POV-Ray : Newsgroups : povray.binaries.images : Another failed render (~300 KB) Server Time
26 Dec 2025 12:12:15 EST (-0500)
  Another failed render (~300 KB) (Message 1 to 10 of 24)
Subject: Another failed render (~300 KB)
Date: 7 Oct 2006 07:39:37
Message: <452791f9@news.povray.org>
The concept was simple: a stone block sitting in a pool of rippling
water, with some assorted glassare on top.
Well, I made the pool and the stone block. But, as you can see, the
results were pittiful to say the least. (The last two even use an
extremely slow volumetric cloud algorithm - not that you can tell!)
I despare sometimes. I can't made even the simplest thing look *good*!
 >_< This just looks pathetic...
Can *anybody* tell me how to make this look cool like everybody else's
renders do??
Download 'glassware01.jpg' (91 KB) Download 'glassware02.jpg' (82 KB) Download 'glassware03.jpg' (63 KB) Download 'glassware05.jpg' (51 KB) Download 'glassware06.jpg' (93 KB)
Preview of image 'glassware01.jpg'
Preview of image 'glassware02.jpg'
Preview of image 'glassware03.jpg'
Preview of image 'glassware05.jpg'
Preview of image 'glassware06.jpg'
Subject: Re: Another failed render (~300 KB)
Date: 7 Oct 2006 08:31:48
Message: <45279e34$1@news.povray.org>
452791f9@news.povray.org...
> renders do??
did you visit Christoph's water tutorial ?
http://www.imagico.de/pov/water/index.html
Marc
Date: 7 Oct 2006 09:15:52
Message: <4527a888$1@news.povray.org>
>> renders do??
No - but thanks for the link...
Date: 7 Oct 2006 09:35:38
Message: <4527ad2a@news.povray.org>
Well I have a few suggestions:
1/ a perfect cube always looks very fake, use a slightly irregular shape
like a superellipsoid or isosurface
2/ it's easy to say this after the fact, but the human eye is extremely
forgiving of reflections in bumpy surfaces, so you really shouldn't worry
about making a complex sky, just something flat that has the right colours.
But it sounds like you learnt this the hard way.
3/ think about the size of the ripples regarding the scale of your scene,
these ones are huge but smooth (particularly in the last image). Smooth
usually means very small ripples, which would make the stone block about 1cm
big! I'd suggest use much much smaller ripples, so the surface is nearly
flat. if you want a dramatically wavey surface for this scale you need
something less smooth, the wrinkles pattern is sometimes pretty good for
this, or granite (inverted to make spikey waves).
4/ water material - a physically correct water is simply: pigment{rgbt
1}finish{reflection{0,1 fresnel}}interior{ior 1.33 fade_colour ...
fade_power 2 fade_distance ...}, there's a lot of tweaks you can do but that
should get you something good. Basically it's transparent, refractive, the
reflections obey fresnel so there's no need to tweak them, and if you want
to colour it you should use fade_colour not pigment because the colour
should be throughout the material not just at the surface.
5/ stone material - always reference a real material, in your present scene
I can't tell if it's meant to be a polished stone like marble, or a more
natural rough finish. A realistic rough finish is easier: just give it a
noisy normal, like normal { granite -.2 }, and no specular or phong. A
realistic smooth finish is difficult because smooth things look fake in CG,
I'd suggest choosing a stone with a very distinctive pattern, like marble or
something. And on that topic note that pov's granite pattern looks more like
marble than the marble pattern...
6/ use global_settings { assumed_gamma 1 }, it screws up all the colours in
the scene so you'll need to adjust them, but it make reflections and
lighting look more realistic.
Hope that's helpful and not patronising :)
I'd be happy to knock together an example scene of how I'd do it if you
think it would help?
Tek
http://evilsuperbrain.com
"Orchid XP v3" <voi### [at] devnull> wrote in message
news:452791f9@news.povray.org...
> renders do??
Date: 7 Oct 2006 09:41:21
Message: <4527ae81@news.povray.org>
news:4527ad2a@news.povray.org...
> that should get you something good. Basically it's transparent,
> refractive, the reflections obey fresnel so there's no need to tweak them,
> and if you want to colour it you should use fade_colour not pigment
> because the colour should be throughout the material not just at the
> surface.
Doh! and of course use conserve_energy in reflections, that's vital!
Tek
Date: 7 Oct 2006 10:03:03
Message: <4527b397$1@news.povray.org>
Cube is a placeholder, yes. I was attempting to get the stone texture
and the water to look right first. (I intend to replace it with a
rounded cube later.)
I only used the complex volumetric sky because I already had one from
another scene that had the right colours, and I couldn't come up with a
static pigment with anything approaching the right colours.
For my trouble, I ended up with an entire scene that's bright blue. (Why
does the real world not do this BTW? The real sky is blue...)
