POV-Ray : Newsgroups : povray.binaries.images : ...the other side Server Time
21 Mar 2026 21:00:57 EDT (-0400)
  ...the other side (Message 1 to 5 of 5)
Subject: ...the other side
Date: 28 Nov 2006 15:40:01
Message: <web.456c9d7cb7f06341bc81efaa0@news.povray.org>
This image was inspired by one that I found on this board at some point.  I
liked the concept and decided to try my own take.  I can't find the
original now though.  If anyone has a reference, I'd appreciate it.  This
uses the Makegrass macro by Gilles Tran.
#version 3.6;
#include "mgrass.pov"
#include "functions.inc"
#declare fast=false;
#ifndef (fast)
 #declare fast=true;
//#declare cam=0;
#ifndef (cam)
 #declare cam=1;
#default {
   color rgb 1
  finish {
   ambient 0
   diffuse 1
global_settings {
 assumed_gamma 1.0
#switch (cam)
 #case (0)
   location <3.0, 0.0, -2.0>
   direction 1.5*z
   look_at <0.0, 0.0,  0.0>
 #break
 #case (1)
   location <1.0, 0.0, -4.0>
   direction 1.5*z
 #break
 #case (2)
   location <2.0, 0.0, 2.0>
   direction 1.5*z
  light_source {
   <0, 0, 2>
   color rgb 0.5
 #break
#if (!fast)
light_source {
  <0, 0, 50>
  color rgb 0.5
  shadowless
sphere {
 0.0, 100
 no_shadow
light_source {
  <1, 1, -1.5>
  color rgb 0.75
  fade_distance 4.5
  fade_power 2
#if (!fast)
  area_light
  <1, 0, 0>
  <0, 1, 0>
  5
  5
  jitter
  adaptive 1
light_source {
  <-1, -5, -10>
  color rgb 0.25
  fade_distance 10
  fade_power 2
#if (!fast)
  area_light
  <1, 0, 0>
  <0, 1, 0>
  5
  5
  jitter
  adaptive 1
sphere {
 0.0, 1
 no_shadow
   color rgb <0.0, 0.2, 0.0>
#if (!fast)
union {
// Patch parameters
// Final number of triangles = nBlade x nBlade x segBlade x 2 (or 4 if
dofold = true)
#declare lPatch=50;               // size of patch
#declare nBlade=10;                // number of blades per line (there will
be nBlade x nBlade blades)
#declare ryBlade = 0;            // initial y rotation of blade
#declare segBlade= 15;            // number of blade segments
#declare lBlade = 25;             // length of blade
#declare wBlade = 1;              // width of blade at start
#declare wBladeEnd = 0.3;         // width of blade at the end
#declare doSmooth=true;          // true makes smooth triangles
#declare startBend = <0,1,0.3>;   // bending of blade at start (<0,1,0>=no
bending)
#declare vBend = <0,-0.5,0>;         // force bending the blade (<0,1,1> =
#declare pwBend = 3;              // bending power (how slowly the curve
bends)
#declare rd = 459;                // seed
#declare stdposBlade = 1;         // standard deviation of blade position
0..1
#declare stdrotBlade = 360;       // standard deviation of rotation
#declare stdBlade = 1.2;           // standard deviation of blade scale;
#declare stdBend = 2;            // standard deviation of blade bending;
#declare dofold = false;          // true creates a central fold in the
blade (twice more triangles)
#declare dofile = false;          // true creates a mesh file
#declare fname = "fgrass1.inc"     // name of the mesh file to create
#declare grass = object { MakeGrassPatch( lPatch, nBlade, ryBlade, segBlade,
lBlade, wBlade, wBladeEnd, doSmooth, startBend, vBend, pwBend, rd,
