POV-Ray : Newsgroups : povray.binaries.images : Ourobus Snake Server Time
2 Aug 2026 01:42:27 EDT (-0400)
  Ourobus Snake (Message 41 to 44 of 44)
Subject: Re: Update: Ouroborous Snake and Escher Snake
Date: 12 Feb 2007 15:24:09
Message: <45d0cce9@news.povray.org>
St. wrote:
>     Ok, I think I've nailed this bump_mapping thingy.   ;)
>    It was the only route I could take after trying loads of stuff with the
> actual mesh.
Steve, I for got to ask and now I am wondering, what did you use to do
the UV mapping?
Wings? ...or something else such as UVmapper?
Date: 12 Feb 2007 22:34:04
Message: <45d131ac$1@news.povray.org>
news:45d0cce9@news.povray.org...
>> the actual mesh.
> Steve, I for got to ask and now I am wondering, what did you use to do the
> UV mapping?
      Hey Jim, yes, I used Wings. I did it in reverse to the norm(?) though,
I mapped and unfolded the flat inside of the snake to give it the normal
gold texture, and then applied the bump_map to the outer, scaly, skin.
(Doing it this way, I saved a whole heap of time by not selecting a trillion
faces!) :o)
 //Material definitions =====
 // flat inside of snake
#declare Cube7_sep8_auv=texture{
  pigment{ colour Pink}
finish{
      diffuse 0.3
      ambient  -.055
      specular 0.6
      phong 1
      reflection {
        0.8
        metallic
      conserve_energy
// Snake skin
#declare Default=texture{ pigment{ colour Pink}
finish{
      diffuse 0.3
      ambient  -.055
      specular 0.6
      phong 1
      reflection {
        0.8
        metallic
      conserve_energy
  normal {
      bump_map {
         jpeg "snake_tex4.jpg"
         bump_size 1
         interpolate 2
        map_type 3
      scale .47
      rotate <0, 40, 0>
   finish {ambient  -.055 phong .5 }}
Date: 13 Feb 2007 14:33:53
Message: <45d212a1$1@news.povray.org>
St. wrote:
> "Jim Charter" <jrc### [at] msncom> wrote in message
>>>the actual mesh.
>>UV mapping?
> faces!) :o)
I am not sure what you mean.
Date: 14 Feb 2007 03:41:55
Message: <45d2cb53@news.povray.org>
news:45d212a1$1@news.povray.org...
>>>the
>>>UV mapping?
>> though,
>> trillion
>> faces!) :o)
    Oh, well all I meant is that most people (I guess) would try and UV_map
the actual outer scales of a snake 'first', which seems a bit like walking
backwards on a high-poly  model when all you need to do is reverse the
routine. So I just UV_map the inside (see attached), export, and then open
PoseRay to give it a gold texture on the inside, and then apply the same
gold texture and bump_map to the outer surface -  rotate the bump_map until
satisfied, and it's done.
     My workflow is this:
       > Select faces
       > Select .UV_mapping.
       > Select Continue
       > Select Unfold
       > Export to .obj
       > Open .obj in PoseRay
       > Apply textures
     But yes, I used Wings...   ;)
           ~Steve~
Download 'UV_inside.jpg' (65 KB)
Preview of image 'UV_inside.jpg'
