POV-Ray : Newsgroups : povray.binaries.images : WIP A kind greeble ? Server Time
26 Dec 2025 10:22:16 EST (-0500)
  WIP A kind greeble ? (Message 1 to 2 of 2)
Subject: WIP A kind greeble ?
Date: 18 Oct 2006 18:12:38
Message: <4536a6d6@news.povray.org>
I had previously had a go, at creating "content" that looked "meaningful" ,
without much joy.
Having seen the images from Zeger I thought YES !!! and WOW !!!. However I
couldn't get the macro to work.
So with the new (to me) thought of using subdivided cells to create the
"randomness" I have written a couple of macros.
The subdividing macro divides a given rectangle a number of times and sets
up the vectors for each corner of each created rectangle at all levels of
subdivision.
Another macro allows you to set up objects in the cells at the lowest level,
Object need to be able to fit in a box  { <-0.5, 0, -0.5>, <0.5, 1, 0.5> }
The output cells can be restricted to the shape of an arbitrary object that
crosses the y=0 plane. So your end "greebled plate" does not need to
rectangular.
A "coverage" percentage is also applied so you can fill only a proportion of
cells if you wish.
A setup macro is called to handle the getting of the required object,
scaling and texturing (so you can tailor all that to what you're trying to
produce.
The attached dodeca~ and hexagon use the same array of objects for each
face, but with differing parameters.
The "roadways" can be created for the cells at any level.
Because all the corners are known, you know the shape/size of each cell so
you can apply your own rules to suit e.g. have multiples in a cell or decide
not to bother if the shape is silly.
The piccies are only test pieces. (One day I'll build a nice interstellar
thingy)
Thoughts welcome  ... Bob
Download 'trial4a_k.jpg' (84 KB) Download 'hexagon2_same.jpg' (14 KB)
Preview of image 'trial4a_k.jpg'
Preview of image 'hexagon2_same.jpg'
Subject: Re: WIP A kind greeble ?
Date: 19 Oct 2006 05:41:45
Message: <45374859@news.povray.org>
"Bob Frew" <bob### [at] ntlworldcom> wrote in message
news:4536a6d6@news.povray.org...
>without much joy.
> subdivision.
> level,
> that crosses the y=0 plane. So your end "greebled plate" does not need to
> rectangular.
> of cells if you wish.
> produce.
> decide not to bother if the shape is silly.
> thingy)
Looks like something electronic? Exposed circuitboards in the open cavity of
a robot/android, perhaps? Well, whatever people use it for, I like it :)
The largest otem you posted looks like maybe a nanite? The second, some sort
of electronic pass or key?