stdposBlade, stdrotBlade, stdBlade, stdBend, dofold, dofile, fname) };
#declare R = seed(642);
#declare clump = 0;
#declare clumps = 4000;
#while (clump < clumps )
 object {
  grass
  rotate <0, 180*rand(R), 0>
  scale <0.002, 0.005*rand(R), 0.002>
  translate <0, 1, 0>
  rotate <-180*rand(R), 90-180*rand(R), 0>
 #declare clump = clump+1;
pigment { color rgb <0.0, 0.2, 0.0> }
union {
#declare post=
cylinder {
 <0, 0, 0>
 <0, 1,  0>
 1
 scale <.0123, 0.3, .0123>
#declare rail =
union {
 sphere {
  <0, 0.1, 0>
  0.005
 sphere {
  <0, 0.2, 0>
  0.005
#if (!fast)
 #declare total_railing = 10000;
 #declare total_posts = 75;
#else
 #declare total_railing = 500;
 #declare total_posts = 10;
#declare rails_per_post = int(total_railing / total_posts);
#declare ang = 0;
#declare dAng = 360/total_railing;
#declare cur_rail = 1;
#while (cur_rail <= total_railing)
 #declare add_post = mod(cur_rail, rails_per_post);
 #if (add_post = 0)
  object {
   post
   translate <0, 1, 0>
   rotate <90+45*(sin(0.1*ang)*sin(0.04*ang)*cos(0.01*ang)), ang, 0>
 object {
  rail
  translate <0, 1, 0>
 #declare ang = ang+dAng;
 #declare cur_rail = cur_rail+1;
#declare sheep =
union {
 sphere {
  <0, .1, 0>
  .1
  scale <1, 1, 1.5>
 sphere {
  <.05, 0, -.07>
  .05
 sphere {
  <-.05, 0, -.07>
  .05
 sphere {
  <.05, 0, .07>
  .05
 sphere {
  <-.05, 0, .07>
  .05
 sphere {
  <0, 0, 0>
  .07
  scale <1, 1, 1.4>
  rotate <-30, 0, 0>
  translate <0, .2, -.15>
 sphere {
  <0, .1, .15>
  .02
#declare headless_sheep =
union {
 sphere {
  <0, .1, 0>
  .1
  scale <1, 1, 1.5>
 sphere {
  <.05, 0, -.07>
  .05
 sphere {
  <-.05, 0, -.07>
  .05
 sphere {
  <.05, 0, .07>
  .05
 sphere {
  <-.05, 0, .07>
  .05
 sphere {
  <0, .1, .15>
  .02
#declare sheep_head =
 sphere {
  <0, 0, 0>
  .07
  scale <1, 1, 1.4>
  rotate <-30, 0, 0>
object {
 sheep
 rotate <0, 40, 0>
 translate <0, 1, 0>
 rotate <-83, 4, 0>
object {
 sheep
 rotate <0, -120, 0>
 translate <0, 1, 0>
 rotate <-100, -50, 0>
object {
 sheep
 rotate <0, 110, 0>
 translate <0, 1, 0>
 rotate <-83, -129, 0>
union{
 object {
  headless_sheep
 object {
  sheep_head
  translate <0, -.2, .15>
  rotate <60, 0, 0>
 rotate <0, 130, 0>
 translate <0, 1, 0>
 rotate <-60, -40, 0>
 pigment { color rgb .01 }
Download 'sheep1.jpg' (146 KB)
Preview of image 'sheep1.jpg'
Subject: Re: ...the other side
Date: 28 Nov 2006 19:05:01
Message: <web.456ccdd675c1c74f8ecc74b10@news.povray.org>
nice!  but perhaps the sheep could use the make_grass macro as well to fake
fur? :)
Date: 29 Nov 2006 09:09:02
Message: <456d947e$1@news.povray.org>
"o.bb.spammed" <o.b### [at] gmailcom> wrote in message
news:web.456c9d7cb7f06341bc81efaa0@news.povray.org...
> I
Your source of inspiration was POVMAN who posted 'Another, Pondering Sheep
Image' in this NG on 6/6/6
news:44852ced@news.povray.org
http://news.povray.org/povray.binaries.images/thread/%3C44852ced%40news.povray.org%3E/?ttop=235491&toff=300
DLM
Date: 29 Nov 2006 11:15:01
Message: <web.456db18175c1c74fbc81efaa0@news.povray.org>
> > I
> DLM
That's the one.  Thank you!
Date: 5 Dec 2006 04:16:52
Message: <45753904$1@news.povray.org>
I like this.
 - Slime
 [ http://www.slimeland.com/ ]
