POV-Ray : Newsgroups : povray.binaries.images : Sparkling water Server Time
1 Aug 2026 17:56:04 EDT (-0400)
  Sparkling water (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Sparkling water
Date: 13 Feb 2007 14:57:10
Message: <45d21816@news.povray.org>
Christian Froeschlin wrote:
> Hmm ... I just realized that my transmit and reflection added up to
> slightly more than 1,
POV-Ray can deal with this for you.  Add the "conserve_energy" keyword
to your finish statement, and POV will adjust the transmitted light
according to the amount that is reflected.
...Chambers
Date: 13 Feb 2007 18:00:18
Message: <45d24302$1@news.povray.org>
Sounds useful, thank you for the pointer.
Date: 13 Feb 2007 20:44:03
Message: <45d26963@news.povray.org>
Don't forget, you are now obligated to post another render featuring
this trick so we can see how it really affects things :)
Or else we'll send the RSCops to hunt you down and force you to do all
of your future renders on a TI calculator!
...Chambers
Date: 14 Feb 2007 03:56:42
Message: <45d2ceca$1@news.povray.org>
"Ben Chambers" <ben### [at] pacificwebguycom> schreef in bericht
news:45d26963@news.povray.org...
> Don't forget, you are now obligated to post another render featuring this
> Or else we'll send the RSCops to hunt you down and force you to do all of
Yeah! Yeah!
Or worse yet, on an abacus!
Date: 14 Feb 2007 18:37:33
Message: <45d39d3d$1@news.povray.org>
That's blackmail!
But seriously, I tried it and posting that render is unnecessary.
As was to be expected from the documentation of conserve_energy,
the render result of
"pigment {color rgbt 1} finish {reflection 0.1 conserve_energy}"
turned out absolutely identical to my previous manual fix of
"pigment {color rgbt 0.9} finish {reflection 0.1}",
excepting, of course, the random jitter.
Date: 14 Feb 2007 19:47:22
Message: <45d3ad9a$1@news.povray.org>
As I understand it, it shouldn't be *exactly* identical, because the
adjustment is done on a per-pixel basis, and the adjustment is varied
based on the amount of light being reflected.
However, in this case, we probably couldn't tell the difference anyway :)
...Chambers
Date: 14 Feb 2007 20:49:01
Message: <45d3bc0d@news.povray.org>
Christian Froeschlin nous apporta ses lumieres en ce 14-02-2007 18:40:
> That's blackmail!
It's more usefull when you have variable reflection like reflection{0, 1} where
you just can't do a manual balancing.
Date: 15 Feb 2007 00:25:23
Message: <45d3eec2@news.povray.org>
> Hello,
> I just experimented a bit with glass, water and photons. For making
> a glass filled with water, the documentation recommends to make a
> hollow container using CSG, and filling it with a liquid object
> scaled down a bit to avoid coincident surfaces. I'm a bit unsure
> about this, as the extra transitions through a thin air slice would
> seem to cause unnecessary calculations, and yield incorrect results
> as well (e.g., I think it is possible that the expected refraction
> at a water/glass transition turns into a total internal reflection
> at a water/air transition). A problem like this was discussed some
> time ago in povray.newusers regarding "Refraction in the eye":
> So, I made three images:
> 1. Uses the recommended technique
> 2. Embeds the liquid in a solid glass block (in the hope that
>     the IOR specified in the second object takes precedence)
> 3. Is a variation of 1., with the liquid scaled *up* a tiny
>     bit and the "merge"-d with the glass container to remove
>     the inner surface (but no idea how POV-Ray handles the
>     differing IORs in a merge).
If my reading of the source is correct, #2 will do *almost* the right thing.
What should produce correct results is scaling the water slightly larger
than the hollow of the glass:
   1     2           3     4           5     6
air|glass|water+glass|water|water+glass|glass|air
What should happen is:
1: The ray exits the air, enters the glass
2: The ray exits the glass, enters the water
3: The ray has already left the glass, so this is ignored for refraction
4: The ray exits the water, enters the glass
5: The ray has already left the water, so this is ignored for refraction
6: The ray exits the glass, enters the air
The first glass-water transition will be slightly nearer the camera than it
should be, but otherwise this is correct.  The proper number of refractions
will take place, and they will all have correct IORs.
Mark Wagner
Date: 17 Feb 2007 15:50:37
Message: <45d76a9d@news.povray.org>
Actually, I tried that first, but it reduced render speed so much
I thought there must be a lot of reflection or similar going on
between those two surfaces, so i tried to merge the internal
surface away (hence test #3).
I just ran a non-anti-aliased render of your suggestion which still
runs in bearable time. The result actually looks almost identical to
the classic "smaller" scaling, except for some differences with light
on the lemon and its reflection at the other side of the glass.
Note this picture uses the old "incorrect" finish without
of my original post.
Download 'bubbles-800-noaa-scaleplus-nomerge.jpg' (22 KB)
Preview of image 'bubbles-800-noaa-scaleplus-nomerge.jpg'
Date: 18 Feb 2007 03:10:22
Message: <45d809ee@news.povray.org>
I don't know about you others, folks, to me this looks simply great! :-)
