POV-Ray : Newsgroups : povray.binaries.images : New Penrose Tile Macros Server Time
18 Aug 2025 12:28:55 EDT (-0400)
  New Penrose Tile Macros (Message 1 to 2 of 2)
Subject: New Penrose Tile Macros
Date: 6 Jul 2006 14:05:39
Message: <44ad50f3@news.povray.org>
After looking at my other Penrose macros, and always being annoyed that
I needed an array of size [xtiles][ztiles][recursion_depth] to eliminate
all the duplicates that the standard rules generate, I figured out how
to...  (A little google here and there helped too, but surprisingly
little, everybody just expands the tiles the way I used to.)
Split each kite, dart, or rhomb into a pair of triangles.  The new
triangles do not overlap each other when expanded from an old set, so
that huge array can disappear. As the new sets of tiles are generated,
the new edges will now leave the border of the old set by 1/2 a tile or
less.  I think the context parameters will allow the old semi-fractal
tile perimeters to be generated, but I haven't tried it yet.
For these test images, I stripped off all the curvy tile decorations of
the last images, but did put that new context parameter to use.  The
first image is just two rhombs, a kite, and a dart expanded a few times.
The edges of each triangle are shown, but each rhomb, kite, or dart is a
single color.
The second image is a cartwheel pattern.  The dark spokes will travel
off to the far edges of the plane.  Each spoke can be reflected, and 10
spokes make for 1024 combinations, but only 56 different ones, the rest
are reflections or rotations of those 56.  (The light colored ring in
the center determines all this, and is called a decagon.) This
particular cartwheel pattern is the only one that can be properly filled
at the center.  Other patterns to to get exact 5 way symmetry from the
central point out are the sun and star, inflated and even number of
times to what ever level you desire.
The third image I just did in the last few hours, and wanted to get the
pentagon tiling that has been seen around here on a regular basis.  It
might be interesting to put curves all over it, but I resisted to keep
the demonstration code shorter and simpler.
I'll put the code in p.t.s-f...
Jon
Download 'penrose0.png' (112 KB) Download 'penrose1.png' (384 KB) Download 'penrose2.png' (95 KB)
Preview of image 'penrose0.png'
Preview of image 'penrose1.png'
Preview of image 'penrose2.png'
Subject: Re: New Penrose Tile Macros
Date: 8 Jul 2006 11:15:01
Message: <web.44afcb035bc01609da8e81320@news.povray.org>
Thanks Jon, I'm going to download the macros. And thanks for the fine
example of the cartwheels.
