POV-Ray : Newsgroups : povray.binaries.images : Zeger's Greebles revisited (attn. Thomas De Groot) Server Time
10 Sep 2025 16:50:16 EDT (-0400)
  Zeger's Greebles revisited (attn. Thomas De Groot) (Message 1 to 7 of 7)
Subject: Zeger's Greebles revisited (attn. Thomas De Groot)
Date: 16 Oct 2006 05:56:34
Message: <45335752@news.povray.org>
Mainly for Thomas but all are welcome to join in.
I couldn't find my original changes to greebles.inc so I started working on
a fresh version last night. The only thing that I've changed is line 31 (see
attached) and now greebletest.pov renders but we still appear to have some
problems (ignoring the multiple error messages which I will fix shortly) in
that the left side of the cylindrical object seems to be dissolving away -
any ideas what might be causing this?
Secondly, any chance of you translating the comments into English so that I
have a fighting chance of understanding Zeger's thinking while he wrote the
original code.
John
"Please refrain from fondling the nymphs and sprites
- it makes them giggly and skittish.
Thank you for your co-operation.
The Management"
Download 'greebletest.jpg' (36 KB) Download 'greebles-inc_truncated.txt' (2 KB)
Preview of image 'greebletest.jpg'
Subject: Re: Zeger's Greebles revisited (attn. Thomas De Groot)
Date: 16 Oct 2006 10:43:01
Message: <45339a75$1@news.povray.org>
That looks very good!
I can translate the comments and post them back of course (except is Zeger
is more rapid ;-) )
Thanks a lot for the good work!
Date: 16 Oct 2006 10:54:06
Message: <45339d0e@news.povray.org>
"Thomas de Groot" <t.d### [at] internlnet> wrote in message
news:45339a75$1@news.povray.org...
> is more rapid ;-) )
> Thomas
More to come as I get my head around exactly how the various macros interact
with each other. The change I made is just a quick fix; I'm sure there's a
better way of doing it (possibly using Diepte which as far as I can see
limits the recursion depth)
John
The Management"
Date: 16 Oct 2006 13:16:39
Message: <4533be77$1@news.povray.org>
> is more rapid ;-) )
I very much doubt I will be, very little time at the moment :(
sorry !
cu!
Date: 16 Oct 2006 13:29:50
Message: <4533c18e$1@news.povray.org>
"Doctor John" <doc### [at] linuxmailorg> wrote in message
news:45339d0e@news.povray.org...
> > is more rapid ;-) )
> > Thomas
as far as I can remember, that's right.
Actually, I believe I *did* kind of fix it, you know!  The problem was that the
points on the polygons (the greeble-cells actually) were too close together,
which caused the official POV-Ray to stop with an error.  However, if I scale
the location of the points by, let's say 10000, and then scale the polygon by
1/10000, then it worked okay... not a perfect fix of course, and won't work in
every case, but the only other way is to check every point of the polygon with
every next point, in a *new* loop before the loop where the polygon is created.
Might slow things down, cause you'd have to do that for every greeble-cell
(which can be quite a few, depending on the value Diepte).
the code to change for the "fix" is, I believe, in the macro RoundPrism(), right
at the end:
change:
  #if (Aantal2>2)
  polygon {
   Aantal2,
   #local Tel=0;
   #while (Tel<Aantal)
    #ifdef(Points2[Tel])<Points2[Tel].x,Points2[Tel].y>
    #local Tel=Tel+1;
   translate -z*H
into:
  #if (Aantal2>2)
  polygon {
   Aantal2,
   #local Tel=0;
   #while (Tel<Aantal)
    #ifdef(Points2[Tel])<Points2[Tel].x,Points2[Tel].y>*100000
    #local Tel=Tel+1;
   scale 1/100000
   translate -z*H
and it should work.
Hope that helps :)
cu!
Subject: Re: Zeger's Greebles revisited (attn. Thomas De Groot): translation posted
Date: 17 Oct 2006 03:49:41
Message: <45348b15@news.povray.org>
I have posted a revised version of Zeger's greebles.inc in p.b.s-f
I corrected the code following Zeger's post above, and translated the
comment lines. If any further doubts, just yell.
Date: 17 Oct 2006 10:04:09
Message: <4534e2d9$1@news.povray.org>
news:45348b15@news.povray.org...
> Thomas
Thanks for the work. Hopefully it should be plain sailing from here on in
John
The Management"
