POV-Ray : Newsgroups : povray.binaries.images : Balance wheel (WIP 2) Server Time
10 Sep 2025 03:45:41 EDT (-0400)
  Balance wheel (WIP 2) (Message 1 to 3 of 3)
Subject: Balance wheel (WIP 2)
Date: 6 Feb 2007 16:57:43
Message: <45c8f9d7@news.povray.org>
Addes a few more details to my balance wheel:  An escapement anchor with
jewels and an escapement wheel.
Oslo, Norway
Download 'balancewheel_3.jpg' (459 KB)
Preview of image 'balancewheel_3.jpg'
Subject: Re: Balance wheel (WIP 2)
Date: 9 Feb 2007 17:20:39
Message: <45ccf3b7$1@news.povray.org>
Nice work on the modelling. CSG?
I see you are zeroing in on the textures also.  It seems these metals on
the internal workings are polished or honed to a high reflectivity?  We
would see that more as you know if there is a background to reflect.
Cool graph paper especially if you are generating it procedurally.  Not
sure it shows off this piece to best advantage though.
We always love to see the development of a meticulously crafted
depiction of a work of meticulous craftmanship here.
Date: 10 Feb 2007 17:37:06
Message: <45ce4912@news.povray.org>
I used Inkscape to create the anchor.  I made the anchor by drawing
bezier lines on top of an image of a real anchor.  When completed, I
exported the bezier lines with the pov-export feature in Inkscape.
The escapement gear was only partially made in Inkscape.  I used the
same procedure as described above, but only for one tooth.  The object
is then duplicated and rotated 15 times in a macro, to form the gear.
The texture of the graph paper:
#declare P_Lines =
     gradient x
     color_map {
       [0.0             color rgbf <1, 1, 1, 1.0>]
       [0.0             color rgbf <0.5, 0.5, 1, 0.0>]
       [0.02            color rgbf <0.5, 0.5, 1, 0.0>]
       [0.02            color rgbf <1, 1, 1, 1.0>]
       #declare N = 0.1;
       #while (N <= 1)
         [N             color rgbf <1, 1, 1, 1.0>]
         [N             color rgbf <0.5, 0.5, 1, 0.0>]
         #if (N = 0.5)
         [N + 0.015            color rgbf <0.5, 0.5, 1, 0.0>]
         [N + 0.015            color rgbf <1, 1, 1, 1.0>]
         #else
         [N + 0.01            color rgbf <0.5, 0.5, 1, 0.0>]
         [N + 0.01            color rgbf <1, 1, 1, 1.0>]
         #declare N = N + 0.1;
#declare T_Grid =
     pigment { color rgb <1, 1, 1> }
     finish { ambient 0.5 }
     pigment { P_Lines }
     pigment { P_Lines rotate <0, 90, 0> }
Oslo, Norway
