POV-Ray : Newsgroups : povray.binaries.images : black reflections on shiny balls Server Time
9 May 2026 13:06:52 EDT (-0400)
  black reflections on shiny balls (Message 11 to 12 of 12)
Subject: Re: black reflections on shiny balls
Date: 29 Jan 2007 13:34:02
Message: <45be3e1a$1@news.povray.org>
tried the following:
//#if (strcmp(texturepic,"")=0)
        texture{
                pigment { color rgb <1,1,1>  }
                finish{ finball  }
//#end
        #if (strcmp(pic,"")!=0)
        texture{
                        image_map
                                        gif   pic
                                        //  map_type 1
                                        #declare j=0;
                                        #declare
jmax=dimension_size(filterarr,1);
                                        #while (j<jmax)
                                                filter   filterarr[j], 1
                                        #declare j=j+1;
                                        #end//
                                        once
                        scale <1,1,1>*1.2
                        warp {
                                spherical
                                orientation z
                                dist_exp 1
                        // translate <0,1.1,0>
                        //  rotate 100*y  //color rgbf <1,1,0>
                        // rotate x*-22
                        // scale  0.1
                scale mapscale
                rotate y*130
                finish{finpic}
#declare ttextur=   texture { pigment {rgbt <1,1,1,1>} normal {bumps 1 scale
.01}};
#if (strcmp(texturepic,"")!=0)
      texture { uv_mapping
        image_pattern { gif texturepic  }
        texture_map {
                [0 uv_mapping ttextur]
                [1 uv_mapping textur scale 1/mapscale]
         scale mapscale
         translate <0,1.02*mapscale,0>
rotate <0,15,0>
translate <0,1,0>
but pov complains that it cannot layer a patterned texture over another. I
think it's the first and the last texture that are conflicting. If I just
put the shiny finish in the texture map then it gets bumps like the metal
part in textur which is not the intention.
"Ben Chambers" <ben### [at] pacificwebguycom> wrote in message
news:45bd78e5@news.povray.org...
> Johan Feyaerts wrote:
>> I think I tried that already but pov protested that image maps could not
>> be combined with texture maps.
> An image_map is a pigment type, which is part of a texture.  So you
> shouldn't try to combine the two.
> Instead, declare the image map as the pigment of a complete texture, and
> layer that with another complete texture.
> ...Chambers
Date: 2 Feb 2007 03:56:39
Message: <45c2fcc7@news.povray.org>
Try it like this:
#declare foo = texture { <first texture here> }
#declare bar = texture { <texture w/ image map here> }
texture {average texture_map {[1 foo][1 bar]}}
...Chambers
