POV-Ray : Newsgroups : povray.binaries.images : friday glass (png ~280k) Server Time
18 Aug 2025 07:56:18 EDT (-0400)
  friday glass (png ~280k) (Message 1 to 5 of 5)
Subject: friday glass (png ~280k)
Date: 18 Aug 2006 18:11:19
Message: <44e63b07@news.povray.org>
started out as a pen doodle less than 1 inch wide on my notebook.
originally pov'd it with a 3x3 grid of these with varying "phases" and
colors, didn't really like it, so i removed the rop and bottom rows, and
rendered it at 1200x400 (then cropped off some extra grey plane)
the only interesting parts are:
#declare n1 = normal_map {
#local n = 10;
#local cn = n;
  #while (n > 0)
   [1/cn granite 0.025 scale <1, 0.1, 0.1> rotate (360/cn * n)*z]
   #local n = n - 1;
#declare f1 =
finish {
  specular 1
  roughness 0.001
  phong 0.5
  phong_size 140
  diffuse 0.5
  reflection {
   0.1, 0.8 fresnel on
#macro colored_glass_interior (theColor)
  interior {
   ior 1.65
   fade_power 1001
   fade_distance 0.08
   fade_color color theColor
Download 'squarewave.png' (230 KB)
Preview of image 'squarewave.png'
Subject: Re: friday glass (png ~280k)
Date: 18 Aug 2006 18:14:36
Message: <44e63bcc@news.povray.org>
Ross wrote:
> #declare n1 =
> #declare f1 =
which all then get used like this:
object {...
    pigment { rgbt <1, 1, 1, 1> }
    finish {f1}
    normal {
     average
     normal_map {n1}
   interior { colored_glass_interior(glasscolor) }
Date: 19 Aug 2006 11:15:01
Message: <web.44e72a634bbfd18cf43b014e0@news.povray.org>
> #local n = 10;
> #local cn = n;
>   #while (n > 0)
>    [!1/cn! granite 0.025 scale <1, 0.1, 0.1> rotate (360/cn * n)*z]
>    #local n = n - 1;
>   #end
I've marked a suspicious spot with exclamation marks;
you probably intend to have 1/n there?
jussi
Date: 19 Aug 2006 12:09:46
Message: <44e737ca@news.povray.org>
jute nous apporta ses lumieres en ce 19/08/2006 11:12:
>> #local n = 10;
>> #local cn = n;
>>   #while (n > 0)
>>    #local n = n - 1;
>>   #end
> jussi
He's using that in an average pattern. In that case, it's perfectly OK to have
each entry share the same value there, it's a ponderation value. That way, all
normals have the same impact.
 From the documentations:
Technically average is not a pattern type but it is listed here because the
syntax is similar to other patterns. Typically a pattern type specifies how
colors or normals are chosen from a pigment_map, texture_map, density_map, or
normal_map , however average tells POV-Ray to average together all of the
patterns you specify. Average was originally designed to be used in a normal
statement with a normal_map as a method of specifying more than one normal
pattern on the same surface. However average may be used in a pigment statement
with a pigment_map or in a texture statement with a texture_map or media density
with density_map to average colors too.
When used with pigments, the syntax is:
AVERAGED_PIGMENT:
     pigment
         pigment_map
             PIGMENT_MAP_ENTRY...
PIGMENT_MAP_ENTRY:
     [ [Weight] PIGMENT_BODY ]
Where Weight is an optional float value that defaults to 1.0 if not specified.
This weight value is the relative weight applied to that pigment. Each
PIGMENT_BODY is anything which can be inside a pigment{...} statement. The
pigment keyword and {} braces need not be specified.
  "Having a smoking area in a restaurant is like having a peeing area in a pool."
   --Thomas Pfeffer, American Heart Association
Date: 21 Aug 2006 10:54:44
Message: <44e9c934@news.povray.org>
"jute" <nomail@nomail> wrote in message
news:web.44e72a634bbfd18cf43b014e0@news.povray.org...
> > #local n = 10;
> > #local cn = n;
> >   #while (n > 0)
> >    #local n = n - 1;
> >   #end
> jussi
yep, like alain said, i'm using this in an average later. if n=8, the normal
looks more like a cross-hatched pattern and i kind of liked it. i might
rerender it with that again.
