POV-Ray : Newsgroups : povray.binaries.images : Failed Server Time
12 Jul 2026 14:47:52 EDT (-0400)
  Failed (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Failed
Date: 19 May 2006 04:19:26
Message: <446d7f8e$1@news.povray.org>
> Instead of using boxes, use prisms with linear_spline to make the letters.
> This will make it easier to clean up the 'N'.
Hmm... that could work.
> The 'S' could be done with a prism using bezier_spline to get both flat &
> curved surfaces
Nah. I'm already quite happy with the S.
> Beyond that, using photons & dispersion could make quite a difference.
> Radiosity won't have much effect on the 'glass' letters.  Unless you plan to
> put more plain-coloured (not transparent or too reflective) objects in the
> scene it would be quicker to leave it out.
Quicker without radiosity, certinaly. But then the scene is vastly too
dark...
I was thinking about adding some photos.
Subject: Re: Failed
Date: 19 May 2006 04:19:59
Message: <446d7faf$1@news.povray.org>
> Gaaarrhhh! What am I talking about?
> Just use the text{} object in Povray.
> Come to think of it, why aren't you using it?
Well, I was *planning* to bevel all the letters in 3D... but I never got
round to it. :-\
Subject: Re: Failed
Date: 19 May 2006 04:22:47
Message: <446d8057$1@news.povray.org>
> Ever considered using a text object?
Yes, but I *was* going to make all the edges curved. (In fact, I still
hope to. It's just that doing it requires about 12x as many objects...)
> That apart, you may want to intersect your leters with a box. It will
> help removing the extra edges on the "N".
Yeah, I think you might be right there. Either that or use a prism...
> Use a merge instead of an union for the "N" and "V" to remove those
> internal surfaces.
Already using merge.
> Try to change the camera position so that we can see the whole thing.
Technically, you already can. (I haven't moddled the remaining letters yet!)
> As is, radiosity looks like it's a waste of time.
Image is far too dark without it.
> Using photons can have a dramatic effect.
Yeah. As I say, the original plan was to curve all the corners. If I
manage to do that, photons are really gonna be good!
> Add some dispersion.
Sounds slow... LOL!
> Adding a faint coloration to the substance of your leters may help, use
> fade_color color fade_distance 4 to 10 times the thickness of the leters
> to keep it faint and fade_power some value to control it. It's place is
> in the interior{...} block.
Mmm, OK. I'll try that...
Subject: Re: Failed
Date: 19 May 2006 06:53:36
Message: <446da3b0@news.povray.org>
Orchid XP v2 wrote:
> How can I make this look cool?
   Use a fading light (fade_power 2) close to the text.
Make it an area light. Use photons.
   Just those, and it will look a lot better.
Subject: Re: Failed
Date: 19 May 2006 06:57:48
Message: <446da4ac$1@news.povray.org>
"Orchid XP v2" <voi### [at] devnull> wrote in message
news:446d7faf$1@news.povray.org...
> round to it. :-\
Hmm, doesn't Elefont bevel text for you?
http://www.armanisoft.ch/webdesign/elefont/Elefont.html
- How
Subject: Re: Failed
Date: 19 May 2006 11:45:55
Message: <446de833$1@news.povray.org>
Orchid XP v2 nous apporta ses lumieres en ce 19/05/2006 04:22:
You can simply increase the light value. If rgb 1 is to low, there is nothing that
prevent you from
using a larger value. If you have some media above the scene, try using extinction
with a value less
than 1.
I drive way too fast to worry about cholesterol.
Subject: Re: Failed
Date: 20 May 2006 05:20:40
Message: <446edf68@news.povray.org>
>> round to it. :-\
> - How
Fine if you're using windows :-)
Someone did post a macro a while back that would bevel any object,
I think it was done with a merge of many copies translated by a
set of equal length vectors in various (all) directions. The bigger
your set of vectors, the smoother the bevelling. Something like
that anyway.
Bill Hails
http://billhails.net/
Subject: Re: Failed
Date: 21 May 2006 23:25:00
Message: <web.44712da5bbca8b2385de7b680@news.povray.org>
Photons.  Lots of photons.
Dispersion.  Use a value less than 1.0 for a physically incorrect and
totally cool effect.
> (Text = CSG. The S in particular was very hard; it involves 4 cylinders
> and 2 cubes. (?!) Lighting is radiosity (bluish) + 1 light sournce
> ("sun", yellowish). Hmm...)
The macro Beveled_Text() in shapes.inc is slow and leaves some distracting
artifacts, but it's available until you program (or borrow) something
better.
Subject: Re: Failed
Date: 22 May 2006 07:48:47
Message: <4471a51f$1@news.povray.org>
"Bill Hails" <me### [at] billhailsnet> wrote in message
news:446edf68@news.povray.org...
Whoops, sorry!
> that anyway.
Ah, hmm.  I think shapes.inc has a 'Bevelled_Text' macro.  Is this what
you're talking about?
- How
Subject: Re: Failed
Date: 22 May 2006 07:50:15
Message: <4471a577$1@news.povray.org>
"How Camp" <hac### [at] gmailcom> wrote in message
news:4471a51f$1@news.povray.org...
Oh, never mind me.  Cousin Ricky already mentioned this.  serves me right
for not reading all the new posts first...
- How
