POV-Ray : Newsgroups : povray.binaries.images : joining the greeble-madness :) Server Time
12 Jul 2026 19:46:26 EDT (-0400)
  joining the greeble-madness :) (Message 8 to 17 of 47)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: joining the greeble-madness :)
Date: 15 May 2006 05:06:33
Message: <44684499$1@news.povray.org>
"Zeger Knaepen" <zeg### [at] povplacecom> schreef in bericht
news:446764f4@news.povray.org...
> I just *had* to try to make my own greeble-macro :)
This is the kind of greeble I like very much: not too intrusive, but subtly
guiding the eyes over the surface. Good work Zeger! Could be used
architecturally, on a curtain wall.
Date: 15 May 2006 06:29:35
Message: <4468580f$1@news.povray.org>
You will be assimilated! Resistance is futile!
Subject: Re: Feedback
Date: 15 May 2006 07:04:59
Message: <0SzOrBAZ1FaEFwMd@econym.demon.co.uk>
Wasn't it Zeger Knaepen who wrote:
>I was just trying to create a city-macro based on this greeble-macro :)
I went the other way. I based my Greeble code on the macro that I used
to generate this city:
http://www.econym.demon.co.uk/pictures/cityscape.jpg
Mike Williams
Gentleman of Leisure
Date: 15 May 2006 08:54:49
Message: <44687a19@news.povray.org>
subtly
thank you! :)
cu!
Date: 15 May 2006 12:34:04
Message: <4468ad7c@news.povray.org>
Be careful, Borg! We otherwise will get support from our captain who will
come back to us from the near future! With nano viruses which will destroy
you Borg from within, as soon as you assimilate!
:-)   ;-)   :-D
Sven
"Warp" <war### [at] tagpovrayorg> schrieb im Newsbeitrag
news:4468580f$1@news.povray.org...
Subject: Question
Date: 15 May 2006 14:44:43
Message: <4468cc1b$1@news.povray.org>
Hi!
Will it be able to use different textures for vertical and for surface
areas? That would allow the usage of windows for all side areas of your very
useful and breathtaking macro! Best would be, one texture for front and
back, one for left and right, and one for surface (and bottom).
Respect,
Sven
Subject: Re: Question
Date: 15 May 2006 15:28:22
Message: <4468d656$1@news.povray.org>
"Sven Littkowski" <sve### [at] jamaica-focuscom> wrote in message
news:4468cc1b$1@news.povray.org...
> Hi!
your very
and
as it is now, the texture has nothing to do with the macro, the macro
only handles the geometry, so yes, you can define different textures for
any part :)
btw, has anyone got any idea on how to subdivide a triangle to make the
"greeble-cells" ? :-/
cu!
Date: 16 May 2006 00:29:57
Message: <44695545$1@news.povray.org>
> here's a first result, rendertime: 3'48" on a Sempron 2400+ with 768MB RAM,
> running Windows XP SP2
> comments are more than welcome !
> cu!
This one's actually quite good.  A nice metallic texture, instead of
polished marble.
John
Date: 16 May 2006 00:44:48
Message: <446958c0$1@news.povray.org>
>> RAM, running Windows XP SP2
>> cu!
> I think it is a bit of a stylistic departure from the usual but the
> result is attractive, even gorgeous, and useful I think.
> The obvious problem with this and the other attempts at an automated
> generator is the lack of averarching elements that would span "cells"
> Simply varying the scale of the cells does not get that effect.
One way is to give cells borders, and require that two cell types cannot
meet unless their typing along that border matches.  Then you can
sprinkle some stand-alone cells in with larger pieces, and even
irregular pieces.  The tricky part is to make sure that the surface can
be completely tiled in this way.
Or you can have multiple layers of greebling, in which the higher level
has tubes and stuff that traverse the lower-level tiles.
John
Date: 16 May 2006 00:47:26
Message: <4469595e$1@news.povray.org>
Depends on the proportions of the triangle.  An equilateral is best
subdivided into smaller equilaterals.  A triangle with the golden ratio
between its sides is best divided with a Penrose tiling.
John
