1-pp.jpg' (85 KB)
Date: 14 Apr 2007 14:34:12
Message: <46211ea4$1@news.povray.org>
Fantastic image Tek! However, I think the border should be wider? If you
think of 1/2"...
     ~Steve~
Date: 14 Apr 2007 18:31:13
Message: <46215631$1@news.povray.org>
Maybe you are taking photorealism too far. If it's to blurry,
why don't you just reduce the blur? Just think of the number
of blur_samples you'll need to make this look good anyway ;)
I suppose camera manufacturers would happily build cameras which show
less blur if they could (well, in fact you can take multiple images
with different focus and combine them in software).
