POV-Ray : Newsgroups : povray.binaries.images : waves of stone, close up Server Time
1 Aug 2026 20:05:37 EDT (-0400)
  waves of stone, close up (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: waves of stone, close up
Date: 28 Nov 2006 12:45:04
Message: <456c75a0@news.povray.org>
You know Tek, that's much better. :o)
  After looking at this image, I was thinking about what I would do with it,
and came to the conclusion that I would definately cover those floating
bits. The one to the far right would be a soaring eagle - you already have
the perfect shape there. And the one near the centre, I'd just cover with
cloud. Also, the pointy bit to the left, would have the eagle's mate sitting
there awaiting his return with possibly a nest nearby, (as that part looks
quite close to me, and the rest looks far away).
   Nice potential in this image for various themes. (Hang glider also comes
to mind low down in that valley).
      ~Steve~
Date: 28 Nov 2006 15:22:30
Message: <456c9a86$1@news.povray.org>
Hash: SHA1
Tek wrote:
> tweaked!
> Improved rock & grass texture so the middle distance looks less flat and
> boring, although perhaps now too dark. And way better clouds, though still
> some striped artefacts (despite intervals=4).
	You should lower the interval back to 1 and increase the samples
instead. With the right settings, you should get something that
looks better *and* renders faster...
		Jerome
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (GNU/Linux)
iD8DBQFFbJqgd0kWM4JG3k8RAs2gAJ9yl+sHgnqYw9JJ6qSMu4aSkddPcwCfe9LR
E/l9ZPwWBu/WmiaYW39gc2c=
=aeXg
-----END PGP SIGNATURE-----
Date: 28 Nov 2006 19:35:24
Message: <456cd5cc$1@news.povray.org>
Actually when I said "intervals" I was mistaken, it was the samples I
increased. They render faster than intervals but even with this setting,
which still has some artefacts, it takes about 10 times longer than the rest
of the scene :-(
Tek
http://evilsuperbrain.com
news:456c9a86$1@news.povray.org...
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Tek wrote:
>> tweaked!
>> still
> Jerome
> =aeXg
Date: 28 Nov 2006 19:41:09
Message: <456cd725$1@news.povray.org>
Nope, no df3s here, it's a granite pattern with a lot of turbulence. The
bands are parallel to the bounding shape, because in the distance each ray
passes through a much longer range of clouds but uses the same number of
samples (why doesn't pov adjust the min samples based on the distance it's
sampling over?!), so you tend to get artefacts relating to large changes in
depth of the bounding shape, which in this case means horizontal lines
(effectively contours of depth of the bounding shape). And, before you say
it, the bounding shape has to be like that because otherwise the clouds
occupy such a small region of space that they mostly vanish when I use other
bounding shapes, because no rays intersect with them.
Annoyingly media method 3's "anti-aliasing" seems blind to this artefact, so
the only thing that fixes it is more samples => proportionally more render
time :(
This one has 4 times as many samples and the artefacts are better, but still
visible. Based on that I'd expect a 1500x1000 render without artefacts to
take more than 24hrs! aaargh! So I'm not going to bother :)
Tek
"David El Tom" <dav### [at] t-onlinede> wrote in message
news:456bf263$1@news.povray.org...
> Tek schrieb:
>> I put the camera somewhere more interesting, and tweaked the lighting and
>> atmosphere a bit. Though this much higher-res image shows up some errors
>> in
>> the clouds. Also this view shows some obvious levitating rocks, and I'm
>> not
>> so fond of the boring grey rock texture...
>> Anyway, still looks pretty dramatic so I thought I'd show it :)
>> I'm probably going to use it as a backdrop for some 2D stuff in
>> photoshop,
>> with some figures on the overhang on the left.
> nice surreal appeal ...
> it looks like your using media clouds based on df3 data (banding/cell
> strukture). Instead of increasing the resolution of the df3 data you may
> add some turbulence *after* importing the density file. Will slow down
> the render process slightly but you get rid of the cell strukture, which
> is an inherent problem of density files.
> ... dave
Date: 28 Nov 2006 19:42:55
Message: <456cd78f$1@news.povray.org>
And, for anyone who wants to laugh at how much worse my 2D skills are than
my povray skills, here's a version I've painted all over using Corel Painter
IX.5 and Photoshop: http://www.deviantart.com/deviation/43810502/
Criticism appreciated, particularly from anyone who's good with a paint
brush. Though "stick to what you're good at" will not be appreciated! I'm
trying to branch out! :)
Tek
news:456aa77a@news.povray.org...
>atmosphere a bit. Though this much higher-res image shows up some errors in
>the clouds. Also this view shows some obvious levitating rocks, and I'm not
> I'm probably going to use it as a backdrop for some 2D stuff in photoshop,
> Tek
Date: 28 Nov 2006 21:02:02
Message: <456cea1a$1@news.povray.org>
Tek nous apporta ses lumieres en ce 28/11/2006 19:35:
> of the scene :-(
samples 4 is prety low. You may need something larger, like 50 or more. The
rendering time increase less than linearly when you increase the  samples count.
If you are good, you will be assigned all the work. If you are really good, you
will get out of it.
Date: 29 Nov 2006 01:24:33
Message: <456d27a1$1@news.povray.org>
I have samples 40, which is 4 times the default, which is where I got 4 from
in my original message :)
Tek
"Alain" <ele### [at] netscapenet> wrote in message
news:456cea1a$1@news.povray.org...
>> rest of the scene :-(
> The rendering time increase less than linearly when you increase the
> samples count.
> Alain
> good, you will get out of it.
Date: 29 Nov 2006 04:17:02
Message: <456d500e$1@news.povray.org>
"Tek" <tek### [at] evilsuperbraincom> schreef in bericht
news:456cd78f$1@news.povray.org...
> Painter IX.5 and Photoshop: http://www.deviantart.com/deviation/43810502/
Stick to....
Sorry. I forgot.
The usefulness of this exercise is that it gives a fair idea about
proportions in the landscape. I would suggest even smaller figures in fact
on the overhang! The eagle should be farther away.
Date: 29 Nov 2006 13:58:21
Message: <456dd84d$1@news.povray.org>
	Then you should try to raise the aa_level (default is 4) and lower
the samples back. Start at samples 20 aa_level 6 for example...
		Jerome
Date: 29 Nov 2006 14:17:02
Message: <456ddcae$1@news.povray.org>
Hash: SHA1
> sampling over?!),
	Megapov 0.7 could do it, but I never had the time to port it to
more recent versions...
		Jerome
iD8DBQFFbdzMd0kWM4JG3k8RAop+AJ9FSzupaZiq763Ihgt8JQuxJAj7OQCdGWZn
SyyT3py/8IBP0MYcq3cIlJM=
=DXCb
