POV-Ray : Newsgroups : povray.binaries.images : Ivy Generator updated Server Time
1 Aug 2026 15:41:07 EDT (-0400)
  Ivy Generator updated (Message 11 to 20 of 20)
Subject: Re: Ivy Generator updated
Date: 26 Mar 2007 17:02:13
Message: <460842e5$1@news.povray.org>
> Tim, what do you mean exactly by 'transmit overloading'? After editing,
> also commenting out the pigment{Clear}, the texture should look like
> this', shouldn't it?
After converting with PoseRay the pigments look like this...
#declare p_map1=pigment {uv_mapping image_map{
 png "E:\graphics\ivy_gen\textures\efeu1.png"
 interpolate 2 transmit all 0 filter all 0} }
but they should look like this ... flipped over ... without
the transmit all...
   }rotate<0,0,180>}
and the layered material looks like this ...
#declare leaf_adult_=
material{
texture{pigment {color rgb <1,1,1> transmit  0}
        finish{phong 0.2980392 phong_size 36.25229 diffuse 0.6*1
        ambient rgb <0,0,0> reflection{0 metallic}}}
texture{pigment{p_map1}
        finish{ phong 0.2980392 phong_size 36.25229 diffuse 0.6*1
but can be simply
#declare leaf_adult_=  material{
the transparency info is already in the PNG
Date: 27 Mar 2007 02:41:13
Message: <4608ca99@news.povray.org>
Ah yes, I see! That makes indeed a big difference. I never realized that
transmit all and/or filter all slowed down the render. The layered texture I
knew, but I had included a transparency map. However, that is not necessary
of course as the transparency is already in the png. I hadn't thought the
thing entirely through apparently  :-)
So, Poseray is doing a thorough job, but much overdone in this case!!
Thank you Tim! I again learned new stuff!
Date: 27 Mar 2007 06:38:54
Message: <4609024e@news.povray.org>
There still is a problem that under certain conditions, the transparent
support becomes visible...
Download 'GrowingIvyTest.jpg' (98 KB)
Preview of image 'GrowingIvyTest.jpg'
Date: 27 Mar 2007 06:45:11
Message: <460903c7$1@news.povray.org>
OK. Solution to that one: delete the finish{}, especially specular and/or
phong.
Date: 27 Mar 2007 06:47:53
Message: <46090469@news.povray.org>
"Thomas de Groot" <t.d### [at] internlDOTnet> wrote in message
news:4609024e@news.povray.org...
     Ah! I was getting this Thomas! I thought it was because I was using
media in the scene as when I turned media off, it worked fine. Hmm, strange.
      ~Steve~
> Thomas
Date: 27 Mar 2007 07:02:36
Message: <460907dc$1@news.povray.org>
"St." <dot### [at] dotcom> schreef in bericht news:46090469@news.povray.org...
> strange.
The problem appears because the material is not a texture_map anymore. So
the transparent part normally invisble by the alpha channel of the image,
becomes visible because of the finish{} specular or phong. So the best thing
to do is comment out the finish{}.
However, I had the problem also with the texture_map in place....
Date: 27 Mar 2007 07:22:59
Message: <46090ca3$1@news.povray.org>
Before I forget: because these are image_maps, it is still smart to use a
finish{diffuse 0.8} to brighten up the leaves. Is a good thing to do anyway
for all image_maps in general.
Date: 27 Mar 2007 07:29:19
Message: <46090e1f@news.povray.org>
news: 46090ca3$1@news.povray.org...
> anyway for all image_maps in general.
> Thomas
Oh yes I forgot that even if I often use higher diffuse values with
image_maps.
Thank you again Thomas :-)
Marc
Date: 27 Mar 2007 09:32:07
Message: <46092ae7@news.povray.org>
"Marc" <jac### [at] wanadoofr> schreef in bericht
news:46090e1f@news.povray.org...
> image_maps.
<grin>
Especially as it was you that brought this to the community's attention,
years ago  :-)
Date: 27 Mar 2007 15:23:52
Message: <46097d58$1@news.povray.org>
news: 46092ae7@news.povray.org...
> <grin>
> years ago  :-)
> Thomas
Really?
Oh years ago, I had a good memory at this time  :-)
No seriousely, when I make my own image_map I  think of it but those were
ready made :-)
Marc