OK. I'm currently investigating Christoph's waver macro. Seems to
produce big fractal-like waves. (I'd actually like the ripples to
radiate from the stone block and follow its shape eventually...)
The water *itself* is a fairly simple thing, as you say. It's
transparent, refractive and reflective. So basically it doesn't look
like anything by itself... gotta have something nice to reflect.
My main problem seems to be getting a decent sky. :-S
The look I'm eventually going for is water-polished rock. Maybe
limestone or something. So I probably just need to make it look slightly
lumpy... and get better colours...
I wouldn't have thought assumed_gamma 1 would have *any* effect...
surely that just means that each colour component is raised to the power
of 1 before being output?
Date: 7 Oct 2006 10:47:38
Message: <4527be0a@news.povray.org>
news:4527b397$1@news.povray.org...
Spheres usually make better placeholders when tweaking materials IMO, the
hard edges of the cube mean you don't see how it interacts with the light at
all angles, making it very hard to tune effects like specular.
Well if you want ripples radiating from the block why are you looking at a
macro for fractal like waves?
Radiating from a block is a bit awkward, I suggest basing it on a function,
like:
normal { function { sin(8*pi*sqrt(pow(max(x-1,0),2)+pow(max(z-1,0),2))) } }
that should give nice "distance from a square" based ripples, though if you
plan on changing the shape of your stone it might not look so good.
Nope I disagree, if you have a realistic water material from this angle it
would be almost completely transparent, the reflection would only show up on
the top edge of the ripples (see attached picture). What's important is the
fall-off of the reflection, which should be either reflection{.01,1 falloff
5} to fake it or reflection{0,1 fresnel} if you have a realistic ior.
Yeah that confused the hell out of me when I first encountered it. The
simple answer is that pov knows what your display gamma is, or rather it has
a default of 2.2. If you don't say "assumed_gamma" it doesn't gamma correct
from the linear colour space of the pov scene to the non-linear gamma of the
monitor. assumed_gamma essentially tells pov what the gamma space of your
scene is, which is a very bizarre thing to do since pov does linear
calculations on light so by definition it has a gamma of 1, it's very
counter intuitive but it works!
Anyway I couldn't resist the urge to have a go at a similar scene myself, so
here's a picture and the source is in p.b.s-f. Most importantly note that
the reflection on the water is very subtle, without the ripples you'd hardly
see the water surface at all.
Tek
Download 'rock mat test.jpg' (62 KB)
Preview of image 'rock mat test.jpg'
Date: 7 Oct 2006 11:16:23
Message: <4527c4c7$1@news.povray.org>
I guess so...
Because it works by placing multiple concentric rings of ripples
semi-randomly. Now if I place the centers of those ripples to coincide
with the edges of the block, the ripples will follow its outline. (This,
apparently, is how the Real World(tm) works...)
Mmm, OK. In that case, my water is going to be completely black...
Is IOR=1.3 "realistic"?
Here's a random question: does LCD require gamma correction?
0__0
OMG... you created something 17,826% better than what I had in about 20
seconds!
Date: 7 Oct 2006 11:36:15
Message: <4527c96f$1@news.povray.org>
Orchid XP v3 nous apporta ses lumieres en ce 07/10/2006 11:16:
>> the hard edges of the cube mean you don't see how it interacts with
>> the light at all angles, making it very hard to tune effects like
>> specular.
> I guess so...
>> at a macro for fractal like waves?
>> angle it would be almost completely transparent, the reflection would
>> only show up on the top edge of the ripples (see attached picture).
>> What's important is the fall-off of the reflection, which should be
>> either reflection{.01,1 falloff 5} to fake it or reflection{0,1
It is, it's close to the real ior of water. Pure water ior is 4/3. Salt or sea
water's ior is close to 1.4.
>> myself, so here's a picture and the source is in p.b.s-f. Most
>> importantly note that the reflection on the water is very subtle,
>> without the ripples you'd hardly see the water surface at all.
> 0__0
> seconds!
Fade_power should be 1 to be physicaly correct. A value of 2 is perfect for a
light source, double the distance and get 1/4 the lighting, not for fading
trough some substance. Light absorbtion trough a substance is linearly
proportional to the thicknessm, double the thickness and the effect double, it
don't quadruple.
Any way, for water, fade_distance is relatively large.
No matter how good she looks, some other guy is sick and tired of putting up
with her shit.
	Men's Room, Linda's Bar and Grill, Chapel Hill , NC
Date: 7 Oct 2006 12:13:16
Message: <4527d21c@news.povray.org>
4527c96f$1@news.povray.org...
for a
double, it
> don't quadruple.
I don't agree about fade power in water :
daylight rays have to get twice (down and back up) through water before
reaching your eye so double the depth quadruple the thickness
Marc
