POV-Ray : Newsgroups : povray.binaries.images : Earth: Your Advices are Welcome Server Time
12 Jul 2026 14:47:51 EDT (-0400)
  Earth: Your Advices are Welcome (Message 11 to 14 of 14)
Subject: Re: Earth: Your Advices are Welcome
Date: 29 May 2006 20:25:01
Message: <web.447b904ca626bc344daddc090@news.povray.org>
Sven,
For illuminated lights in the shadowed portion you could use MegaPOV's
'projection pattern'.  You can find samples here:
http://megapov.inetart.net/samples.html
Date: 29 May 2006 22:29:09
Message: <447badf5$1@news.povray.org>
"Mark Birch" <las### [at] hotmailcom> schrieb im Newsbeitrag
news:web.447b904ca626bc344daddc090@news.povray.org...
Hi Mark,
I just wonder if the current version of MegaPov has all the same features as
the Beta 13. I hope, the POVgrammers will include all MegaPov features into
the future regular POV-Rays, as I consider the MegaPov features as quite
interesting, helpful and usable. I truly hope the glorious programmers will
take them.
For now, I prefer to use the Beta 13 in order to beta-test it and to get a
deep feeling of the scene writing. Starting to use now MegaPov, would be
some circumstance. Despite of that I (like nearly everyone here) like the MP
features.
Best greetings and thanks for your hint,
Sven
PS:
Mark you - I still do consider your hint. Let me publish here (again) the
entire scene code so you can see it. Could you please (if you like) alter
that code so it could function as 'projection pattern' within MegaPov? That
way, I could learn some different MegaPov programming and could more make my
mind. Thanks.
NOTE: I am using the great universe sky sphere wonderfully done by Nekar
Xenos
#include "textures.inc"
#include "shapes.inc"
#include "metals.inc"
#include "glass.inc"
#include "woods.inc"
#declare Earth = texture { pigment { image_map { jpeg "E:\Scripts\Eigene
Bilder\Povray Textures\Sphere_Earth_01.jpg" map_type 1 } rotate < 0.0, 0.0,
0.0 > } finish { ambient 0.0 } }
#declare EarthLights = texture { pigment { image_map { png
"E:\Scripts\Eigene Bilder\Povray Textures\Sphere_Earth_Lights_01.png"
map_type 1 } rotate < 0.0, 0.0, 0.0 > } finish { ambient 0.25 } }
#declare EarthClouds = texture { pigment { image_map { png
"E:\Scripts\Eigene Bilder\Povray Textures\Sphere_Earth_Clouds_03.png"
map_type 1 } rotate < 0.0, 0.0, 0.0 > } finish { ambient 0.0 } }
global_settings
 assumed_gamma 2.0
 radiosity {  }  //
camera
 location < 000.0, 0.0, -300.0 >
 look_at < 000.0, 0.0, 0.0 >
light_source
 < 1000.0, 0.0, 250.0 >
 color White *3
#macro StarSubPigment(StarSize, StarFrequency)
 crackle
 form < 1.0, 0.0, 0.0 >
 #local Cutoff=StarSize*StarFrequency;
 color_map
  [ Cutoff rgb 1.0 ]
  [ Cutoff rgb 0.0 ]
 scale 1/StarFrequency
// minsize, maxsize = size range of stars (some stars will always be smaller
due to nature of crackle pattern)
// starfrequency = how many stars
// variationfrequency = how quickly their size changes
#macro StarPigment(MinSize, MaxSize, StarFrequency, VariationFrequency)
 #local NumSizeSteps=8;
 pigment
  pigment_pattern
   bozo
   color_map
    [ 0.0 rgb 0.75 ]
    [ 1.0 rgb 1.00 ]
   scale 1/VariationFrequency
  pigment_map
   #local StepNum=0;
   #while (StepNum<NumSizeSteps)
    #local SizeAmnt=(StepNum+.5)/NumSizeSteps;
    #local PreSize=MinSize+(StepNum/NumSizeSteps)*(MaxSize-MinSize);
    #local PostSize=MinSize+((StepNum+1)/NumSizeSteps)*(MaxSize-MinSize);
    [ SizeAmnt StarSubPigment(PreSize,StarFrequency) ]
    [ SizeAmnt StarSubPigment(PostSize,StarFrequency) ]
    #local StepNum=StepNum+1;
sky_sphere
 StarPigment
  0.000002,  // min star size
  0.000008,  // max star size
  10000,     // star density (higher = more)
  5          // variation frequency (higher = star size changes more over
nearby parts of the sky)
#declare Earth_Surface=sphere
 0.0, 1.0
 texture { Earth }
 texture { EarthLights }
 normal
//  density_file df3 "Sphere_Earth_Bumps_01.df3"
//  interpolate 1
  bump_map
   jpeg "Sphere_Earth_Bumps_01.jpg"
   map_type 1
#declare Earth_Clouds=sphere
 0.0, 1.0005
 texture { EarthClouds }
 normal
//  interpolate 1
  bump_map
   jpeg "Sphere_Earth_Clouds_Bumps_03.jpg"
   map_type 1
#declare Earth_Atmosphere=sphere
 < 0.0, 0.0, 0.0 > 1.0
 pigment
  color rgbt < 0.3, 0.3, 1.0, 1.0 >
 hollow
 interior
  media
   intervals 10
   scattering
    2,
    rgb < 0.3, 0.3, 1.0 >
    extinction 1.0
   }   // 0.75
   density
    spherical
    color_map
     [ 0.000 rgb < 0.0, 0.0, 0.0 > ]
     [ 1.000 rgb < 0.1, 0.1, 0.5 > ]
   samples 1, 10
   confidence 0.9999
   variance 1/1000
   ratio 0.9
 finish { ambient 0.0 diffuse 0.9/**/ }
 scale 1.0075
#declare Earth=union
 object { Earth_Surface }      //
 object { Earth_Clouds }       //
 object { Earth_Atmosphere }   //
 scale 100.0
object { Earth }
Date: 30 May 2006 11:16:51
Message: <447c61e3@news.povray.org>
> take them.
> features.
The only difference between 3.7 and 3.6 (other than the gamma issues
mentioned) should be speed, and that's mostly true for MP systems.  3.6
and MegaPOV both have all the same features and SDL syntax that 3.7
supports.
...Chambers
Date: 30 May 2006 11:52:37
Message: <447c6a45@news.povray.org>
Thanks, Chambers. I am thinking about it.
Sven
