POV-Ray : Newsgroups : povray.binaries.images : Almost there... Server Time
1 Aug 2026 18:59:20 EDT (-0400)
  Almost there... (Message 11 to 17 of 17)
Subject: Re: Almost there...
Date: 1 Jan 2007 10:40:25
Message: <45992b69$1@news.povray.org>
"Thomas de Groot" <t.d### [at] internlDOTnet> wrote in message
news:4598ccbb$1@news.povray.org...
> "Jim Charter" <jrc### [at] msncom> schreef in bericht
> news:4598096c$1@news.povray.org...
>> St. wrote:
>>>    Well Vincent, this was the best that I could do with Wings so far on
>>> your Rapier Hilt project. Hope you like it.
>> Nice job!
> I second that !
  Thanks Thomas!  :o)
   ~Steve~
> Thomas
Date: 1 Jan 2007 10:40:26
Message: <45992b6a@news.povray.org>
> Nice job!
     Thank you Jim!
> So I'm wondering, is this a right or left handed sword, or does it matter?
    I was wondering this myself, and now Vincent has explained it, but it
did look right-handed to me.
    ~Steve~
Date: 2 Jan 2007 03:40:00
Message: <web.459a19cb91160245f1cb1e660@news.povray.org>
> > Almost(?) there!
>     Well, I did spot a mistake on that spiky bit by the join to the right
> where it's scaled 'fatter' than the bit before it. I think I left some verts
> selected when scaling something else. Anyway, it's now corrected in the .obj
> model posted in my reply to Vincent.  :o)
Spiky bit, would that be what most people call the blade? Only joking, the
Date: 2 Jan 2007 08:51:34
Message: <459a6366@news.povray.org>
"Vincent Le Chevalier" <gal### [at] libertyALLsurfSPAMfr> schreef in
bericht news:45991601$1@news.povray.org...
> No it's indeed a left-handed rapier. Well, that's the convention actually,
> you could certainly hold it in your right hand as well...
 As I have no experience at all with rapiers, mine was a wild guess just
based on trying to hold the thing  :-)
So... what makes this particlularly left-handed, is there clue? Just down to
earth curiosity really...
Date: 2 Jan 2007 09:47:51
Message: <459a7097@news.povray.org>
Swords being another of my hobbies I will happily try to satisfy your
curiosity :-)
However it's a bit difficult to explain in text... Some terminology
necessary to understand what I'm saying can be found here:
http://www.myarmoury.com/feature_anatomy.php#rapier
The conventional way of holding the rapier is as follow: you pass your
index finger around the fore quillon, inside one of the finger rings.
The rest of the fingers hold the grip, and are protected by the knuckle
guard. In this position, the back of your hand is protected by the side
ring and loop-guard (the spiraling bar in the specific example modelled
by Steve is a style of loop-guard). The thumb is on the other side, and
is protected by the counter guards.
To sum up and speak POV-ish :-) , on a right-hander, you have the blade
on +z, the knuckle guard on the +x side, and the side ring raising along
+y. The assumption being that the hilt was designed (or rather evolved)
to be most protective when held in this way.
But this does not prevent a left-hander from fighting with a
right-handed rapier, nor the opposite. I tend to think this is by design
also, in case of injury on your dominant hand you wouldn't like to be
unable to use your weapon in the other hand as well ;-)
There are also some other way to hold the thing, that were less spread
as far as I know. You can pass your index and middle finger through the
same finger ring to increase tip control. You can pass them through both
of the finger rings, one in each of them, to have the blade more
parallel to your fore-arm. I even read about a grip which looks like the
opposite of the usual way, with fingers protected by the counter guard,
the index passed in the other finger ring, that provides advantages when
using the quillons to control the opponent's blade...
I'll have to model and pose a hand inside Steve's guard to explain more
visually, I guess :-D
Regards
Vincent
Date: 2 Jan 2007 11:33:20
Message: <459a8950@news.povray.org>
>> in bericht news:45991601$1@news.povray.org...
>>> actually, you could certainly hold it in your right hand as well...
>> just based on trying to hold the thing  :-)
>> down to earth curiosity really...
> curiosity :-)
Thanks for the explanation.  My original question was provoked by the
assumption that the side-ring would probably be held to the outside of
the body although I have no clue what it is supposed to do.
Date: 3 Jan 2007 03:20:25
Message: <459b6749$1@news.povray.org>
Thank you very much indeed!!! An excellent explanation. I never realized the
necessary complexity of the thing. Always thought it was mere decoration,
but that was not doing right to the builders who were able to merge
technology with beauty. A revelation to me. Thank you!
