POV-Ray : Newsgroups : povray.binaries.images : Invisible #8 (50KB) - "Now with sounded S!" (tm) Server Time
15 Jun 2026 03:01:19 EDT (-0400)
  Invisible #8 (50KB) - "Now with sounded S!" (tm) (Message 1 to 4 of 4)
Subject: Invisible #8 (50KB) - "Now with sounded S!" (tm)
Date: 29 May 2006 16:24:53
Message: <447b5895@news.povray.org>
OK, so I spend 2 hours rounding the S. Here is the result, rendered
without radiosity and with photons. (Changed light source position also.)
What do you think?
By the way, I would like to share with you the scene description of the
letter "S" object:
#declare ObjectS_Top =
merge
   difference
     merge
       difference
         merge
           cylinder {<0*cm, +2*cm, -1*cm>,          <0*cm, +2*cm,
+1*cm>,          3*cm + Radius} // Outside (Middle)
           cylinder {<0*cm, +2*cm, -1*cm - Radius>, <0*cm, +2*cm, +1*cm
+ Radius>, 3*cm}          // Outside (Edges)
           torus {3*cm, Radius  rotate +90*x  translate <0*cm, +2*cm,
-1*cm>} // Front outer rounding
+1*cm>} // Back  outer rounding
         cylinder {<0*cm, +2*cm, -2*cm>, <0*cm, +2*cm, +2*cm>, 1*cm -
Radius} // Center
         cylinder {<0*cm, +2*cm, -1*cm>, <0*cm, +2*cm, -2*cm>, 1*cm} //
Front edge
         cylinder {<0*cm, +2*cm, +1*cm>, <0*cm, +2*cm, +2*cm>, 1*cm} //
Back  edge
       torus {1*cm, Radius  rotate +90*x  translate <0*cm, +2*cm,
-1*cm>} // Front inner rounding
+1*cm>} // Back  inner rounding
     box {<0*cm, -5*cm, -2*cm>, <+5*cm, +2*cm, +2*cm>} // Cutout
   sphere {<+1*cm, +2*cm, -1*cm>, Radius} // Front Left  Corner
   sphere {<+3*cm, +2*cm, -1*cm>, Radius} // Front Right Corner
   sphere {<+1*cm, +2*cm, +1*cm>, Radius} // Back  Left  Corner
   sphere {<+3*cm, +2*cm, +1*cm>, Radius} // Back  Right Corner
   cylinder {<+1*cm, +2*cm, -1*cm>, <+3*cm, +2*cm, -1*cm>, Radius} //
Front Edge
   cylinder {<+1*cm, +2*cm, +1*cm>, <+3*cm, +2*cm, +1*cm>, Radius} //
Back  Edge
   cylinder {<+1*cm, +2*cm, -1*cm>, <+1*cm, +2*cm, +1*cm>, Radius} //
Inside  Edge
   cylinder {<+3*cm, +2*cm, -1*cm>, <+3*cm, +2*cm, +1*cm>, Radius} //
Outside Edge
   box {<+1*cm, +2*cm - Radius, -1*cm>, <+3*cm, +2*cm, +1*cm>}
#declare ObjectS =
merge
   object {ObjectS_Top}
   object {ObjectS_Top   rotate 180*z}
The final object contains 8 spheres, 18 cylinders, 4 boxes and 8 torii.
That's a grand total of 38 objects.
...you can see why I only placed 19 of those by hand, and had POV-Ray
duplicate the rest for me! >_<
Note also the multiple levels of merges and differences necessary to
achieve the correct effect. (The innermost part is nested 6 levels deep!
Eeeps!!)
Download 'invisible20.jpg' (49 KB)
Preview of image 'invisible20.jpg'
Subject: Re: Invisible #8 (50KB) - "Now with sounded S!" (tm)
Date: 29 May 2006 16:44:40
Message: <447B5DED.2000605@hotmail.com>
> What do you think?
I think the next one will be the 'B'
[snip]
> Eeeps!!)
I think there might be a solution with less level, but that you
better stick with the solution that is the most readable, or at
least the one you understand.
Will there also be a final version with the characters removed and
only the reflections and shadows visible?
Date: 29 May 2006 16:59:57
Message: <447b60cd$1@news.povray.org>
>> What do you think?
LOL! Yeah, well... that's the only other difficult letter really. Would
require more fiddling with cylinders and torii...
Well, the 6th level is just merging the two copies of the half together
to make the whole. Whichever way you do the processing, with 38 objects
it's always going to be pretty complicated. :-\
I actually started out trying to make a system that would automatically
round things using CSG. (Sadly, I believe it would be infeasible to
construct such a thing in SDL.) But I never got anywhere near being
finished!
Ooo... neat idea! :-.
Date: 30 May 2006 12:36:59
Message: <447c74ab$1@news.povray.org>
"Orchid XP v2" <voi### [at] devnull> wrote in message
news:447b5895@news.povray.org...
> What do you think?
I definately like the lighting of #7 better. the progression of this work
has cme along really nicely.
