POV-Ray : Newsgroups : povray.binaries.images : Lady of the Lake, version 2 (100kbu) Server Time
1 Aug 2026 17:57:20 EDT (-0400)
  Lady of the Lake, version 2 (100kbu) (Message 11 to 19 of 19)
Subject: Re: Lady of the Lake, version 2 (100kbu)
Date: 2 Feb 2007 11:49:38
Message: <ifq6s29r9g2nk3qqcmgu9cn2gqi26ius4q@4ax.com>
On Fri, 2 Feb 2007 17:20:53 +0200, "Gail Shaw" <initialsurname@sentech sa dot com>
wrote:
Nice image!
>Focal blur settings are as follows. I'm not very experienced with focul
>blur. Any settings you'd suggest changing?
>aperture 0.09
>blur_samples 150
>focal_point <13,-1.65,-2>
>confidence 0.95
>variance 1/256
I'd suggest reducing the aperture a bit to increase the depth of field.  The
background looks too blurry to me.  You should be able to find a happy medium where
the background is out of focus enough
to hide the lack of details that you have mentioned, but a little sharper that it is
now.  It's really all up to your artistic preferences, though.  :-)  You can increase
the blur samples to reduce
the graininess.
Kyle
Date: 2 Feb 2007 15:35:01
Message: <web.45c39f6fc96678e2d13f7aad0@news.povray.org>
"Gail Shaw" <initialsurname@sentech sa dot com> wrote:
> Changed the sky to something a bit more realistic (The previous one was my
> poor attempt at a sunrise)
> Changed the camera angle slightly
> Increased the amount of surface mist.
> Comments?
Looks great.  It's probably just this LCD I'm viewing it on, but my only
problem with it is the transition from the hills to the sky.  It looks a
bit like someone was taking a long exposure photo and bumped the camera
halfway through.  I think that one edge needs more blur, or maybe turn down
the contrast just a bit.
The trees go very nicely into the fog and the hills, but the contrast is
lower there...  I'm not quite sure how to suggest a fix either, OTOH as I
said at the start, it might not even be a real problem.
Date: 2 Feb 2007 16:14:57
Message: <45c3a9d1$1@news.povray.org>
   IIRC, "variance 0" gives usually less grain, but it's very slow with
so many samples.
   Great image, BTW!
Jaime
Date: 3 Feb 2007 03:18:49
Message: <45c44569@news.povray.org>
Yes, I like this version better!
The sky is beautiful. The banding Stephen mentioned is probably due to (one
of) the fog(s) in the distance. Just a guess. I seem to have experienced
something similar in the past.
I am not a very big fan of focal blur, but here it is very effective indeed.
Well done!
Date: 3 Feb 2007 04:21:15
Message: <45c4540b@news.povray.org>
> aperture 0.09
> blur_samples 150
> confidence 0.95
> variance 1/256
I think your variance is good, but you should increase the confidence. Right
now, for each pixel you're 95% sure that it's within 1/256 of the color it
should be. You want to be much more sure than that. You may also have to
increase the blur_samples in order to achieve the confidence you specify.
And if all else fails, just set confidence 1 varience 0 and it will do the
specified number of blur_samples for every pixel.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 3 Feb 2007 05:48:22
Message: <nrp8s2huclp1a4b0jk6brg6tqhljslofk3@4ax.com>
>> "Stephen" <mcavoys_AT_aolDOT.com> wrote in message
>> news:web.45c3535fc96678e2f1cb1e660@news.povray.org...
>> > I like this better, particularly the moon and the mist. I like the sky, on
>> > my work's monitor it looks subtly stratified at the top, nice.
>> Thanks. I'm not sure why the banding is there. The sky is a solid colour and
>> 2 ground fogs with very high distance
>Can you see it in the original? Looks good to me.
Looking at the image at home on my own monitor I don't see anything that would
make me comment on banding. Cheap work's monitor :-(
I much prefer the new camera position.
Regards
Date: 3 Feb 2007 08:55:36
Message: <2n49s21vpj4p6b752ade6ng7uve0d8pjb1@4ax.com>
Actually, a confidence value of 1 is invalid.  POV-Ray will display a warning message
and default to
a confidence value of 0.9, at least in version 3.6.  Reference section "3.3.1.3  Focal
Blur" in the
manual.
Kyle
Date: 4 Feb 2007 04:10:31
Message: <45c5a307@news.povray.org>
"Stephen" <mcavoysATaolDOTcom@> wrote in message
news:nrp8s2huclp1a4b0jk6brg6tqhljslofk3@4ax.com...
would
I can see a bit on the original image, but I have to zoom in massivly to see
it.
Thanks. Me too.
Date: 4 Feb 2007 04:45:13
Message: <poabs2h8483ntfoqbhltntd6qhjgi8c1s0@4ax.com>
On Sun, 4 Feb 2007 11:10:43 +0200, "Gail Shaw" <initialsurname@sentech sa dot
>would
>it.
At home I saw it in psp by "find all edges" then "enhance edges more". Bah!
Cheap monitors.
Regards
