POV-Ray : Newsgroups : povray.binaries.images : crumbled plaster for an object Server Time
10 Oct 2024 12:16:56 EDT (-0400)
  crumbled plaster for an object (Message 1 to 3 of 3)
Subject: crumbled plaster for an object
Date: 24 Sep 2006 06:36:42
Message: <45165fba@news.povray.org>
I tried to create a sort of crumbled plaster for an object.
Using an intersection of an outer hull and an isosurface.
Unfortunately i run into the problem of having dark areas where i do not
expect them. The plaster seems to be just a hull and not to be solid.
in past i could get rid of these effects in ISOs by adjusting the
accuracy & max_gradient settings. But it did not work in this case.
I noticed that the bad effect decreases by lowering the dimensions of
the contained_by box converging the intersections dimensions.
Does anybody has an idear how to solve this?
It would be great if someone could help, cause i'm somewhat perplexed at
the moment...
Regards
Joerg
---8<---------8<----------8<---------8<---------8<---------8<----------8<---------8<------
// The Object to be plastered
union{
  box{<-1,0,-1>,<1,1,1>}
  sphere{<0,1,0>,1}
  pigment{color Red}
// Funtion for plaster
#declare L10=function{
  pigment{
	bozo
	turbulence 1.25
	scale <4,4,4>
	color_map {
	 [0 rgb 1]
	 [1 rgb 0]
// the plaster
#declare B1 = intersection{
  isosurface {
     function { L10(x,y,z).red - 0.5 }
     accuracy     0.00001	// 0.05 the smaller the slower to render
     max_gradient 1.551 		// 2    the smaller the faster to render
     contained_by{box{<-12,-12,-12>,<12,12,12>}}
//    open
  union{
   box{<-1.05,0,-1.05>,<1.05,1.05,1.05>}
   sphere{<0,1,0>,1.05}
  pigment{ color White  }
object{B1}
Download 'test-a.jpg' (21 KB) Download 'test-b.jpg' (21 KB)
Preview of image 'test-a.jpg'
Preview of image 'test-b.jpg'
Subject: Re: crumbled plaster for an object
Date: 24 Sep 2006 07:15:00
Message: <web.4516688cd9522b052738fe000@news.povray.org>
> the moment...
> Regards
> Joerg
> union{
>   sphere{<0,1,0>,1}
>   pigment{color Red}
>   pigment{
>  bozo
>  turbulence 1.25
>  scale <4,4,4>
>  color_map {
>   [0 rgb 1]
>   [1 rgb 0]
> // the plaster
>   isosurface {
> //    open
>   union{
> object{B1}
I suspect this is because you need to add ALL_INTERSECTIONS to your
isosurface to do CSG.
Also, do you get any warnings about max_gradient?
Sean
Date: 24 Sep 2006 07:55:04
Message: <45167218$1@news.povray.org>
> Hi,
> Sean
Hi Sean,
that was it, i added 'all_intersections' and id works :)
Thanks a lot
Joerg
