POV-Ray : Newsgroups : povray.binaries.images : artistic water Server Time
1 Aug 2026 21:31:31 EDT (-0400)
  artistic water (Message 23 to 32 of 32)
Subject: Re: artistic water
Date: 9 Nov 2006 15:55:01
Message: <web.455394c7c41de098ffb947b40@news.povray.org>
> "Gail Shaw" <initialsurname@sentech sa dot com> wrote in message
> news:45515d23@news.povray.org...
> > That's fantastic.
> Thank you :)
> > You might be able to fix the 'all at the same height' problem if you add a
> > large scale f_rand3d to the function.
> I've now added f_spotted and the problem is completely fixed (plus it now
> looks like an even more dramatic ocean!).
Firstly, the water is fantastic, really dramatic looking, I guess you could
adjust the size of the rubber ring to make the waves look even larger...
Secondly any chance you can post the improved render.
Sean
Date: 9 Nov 2006 16:02:36
Message: <4553976c@news.povray.org>
"s.day" <s.d### [at] uelacuk> wrote in message
news:web.455394c7c41de098ffb947b40@news.povray.org...
Well I was waiting until I let one finish with anti-aliasing turned on!
Trouble is I keep stopping it when it's half done to tweak the wave shapes.
Although I think I'm happy with them now, so I'm chucking a sinking ship in
there to show off the refraction and media effects below the surface. Here's
a taster (without anti-aliasing).
Tek
http://evilsuperbrain.com
Download 'water2-1.jpg' (158 KB)
Preview of image 'water2-1.jpg'
Date: 9 Nov 2006 20:10:50
Message: <75k7l29lb4p1uh7tc35g3o99nnh7jjp874@4ax.com>
Oooh, those waves look very nice.  Much better than I have achieved.  Great work!
I'll be keeping an eye out for the code... I hope you will post it.
Kyle
Date: 9 Nov 2006 20:31:37
Message: <4553d679$1@news.povray.org>
I'll probably post it when it's finished...
Tek
"Kyle" <hob### [at] gatenet> wrote in message
news:75k7l29lb4p1uh7tc35g3o99nnh7jjp874@4ax.com...
> Great work!
> Kyle
Date: 10 Nov 2006 02:39:02
Message: <45542c96@news.povray.org>
Tek wrote:
> I decided to have a play with ridged_mf. Usually I avoid it because it has
> all those parameters and granite generally looks good enough. Anyway, I came
> up with something rather good!
> Render time 6h 36m.
I assume you're using an isosurface?  You could probably speed up the
rendertime (by several orders of magnitude, in fact) by first rendering
the pattern as a height field.
...Chambers
Date: 10 Nov 2006 03:13:00
Message: <4554348c@news.povray.org>
"Ben Chambers" <ben### [at] pacificwebguycom> schreef in bericht
news:45542c96@news.povray.org...
...but then you will miss the overhanging parts...!
Date: 10 Nov 2006 04:57:54
Message: <45544d22$1@news.povray.org>
> Thomas
Were there some?  I found it hard to see any in the picture.
Of course, you could use intersections between height fields, and other
such tricks, but that gets... tricky ;)
...Chambers
Date: 10 Nov 2006 10:19:14
Message: <45549872$1@news.povray.org>
"Ben Chambers" <ben### [at] pacificwebguycom> wrote in message
news:45544d22$1@news.povray.org...
The overhanging parts aren't obvious in the first version of this image
(aside from the whole thing leaning left, but that could easily be done with
Skew_Trans on a height field), but if you look at my new post they're much
more visible.
The render time's mostly caused by radiosity (which I've since disabled) and
reflections & refractions. A heightfield would be a big help with those
because it traces very quickly, though the resolution I'd need for this
image would mean a huge pretrace time to generate that heightfield, and a
huge lump of memory to store it!
Tek
Date: 10 Nov 2006 15:40:00
Message: <web.4554e34ec41de098f39556bf0@news.povray.org>
> "Smws" <smw### [at] poboxcom> wrote in message
> news:web.4551fe32c41de098da53d9e40@news.povray.org...
>>... people may start to
> > suspect that your superbrain isn't so evil after all...
> Really? But I'm encouraging people to develop skills that serve no
> marketable purpose whatsoever! Just think of all those budding CG artists
> whose lives I've ruined by leading them to povray instead of Maya!
> Mwahahahahaha!
LOL!  Yeah, I think about that often as I tap away at my keyboard hour after
hour, tweaking, adding new things, discovering new tricks, forgetting to
eat(!), etc.  What can I say--I'm a slave to POV! Happily so!
Your images are simply fantastic, technically and artistically. They (and
the various suggestions of others) comprise one of the most interesting
newspost threads I've come across in awhile. MUCH food for thought here. I
agree with others: These are some of the most astonishing water waves I've
seen using POV-Ray. I *DO* like the "heightened realism"--like Old Master
paintings. Beautiful!
Ken W.
Date: 10 Nov 2006 16:08:34
Message: <4554ea52$1@news.povray.org>
> I *DO* like the "heightened realism"--like Old Master paintings.
> Beautiful!
Awesome, in that case it's intentional, and not caused by my inability to do
something realistic! :-D
Tek
"Kenneth" <kdw### [at] earthlinknet> wrote in message
news:web.4554e34ec41de098f39556bf0@news.povray.org...
>> Mwahahahahaha!
> after
> Ken W.
