POV-Ray : Newsgroups : povray.binaries.images : Ourobus Snake Server Time
1 Aug 2026 21:29:52 EDT (-0400)
  Ourobus Snake (Message 35 to 44 of 44)
Subject: Re: Update: Ouroborous Snake and Escher Snake
Date: 26 Oct 2006 09:03:21
Message: <4540b219$2@news.povray.org>
"Thomas de Groot" <t.d### [at] internlnet> wrote in message
news:453c699b$1@news.povray.org...
> "St." <dot### [at] dotcom> schreef in bericht news:453be7d1@news.povray.org...
>>    Ok, I think I've nailed this bump_mapping thingy.   ;)
>>   It was the only route I could take after trying loads of stuff with the
>> actual mesh.
>>      Comments welcome!
> Wow (too)!! Just give me one dozen of those and... eerrr... one dozen of
> those others.... Do you accept credit cards?
   LOL! It can be arranged Thomas...  ;o)
   ~Steve~
> Thomas
Date: 26 Oct 2006 09:03:24
Message: <4540b21c@news.povray.org>
"Smws" <smw### [at] poboxcom> wrote in message
news:web.453c289b6c10637dda53d9e40@news.povray.org...
>> the
>> actual mesh.
>>       Comments welcome!
>>         ~Steve~
> Wow! This looks really good! However you got the normal, it looks very
> much
> like scales. Did you make the bump_map yourself?
     Kind of. I found a nice snake skin texture on the net, but it was
fairly large. I played around with that for ages and couldn't get a good
result, so then thought about trying with a smaller image, so I cut out the
attached from the original and tried with that. It worked first time!  :oO
      Set yourself up a torus (whatever) and apply this:
         T_Gold_2A
    finish{
      diffuse 0.45
      ambient 0.035
      phong .5
      specular 0.6
      reflection {
        0.8
        metallic}
      conserve_energy}
      normal {
      bump_map {
         jpeg "snake_tex4.jpg"
         bump_size 1
         interpolate 2
        map_type 3}
        scale .47   rotate <0, 40, 0>}
        finish {ambient  -.055 phong .5 }}
       Have fun!
> Great image.
   Thanks!
    ~Steve~
> -Stefan
Download 'snake_tex4.jpg' (46 KB)
Preview of image 'snake_tex4.jpg'
Subject: Update: Single coil version
Date: 26 Oct 2006 09:03:33
Message: <4540b225@news.povray.org>
Last one, I promise! :o)
   This is a single coil version with Garnet eyes.
    ~Steve~
Download 'snakes_garnet.jpg' (165 KB)
Preview of image 'snakes_garnet.jpg'
Subject: Re: Update: Single coil version
Date: 28 Oct 2006 01:15:00
Message: <web.4542e698645287b3da53d9e40@news.povray.org>
>     ~Steve~
Well, don't stop on my account, they just keep getting better. Surely this
is just the kind of image that the POV-Ray news server is meant to host!
It seems from some of the previous messages that you make the rings in
reality. Is this true? Are you rendering it in POV-Ray for fun, or does it
really inform your design and construction? Do you make blueprints somehow
and use them for the metalwork? (of course, you can ignore these very nosy
questions if you wish, craftsmens secrest and all...)
If I was your client, I would want this one. I think the single coil is more
elegant and works better.
Definitly keep it up, and thanks for sharing. Do you happen to have a
website where you put POV-stuff?
-Stefan
Date: 29 Oct 2006 12:20:01
Message: <web.4544e29d645287b3156dd69f0@news.povray.org>
>     ~Steve~
Wow Steve. These rings are amazing. Great job. :)
Date: 30 Oct 2006 07:49:37
Message: <4545f4e1@news.povray.org>
news:web.4542e698645287b3da53d9e40@news.povray.org...
>>     ~Steve~
    Well, yes, I hope so!  :o)
   Yes, that's what I do, I design and make jewellery. I'm just about to
start making this single coil snake ring in silver, so I'll post an image or
two on my little personal website when it's finished.
  Well, I've found that I'm using PoV-Ray a lot more now for jewellery
design. Yes, it's fun! Last week I designed 5 rings and a pendant and
earring set. That was the best and most enjoyable weeks work I've done for
some time. Getting paid to play with PoV-Ray is good!  :o)
      Oh, I don't worry about that. Basically, there are no blueprints as
such for most common jewellery items, but when it comes to something that's
going to be an expensive design, then sure, you either draw it correctly, or
make an exact silver model so that the customer knows exactly what s/he is
getting.
> more
     It does work better. I was a little ambitious with my first snake...
  My pleasure. As long as my work is (sometimes) enjoyed, I'll keep on
goin'!  :o)
    Oh, now you've gone and said it Stefan. ;)  I don't at the moment, but I
now have many images, so I guess I should. I'll post a link sometime in the
near future.
     ~Steve~
> -Stefan
Date: 12 Feb 2007 15:24:09
Message: <45d0cce9@news.povray.org>
> actual mesh.
Steve, I for got to ask and now I am wondering, what did you use to do
the UV mapping?
Wings? ...or something else such as UVmapper?
Date: 12 Feb 2007 22:34:04
Message: <45d131ac$1@news.povray.org>
news:45d0cce9@news.povray.org...
>> the actual mesh.
> Steve, I for got to ask and now I am wondering, what did you use to do the
> UV mapping?
      Hey Jim, yes, I used Wings. I did it in reverse to the norm(?) though,
I mapped and unfolded the flat inside of the snake to give it the normal
gold texture, and then applied the bump_map to the outer, scaly, skin.
(Doing it this way, I saved a whole heap of time by not selecting a trillion
faces!) :o)
 //Material definitions =====
 // flat inside of snake
#declare Cube7_sep8_auv=texture{
  pigment{ colour Pink}
finish{
      diffuse 0.3
      ambient  -.055
      specular 0.6
      phong 1
      reflection {
        0.8
        metallic
      conserve_energy
// Snake skin
#declare Default=texture{ pigment{ colour Pink}
finish{
      diffuse 0.3
      ambient  -.055
      specular 0.6
      phong 1
      reflection {
        0.8
        metallic
      conserve_energy
  normal {
      bump_map {
         bump_size 1
         interpolate 2
        map_type 3
      scale .47
      rotate <0, 40, 0>
Date: 13 Feb 2007 14:33:53
Message: <45d212a1$1@news.povray.org>
St. wrote:
> "Jim Charter" <jrc### [at] msncom> wrote in message
>>>the actual mesh.
>>UV mapping?
> faces!) :o)
I am not sure what you mean.
Date: 14 Feb 2007 03:41:55
Message: <45d2cb53@news.povray.org>
news:45d212a1$1@news.povray.org...
>>>the
>>>UV mapping?
>> though,
>> trillion
>> faces!) :o)
    Oh, well all I meant is that most people (I guess) would try and UV_map
the actual outer scales of a snake 'first', which seems a bit like walking
backwards on a high-poly  model when all you need to do is reverse the
routine. So I just UV_map the inside (see attached), export, and then open
PoseRay to give it a gold texture on the inside, and then apply the same
gold texture and bump_map to the outer surface -  rotate the bump_map until
satisfied, and it's done.
     My workflow is this:
       > Select faces
       > Select .UV_mapping.
       > Select Continue
       > Select Unfold
       > Export to .obj
       > Open .obj in PoseRay
       > Apply textures
     But yes, I used Wings...   ;)
           ~Steve~
Download 'UV_inside.jpg' (65 KB)
Preview of image 'UV_inside.jpg'
