POV-Ray : Newsgroups : povray.binaries.images : cargo-ship Server Time
2 Aug 2026 03:10:13 EDT (-0400)
  cargo-ship (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: cargo-ship
Date: 10 Jul 2006 03:36:55
Message: <44b20397$1@news.povray.org>
I think this might be real nice as a space Monolith.  Change the texture to
stone and add a little spacecraft investigating...
POV Tips and Hints at ...
http://povman.blogspot.com/
Date: 10 Jul 2006 08:10:01
Message: <web.44b241b8b6abe218559ef8600@news.povray.org>
> it might be a bit dark and maybe the shapes aren't very clear, but it's
> a WIP :)
Heck, don't make it brighter - the lighting is simply lovely. You can
accessorize if you like, but it SHOULD be a bit dark. Looks too good that
way to change, IMO.
-s
5TF!
Date: 10 Jul 2006 15:45:13
Message: <44b2ae49$1@news.povray.org>
"stm31415" <sam### [at] cscom> wrote in message
news:web.44b241b8b6abe218559ef8600@news.povray.org...
> way to change, IMO.
thanks :) but still, I think it's too hard to see what it is :(
Some better texturing, and extra modelling might fix that though :)
cu!
Date: 10 Jul 2006 15:46:09
Message: <44b2ae81$1@news.povray.org>
"POVMAN" <s### [at] acom> wrote in message news:44b20397$1@news.povray.org...
you're saying it looks like a rock? :-/
cu!
Date: 11 Jul 2006 18:50:11
Message: <44b42b23@news.povray.org>
>>to stone and add a little spacecraft investigating...
Looks like something out of the first Alien movie to me.
> cu!
Bill Hails
http://billhails.net/
Date: 14 Jul 2006 13:23:07
Message: <44b7d2fb$1@news.povray.org>
Great stuff, Zeger!!!!!!!!!!!!!!!
Need more of it! Missing: Tiny ships (maintenance ships or shuttles) in
front or around it to show the real big size of the cargo ship! And here and
there a few lightened windows, visible only in the shadowed zones, would be
an important add-on.
I created a small personal shuttle, do you want to get the source code? You
could use it then.
I use these shuttles in my SPACE CARRIER scenes. The shuttles would require
only small cylindrical flight-in holes in the hull of bigger ships. The
shuttle is just made for transporting humans on short-range routes, only
space, no planetary targets. The hull is made of industrially mass-produced
diamond, and contains 10 seats. Controls are displayed on the inside of the
tubular shuttle and pilot's movements and brain readings control that
shuttle. No real controls are required.
I also have developed a number of spaceship turrets. Those, as well, i would
offer you for usage. Shuttle and turrets are published in this newsgroup.
Best greetings,
Sven
"Zeger Knaepen" <zeg### [at] povplacecom> schrieb im Newsbeitrag
news:44b167c9@news.povray.org...
This is more or less a remake of another cargo-ship I did a few years ago:
http://www.povplace.com/gallery/SciFi%20-%20Own/12.jpg
it might be a bit dark and maybe the shapes aren't very clear, but it's a
WIP :)
some post-processing was done (the bloom-effect)
of course, my greeble-macros were used :)
Render Statistics
Image Resolution 1280 x 960
Pixels:          1305600   Samples:         5333876   Smpls/Pxl: 4.09
Rays:            5333876   Saved:                 0   Max Level: 1/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Cone/Cylinder               1610446888         4084508      0.25
CSG Intersection             184806611        12582426      6.81
CSG Union                    277630042        20192408      7.27
Plane                            19792           19792    100.00
Polygon                       92822463         5084355      5.48
Prism                        347251725        42223520     12.16
Prism Bound                 1194032891       938356522     78.59
Sphere                      2199896580          805172      0.04
Superellipsoid               272814600         1035281      0.38
Triangle                     757192868         3598564      0.48
Bounding Box                 426177716       115065240     27.00
Light Buffer                2520053752       827941469     32.85
Vista Buffer                 623218064       381138150     61.16
Roots tested:              39941693   eliminated:                    0
Calls to Noise:            56650698   Calls to DNoise:        53931352
Shadow Ray Tests:          33788309   Succeeded:               3888446
Smallest Alloc:                  18 bytes
Largest  Alloc:              130256 bytes
Peak memory used:         517379801 bytes
Total Scene Processing Times
  Parse Time:    0 hours  1 minutes 49 seconds (109 seconds)
  Photon Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Cloth Time:    0 hours  0 minutes  0 seconds (0 seconds)
  Mechsim Time:  0 hours  0 minutes  0 seconds (0 seconds)
  Render Time:   1 hours 16 minutes  7 seconds (4567 seconds)
  Postpr. Time:  0 hours  0 minutes  0 seconds (0 seconds)
  Total Time:    1 hours 17 minutes 56 seconds (4676 seconds)
CPU time used: kernel 8.47 seconds, user 2430.61 seconds, total 2439.08
seconds
Render averaged 503.80 PPS over 1228800 pixels
hardware: Athlon XP 2500+, 1GB DDR, Windows XP, rendered with MegaPOV.
cu!
Date: 14 Jul 2006 13:35:01
Message: <44b7d5c5$1@news.povray.org>
"Sven Littkowski" <sve### [at] jamaica-focuscom> wrote in message
news:44b7d2fb$1@news.povray.org...
tnx :)
in
ah, that's a very good idea !
> And here and
would be
yep, that already was on my to do list :)
code? You
> could use it then.
I'm a fundamentalist, I have to make everything myself, or I consider it
cheating :)
so, thanks, but no :)
I would like to see some images though !
cu!
Date: 14 Jul 2006 13:42:35
Message: <44b7d78b@news.povray.org>
news:44b7d5c5$1@news.povray.org...
Check this newsgroup. They are published here. Search for my name, or for
SPACE CARRIER.
Later,
Sven
Date: 14 Jul 2006 14:21:35
Message: <44b7e0af$1@news.povray.org>
Looks like they're transporting a full load of greebles to the outer rim!
Date: 14 Jul 2006 15:17:43
Message: <44b7edd7@news.povray.org>
"Bryan Valencia" <pov### [at] spamgourmetcom> wrote in message
news:44b7e0af$1@news.povray.org...
rim!
greebles are needed everywhere! :p
cu!
