POV-Ray : Newsgroups : povray.binaries.images : New attempt at a cratered asteroid Server Time
22 Mar 2026 03:47:53 EDT (-0400)
  New attempt at a cratered asteroid (Message 1 to 10 of 24)
Subject: New attempt at a cratered asteroid
Date: 25 Jun 2006 12:50:23
Message: <449ebecf@news.povray.org>
High!
Several days have passed, and I tried to improve the appearance of my
asteroidal moon, mostly be applying additional 3D noise to the surface
(in the case of the image attached here, by replacing the original
noise_3d(x, y, z) by noise_3d(pow(x, 3), pow(y, 3), pow(z, 3)), which in
fact added subtle waves to the terrain relief).
But still the problem is, that with the crackle pattern (with form set
to <n, 0, 0>), the craters are in fact "bubbles" of empty space
distributed randomly inside the raw isosurface moon body and not
necessarily cut in half by its surface, so that many craters still are
gaping holes rather than shallow depressions.
How can I get rid of this? Is there something like UV mapping for
isosurfaces which guarantees that only craters cut in half by the
surface are generated?
Is it possible to write a "core function" which, on the x-y plane,
generates a roughly symmetric (perhaps slightly turbulated)
cross-section of a crater, with terraced walls, a rim higher than the
surrounding terrain and even a central peak, which then is transferred
to a circular structure by applying trigonometric functions (?), which
in turn are distributed randomly (also with random variations in depth,
diameter, terracing and height of central peak) across the existing
asteroid surface?
Where can I find the mathematical resources to design such a function?
See you in Khyberspace!
Yadgar
Now playing: Pirates of Love (Zara)
Download '2006-06-24 michatopia, moon .jpg' (20 KB)
Preview of image '2006-06-24 michatopia, moon .jpg'
Subject: Re: New attempt at a cratered asteroid
Date: 25 Jun 2006 14:38:12
Message: <449ed814@news.povray.org>
> High!
You could create the isosurface without holes then use trace() and
difference out the craters, but that doesn't help with the rims.
You could use trace and a blob rather than an isosurface, but again
the rims are tricky (or impossible).
You might be able to add the crackle pigment as a function to
the isosurface, but I'm not sure how that would turn out.
> asteroid surface?
> Yadgar
Bill Hails
http://billhails.net/
Date: 25 Jun 2006 18:33:28
Message: <449f0f38$1@news.povray.org>
High!
Interesting approach... perhaps I would even be able to generate halfway
believable rims!
This is exactly what I did in my current attempts!
Yadgar
Date: 25 Jun 2006 21:01:16
Message: <449f31dc$1@news.povray.org>
> High!
For future reference, when greeting people in English, the proper
spelling of it is "Hi!" not "High!"  They are both pronounced the same,
but the meanings are completely different.
Just thought you might like to know.  I understand we have a lot of
people here that speak English as a second, or even third or fourth
language, and I most of them want to be told when they say something
wrong or that doesn't make sense.
-DJ
Date: 25 Jun 2006 22:15:00
Message: <web.449f4297559e4b454daddc090@news.povray.org>
Thought I'd have a go at this one...
// Asteroid
#version 3.6;
#default{finish{ambient 0}}
#global_settings{assumed_gamma 1.0 max_trace_level 5}
#declare f_bozo1 = // similar to noise3d
function{pigment{bozo scale 0.5 color_map{[0 color rgb 0] [1 color rgb 1]}}}
#declare f_craters =
function{
  pigment{
    crackle form <1.2, 0, 0> // never really played with this one, thaks
Yadgar!
    scale 0.3
    color_map{
      [0.00 color rgb 1.00] // centre of crater, lowest part
      [0.30 color rgb 0.80] //
      [0.35 color rgb 0.40] // rim, higher than surrounding area
      [0.40 color rgb 0.5] // level of area outside the crater
      [1.00 color rgb 0.5]
the f_craters function is subtracted from the basic asteroid shape, so the
lowest points get the highest numbers, since you are subtracting more.
isosurface{
  function{
    (x*x)+(y*y*1.8)+(z*z*1.5)-1 // basic sphere function, scaled to be more
elliptical
    +f_bozo1(x,y,z).red*0.35 // deforms the ellipse shape
    +f_craters(x,y,z).red*0.05 // adjust the '*0.05' part to change the
depth of the craters
  contained_by{box{<-1, -1, -1>, <1, 1, 1>}}
  threshold 0
  accuracy 0.001
  max_gradient 4
  texture{pigment{color rgb 1} finish{diffuse 0.6}}
light_source{<-10, 10, -5> color rgb 1}
light_source{< 10, -10, -5> color rgb<0.2, 0.4, 1.0>*0.25}
camera{
  location <0, 1, -4>
  up y*(image_height/image_width)
  right x
  sky y
  look_at <0, 0, 0>
  angle 36
// -------------------------------------------------- end of file
Download 'asteroid.jpg' (6 KB)
Preview of image 'asteroid.jpg'
Date: 26 Jun 2006 03:09:43
Message: <449f8837$1@news.povray.org>
A potato-cheese with holes! Delicious! Nyam!
Doesn't looks very realistic. Might be, the crater edges are to straight.
And the entire object (asteroid and craters) is too regular, somehow. Not in
shape, but in surface characteristica. Too plain. Too smooth.
I believe you would be well-advised to consult photos of asteroid or moons
surfaces to get some good ideas. Surfaces are not really plain but bear tiny
difference in surface heights and surface roughness.
But your project is promising. Go on, and you will create a great model of
an asteroid!
Greetings,
Sven
Date: 26 Jun 2006 09:27:02
Message: <449fe0a6$1@news.povray.org>
High! ;-))
> For future reference, when greeting people in English, the proper spelling
Of course I know... but I use "High!" deliberately as a kind of oxymoron to
indicate my preferred state of mind , which is, by the way, not induced by
any chemical additives, but by such mindblowing things like raytracing,
electronic organs, extrasolar planets and Afghanistan!
Yadgar
Date: 26 Jun 2006 16:26:14
Message: <44a042e6$1@news.povray.org>
High!
Yes, I've seen this on close-up NEAR photos of (433)Eros... and I had
some headache to find out how to add such small-scale noise to the
surface! Should I try noise_generator_3d rather than noise_3d?
Yadgar
Date: 26 Jun 2006 18:37:37
Message: <44a061b1@news.povray.org>
> High!
>> same, but the meanings are completely different.
> Of course I know... but I deliberately use "High!" as a little pun to
> indicate my favourite state of mind... which, by the way, is not induced
> by hemp products, but by such mindblowing things and experiences like
> raytracing, electronic organs, extrasolar planets, swamp mud orgies and
> Afghanistan!
> Yadgar
> P. S. Micro$oft Outlook Express sucks!!! I tried to post this already
> this afternoon (CET) from a workplace computer, which of course runs
> under Windoze... but it didn't show up at all on the server!
Still using Thunderbird 1.0! That's an antique. Newest is 1.5.0.4.
Both of your messages made it trough.
Never delay the ending of a meeting or the beginning of a cocktail hour.
Date: 26 Jun 2006 21:47:12
Message: <44a08e20$1@news.povray.org>
Dr. Egon Kasper wrote:
> High! ;-))
'Lo...     ;-)
I always understood your "High" that way.
> Yadgar
Besides raytracing and computers, I've always been particularly
fascinated by pipe organs -- both classic/church style and theater style
-- and their appropriate music.  (These pipe organ styles are quite
different both in their sound and in their construction.)
      -=- Larry -=-
