POV-Ray : Newsgroups : povray.binaries.images : artistic water Server Time
1 Aug 2026 22:46:53 EDT (-0400)
  artistic water (Message 21 to 30 of 32)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: artistic water
Date: 9 Nov 2006 03:18:57
Message: <4552e471@news.povray.org>
"Tek" <tek### [at] evilsuperbraincom> schreef in bericht
news:45523a76$1@news.povray.org...
> Really? But I'm encouraging people to develop skills that serve no
> marketable purpose whatsoever! Just think of all those budding CG artists
> whose lives I've ruined by leading them to povray instead of Maya!
> Mwahahahahaha!
Now, that's evil!  Shame on you!!!
Date: 9 Nov 2006 13:56:45
Message: <455379ed@news.povray.org>
news:4552da59$1@news.povray.org...
> Pretty good - the horizon looking strange might also be due to something
> else.  In real life you would have quite a lot of spray in the air in such
> a situation that would limit the sight so you would not be able to see
> that far.
Yeah I was thinking of adding a little fog to take care of that but I
haven't got round to it yet :)
Tek
http://evilsuperbrain.com
Date: 9 Nov 2006 15:55:01
Message: <web.455394c7c41de098ffb947b40@news.povray.org>
> "Gail Shaw" <initialsurname@sentech sa dot com> wrote in message
> news:45515d23@news.povray.org...
> > That's fantastic.
> Thank you :)
> > You might be able to fix the 'all at the same height' problem if you add a
> > large scale f_rand3d to the function.
> I've now added f_spotted and the problem is completely fixed (plus it now
> looks like an even more dramatic ocean!).
Firstly, the water is fantastic, really dramatic looking, I guess you could
adjust the size of the rubber ring to make the waves look even larger...
Secondly any chance you can post the improved render.
Sean
Date: 9 Nov 2006 16:02:36
Message: <4553976c@news.povray.org>
"s.day" <s.d### [at] uelacuk> wrote in message
news:web.455394c7c41de098ffb947b40@news.povray.org...
Well I was waiting until I let one finish with anti-aliasing turned on!
Trouble is I keep stopping it when it's half done to tweak the wave shapes.
Although I think I'm happy with them now, so I'm chucking a sinking ship in
there to show off the refraction and media effects below the surface. Here's
a taster (without anti-aliasing).
Tek
Download 'water2-1.jpg' (158 KB)
Preview of image 'water2-1.jpg'
Date: 9 Nov 2006 20:10:50
Message: <75k7l29lb4p1uh7tc35g3o99nnh7jjp874@4ax.com>
Oooh, those waves look very nice.  Much better than I have achieved.  Great work!
I'll be keeping an eye out for the code... I hope you will post it.
Kyle
Date: 9 Nov 2006 20:31:37
Message: <4553d679$1@news.povray.org>
I'll probably post it when it's finished...
Tek
"Kyle" <hob### [at] gatenet> wrote in message
news:75k7l29lb4p1uh7tc35g3o99nnh7jjp874@4ax.com...
> Great work!
> Kyle
Date: 10 Nov 2006 02:39:02
Message: <45542c96@news.povray.org>
Tek wrote:
> I decided to have a play with ridged_mf. Usually I avoid it because it has
> all those parameters and granite generally looks good enough. Anyway, I came
> up with something rather good!
> Render time 6h 36m.
I assume you're using an isosurface?  You could probably speed up the
rendertime (by several orders of magnitude, in fact) by first rendering
the pattern as a height field.
...Chambers
Date: 10 Nov 2006 03:13:00
Message: <4554348c@news.povray.org>
"Ben Chambers" <ben### [at] pacificwebguycom> schreef in bericht
news:45542c96@news.povray.org...
...but then you will miss the overhanging parts...!
Date: 10 Nov 2006 04:57:54
Message: <45544d22$1@news.povray.org>
> Thomas
Were there some?  I found it hard to see any in the picture.
Of course, you could use intersections between height fields, and other
such tricks, but that gets... tricky ;)
...Chambers
Date: 10 Nov 2006 10:19:14
Message: <45549872$1@news.povray.org>
"Ben Chambers" <ben### [at] pacificwebguycom> wrote in message
news:45544d22$1@news.povray.org...
The overhanging parts aren't obvious in the first version of this image
(aside from the whole thing leaning left, but that could easily be done with
Skew_Trans on a height field), but if you look at my new post they're much
more visible.
The render time's mostly caused by radiosity (which I've since disabled) and
reflections & refractions. A heightfield would be a big help with those
because it traces very quickly, though the resolution I'd need for this
image would mean a huge pretrace time to generate that heightfield, and a
huge lump of memory to store it!
Tek
