POV-Ray : Newsgroups : povray.binaries.images : water again (did I say final? lol) Server Time
1 Aug 2026 21:30:53 EDT (-0400)
  water again (did I say final? lol) (Message 17 to 26 of 36)
Subject: Re: water again (did I say final? lol)
Date: 16 Nov 2006 08:50:00
Message: <web.455c6b93e4e3b873f1cb1e660@news.povray.org>
> Really? Every time I've seen things underwater in the ocean it's been very
> hard to see any kind of distance.
It depends where you are looking from. If you are close to shore the
turbulence stirs up a lot of sand and cuts down the visibility. If you are
offshore in deep water the sea is clearer. Also if you are higher that a
few yards above the surface you get better visibility through the top layer
of water. I spent about sixteen years working on oilrigs and can say that
your latest images are quire realistic. One other thing, some rust marks
would not go amiss on your ship :-) The rust stains would come from the
bilge pumps even on a fibreglass hull.
> Anyway, here's a less transparent version, discuss :)
Although waves are said to be fractal and it is difficult to get a sense of
scale from them the foam defines the scale for me. I would say that these
waves are no more that two meters high. (The lifebelt reinforces this) This
jars with the scale of ship, to my eyes. You know RL often does not measure
up to our imagination -)
Can you change the ship for a yacht? (Shakes both hands in a Tommy Cooper
deserves the best.
> Tek
> http://evilsuperbrain.com
> "Thomas de Groot" <t.d### [at] internlnet> wrote in message
> news:455c3ca5$1@news.povray.org...
> > "Stephen" <mcavoys_AT_aolDOT.com> schreef in bericht
> > news:web.455c23e6e4e3b873f1cb1e660@news.povray.org...
> >> I don't agree. >
> > Neither do I.
> > From my experience on ships and in rough seas, the water can be extremely
> > clear, allowing you to see down to several metres.
> > Thomas
Date: 16 Nov 2006 10:15:00
Message: <web.455c8036e4e3b873c0bad8570@news.povray.org>
> "John VanSickle" <evi### [at] hotmailcom> wrote in message
> news:455b4f6d$1@news.povray.org...
> > How easily can you animate it?  There's probably a good-paying job out
> > there for you if you can.
> Well I had a go at animating it, it looks terrible. I think I could get
> something good if I replace the ridged_mf function with a home-grown version
> where I can animate each octave independantly, but it would probalby still
> look a bit wierd and I can't be bothered putting that much effort in! :)
I'd talk to fidos if you wan't it animated. He's done some AWESOME fluid
simulations (using his own computational fluid dynamics engine) in
povray.binaries.animations
> Tek
Date: 16 Nov 2006 10:17:55
Message: <455c8123$1@news.povray.org>
news:web.455c6b93e4e3b873f1cb1e660@news.povray.org...
> layer
Yes, like Stephen says. I often observed from the deck of a ship that in a
turbulent sea, once in a while, you get suddenly whole stretches of a
perfectly smooth surface, mostly in the wave troughs of course, through
which you can look down into the depth. It only happens for a few seconds
and then the surface clouds over once more, as it were.
Date: 16 Nov 2006 10:20:00
Message: <web.455c8080e4e3b873c0bad8570@news.povray.org>
> A couple of different versions with a more detailed & more appropriately
> scaled boat.
> Opinions? I'm starting to get a bit lost on this project, to be honest...
> Tek
I'd like to help. Can you tell us why you think you made this image in the
first place? Is there a certain goal in mind? IRTC? If so, what would the
topic be?
Thanks,
George
MegaPOV XRS parallel rendering patch: http://www.gammaburst.net
Date: 16 Nov 2006 10:27:16
Message: <455c8354$1@news.povray.org>
"George Pantazopoulos" <go### [at] tomyaboutpage> wrote in message
news:web.455c8036e4e3b873c0bad8570@news.povray.org...
But then that would be an animation of a different effect, not my sea.
There's a fundamental difference between a simulation and a ridged
multifractal that I don't think can be ignored here...
Tek
Date: 16 Nov 2006 10:35:00
Message: <web.455c84ffe4e3b873c0bad8570@news.povray.org>
> Tek
You've got a point, but have you seen his stuff? Check out his "Liquid
Animation" series
Date: 16 Nov 2006 10:42:56
Message: <455c8700@news.povray.org>
"Stephen" <mcavoys_AT_aolDOT.com> wrote in message
> of
> This
> measure
> movement :-). I'm sorry if I sound nitpicking but it is such good sea it
> deserves the best.
I think perhaps you're confused about what ship I'm using. if you look
closely you might notice this is no longer a huge ocean liner, I've replaced
it with a more appropriatly scaled trawler (as noted in my first post in
this thread).
To make this a bit more visible, here's a render without any water, and one
with the boat moved closer to the camera & life ring for comparison of
scale.
Tek
Download 'boatclose.jpg' (76 KB) Download 'nowater.jpg' (51 KB)
Preview of image 'boatclose.jpg'
Preview of image 'nowater.jpg'
Date: 16 Nov 2006 11:04:59
Message: <455c8c2b$1@news.povray.org>
news:web.455c84ffe4e3b873c0bad8570@news.povray.org...
> Animation" series
Yeah I've seen it, to be honest it's never looked quite right to me, sorta
like jelly (that's jello, for you americans).
I've seen better, check out the R&D video here:
http://www.scanlinevfx.com/gallery.html
Tek
Date: 16 Nov 2006 12:00:00
Message: <web.455c98ffe4e3b873f1cb1e660@news.povray.org>
> > of
> > This
> > measure
> > deserves the best.
> this thread).
> scale.
Yes you are right I was still thinking about the liner. Strange how after
BTW I asked a work colleague to look at
http://news.povray.org/povray.binaries.images/attachment/%3C455b17c1%40news.povray.org%3E/ridgedmf2.jpg
He worked offshore longer than me and when I said that it was a cg not a
photograph.
Endit.
Date: 16 Nov 2006 12:23:13
Message: <455c9e81$1@news.povray.org>
It depends how warm the water is, as well as the rest of the effects. In
cold water, algae can live, and they're usually maybe 6 inches deep down
to four or five feet deep, because they have to avoid being exposed to
direct sun, but close enough to get the light.  A storm would stir them up.
Down south, where the main source of opacity is inorganic life (i.e.,
sand), deep water stays clear near the top even in fairly violent storms.
Of course, the scuba still sucks after a storm, because the things you
want to look at are all near the bottom, not the surface.
     Scruffitarianism - Where T-shirt, jeans,
     and a three-day beard are "Sunday Best."
