POV-Ray : Newsgroups : povray.binaries.images : artistic water Server Time
2 Aug 2026 00:14:09 EDT (-0400)
  artistic water (Message 3 to 12 of 32)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: artistic water
Date: 7 Nov 2006 20:05:00
Message: <web.45512c31c41de098c0bad8570@news.povray.org>
> > Render time 6h 36m.
> > I'm very pleased with it, but the horizon looks wierd with all those wave
> > crests at exactly the same height.
> Adding some turbulence or 3d noise could reduce that effect.
>   Also the water has a really nice media
> > for stuff underwater, which is slowing down the render time, and you can't
> > see any sign of it in this shot! doh!
I love this look! I think an artistic, stylized, or idealized look can be a
lot more exciting than pure realism when making synthetic images, and I
feel you're onto something great with this one. Keep it up! I have a tool
that may help with that render time. Oh, and your signature rocks ;-)
George
http://www.gammaburst.net
> Alain
> Keep your boss’s boss off your boss’s back.
Date: 7 Nov 2006 20:07:38
Message: <45512dda$1@news.povray.org>
That is one of the most convincing modeling of rough seas I've seen from
Povray so far! Kudos. The froth could look a little frothier though,
then it would be just amazing.
Date: 7 Nov 2006 20:34:35
Message: <4551342b$1@news.povray.org>
Yeah the froth's a bit sharp and spikey at the moment, I'm working on it now
Tek
http://evilsuperbrain.com
"Halbert" <hal### [at] gmailcom> wrote in message
news:45512dda$1@news.povray.org...
> Povray so far! Kudos. The froth could look a little frothier though, then
Date: 7 Nov 2006 23:29:23
Message: <45515d23@news.povray.org>
news:45511803@news.povray.org...
> I decided to have a play with ridged_mf. Usually I avoid it because it has
> all those parameters and granite generally looks good enough. Anyway, I
came
> up with something rather good!
That's fantastic.
You might be able to fix the 'all at the same height' problem if you add a
large scale f_rand3d to the function.
How did you do the foam?
Date: 8 Nov 2006 00:18:16
Message: <45516898@news.povray.org>
news:4551342b$1@news.povray.org...
> now :)
Maybe make the froth fade to transparent with something like a granite
texture.
-Nekar Xenos
"The truth is out there"
Date: 8 Nov 2006 01:37:43
Message: <45517b37$1@news.povray.org>
"Gail Shaw" <initialsurname@sentech sa dot com> wrote in message
news:45515d23@news.povray.org...
> That's fantastic.
Thank you :)
I've now added f_spotted and the problem is completely fixed (plus it now
looks like an even more dramatic ocean!).
The foam is controlled using a nearly identical version of the f_ridged_mf
that defines the surface, but with the gain parameter cranked up a bit so it
picks up the higher frequencies more to make a more interesting shape.
That's averaged with a crackle form <1,0,0> pattern to look a bit like some
bubbles.
Tek
Date: 8 Nov 2006 03:13:51
Message: <455191bf$1@news.povray.org>
"Nekar" <ger### [at] rpmmagcoza> schreef in bericht
news:45516898@news.povray.org...
> "Tek" <tek### [at] evilsuperbraincom> wrote in message
>> now :)
> texture.
Hey, I wa just going to say that!!  :-)
Excellent, Tek!
Date: 8 Nov 2006 03:16:28
Message: <4551925c$1@news.povray.org>
"Tek" <tek### [at] evilsuperbraincom> schreef in bericht
news:45517b37$1@news.povray.org...
> it picks up the higher frequencies more to make a more interesting shape.
> some bubbles.
A while ago (for the Catastrophy IRTC) I have been experimenting with making
foam, but never got satisfying results... This looks much, much better!!
Date: 8 Nov 2006 04:30:00
Message: <web.4551a27fc41de098f1cb1e660@news.povray.org>
> all those parameters and granite generally looks good enough. Anyway, I came
> Render time 6h 36m.
> crests at exactly the same height. Also the water has a really nice media
When you get white horses like that the sea looks different see below for
reference.
http://www.boatingandmarineinfo.org/images/forces.jpg
http://www.boatingandmarineinfo.org/beaufort.html
and he is right. RL can be so disappointing.
I spent many hours wave watching when I worked offshore.
Message: <web.4551a371c41de0983976a8750@news.povray.org>
i'm guessing there weren't any survivers? ;)
great looking water!  Please, consider George's suggestion about his "tool".
