POV-Ray : Newsgroups : povray.binaries.images : SF: Preview 03: Imperial Carrier Server Time
2 Aug 2026 06:42:08 EDT (-0400)
  SF: Preview 03: Imperial Carrier (Message 11 to 20 of 43)
Subject: Re: Preview 03: Imperial Carrier
Date: 29 Apr 2006 15:51:01
Message: <4453c3a5$1@news.povray.org>
Hi Marc,
the very first of these previews was done with the full version of POV-Ray:
v 3.6, but all other previews (02 - 07) were done with the bbeta version of
the new POV-Ray, version 3.7.0 Beta 12a.
There are none of these "spot lights" remaining when using the beta version.
On the other hand, they say that radiosity and other features are not yet
fully completed which might be the only reason why the spot lights have
disappeared.
Greetings,
Sven
"Marc Jacquier" <jac### [at] wanadoofr> schrieb im Newsbeitrag
news:4453a503$1@news.povray.org...
> news:445295e2@news.povray.org...
>>Here: Bird's view on the middle front section of the imperial carrier
> SENECA.
> That's impressively Imperial indeed :-)
> The little reserve I can have is that you should vary slightly the color
> en
> intensity of the bay lights.
> Regarding those bays, I thonk anti-aliasing has problems with hi rgb value
> pixels, which version of povray are you using?
> Marc
Subject: Re: Preview 07: Imperial Carrier
Date: 29 Apr 2006 18:55:00
Message: <web.4453ee0adda5ea50dad8fec00@news.povray.org>
Hi Sven
I'm viewing this newsgroup with a web browser (i tried FireFox and IE6). i
see all the images on this page. The one of Larry above as well. Usually i
see:
  Download '<filename>.jpg' (<size> KB)
  Preview of image '<filename>.jpg'
  [image]
In your case i just see:
  Download 'iso-8859-1' (1 KB)
(one has 4KB but that's it)
When i download this files they contain html code for example:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=Content-Type content="text/html;
charset=iso-8859-1">
<META content="MSHTML 6.00.2900.2873" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=#ede2cd background="">
<DIV><FONT face=Arial color=#000000 size=2>Here: Rear view of the
middle front
section of the imperial carrier SENECA containing the panoramic quarters
and a
large sensor bay. There are still many details to come, such as small
surface
structures, antennas and others.</FONT></DIV>
<DIV><IMG alt="" hspace=0
src="cid:054a01c66b18$9c083ad0$16b2a8c0@SVEN"
align=baseline border=0></DIV></BODY></HTML>
The src links in the image tags (if they are links at all) don't work.
Has anyone ever experienced similar problems? I have no idea what goes wrong
here.
Regards Roman
"Sven Littkowski" <sve### [at] jamaica-focuscom> wrote:
> Hi Roman,
> hmmm, sounds unusual. Let me ask you: do you see here any other image file?
> Nearly each topic here has an image file. If you cannot see any graphics
> here, you might check your settings. Do you use an e-mail program such as
> Eudora or Outlook (Express)? Or do you use a web browser?
> Later,
> Sven
Date: 29 Apr 2006 19:06:40
Message: <4453f180@news.povray.org>
Hello Roman,
That is a problem I am not familiar with, I am very sorry.  I see all the
contents by using my e-mail program (Outlook Express) which i simply
configured to be signed up for the POV-Ray newsgroups.
Sven
"Roman Reiner" <lim### [at] gmxde> schrieb im Newsbeitrag
news:web.4453ee0adda5ea50dad8fec00@news.povray.org...
> Hi Sven
> see:
>  [image]
> <HTML><HEAD>
> <STYLE></STYLE>
> </HEAD>
> middle front
> and a
> surface
> wrong
> here.
> Regards Roman
>> Hi Roman,
>> file?
>> Later,
>> Sven
Date: 29 Apr 2006 21:21:01
Message: <445410fd$1@news.povray.org>
Sven Littkowski wrote:
> Hello Roman,
> Sven
The problem is that there is a difference between embedding and
attaching an image.  You are embedding them, which makes them an
integral part of your HTML messages.  You should attach them instead,
because apparently some software has problems with embedded images.
Outlook Express does allow using either method.
I don't remember the details because I switched from OE to Thunderbird
some time ago.  Besides, right at the moment I'm using Linux so can't
check it out -- but the option is there.
It would probably cause fewer problems if you would switch to straight
text instead of HTML.  It seems that HTML is rarely used in newsgroups
-- at least in the ones I'm familiar with.  That choice can be selected
in OE as well.
One other minor quibble...  All your images have been posted with the
same name "SpaceCarrier", so if anyone saves your images (as I do) they
all have to be renamed to do so.    :-)     (Use SpaceCarrier-1,
SpaceCarrier-2, ..., etc.)
      -=- Larry -=-
Subject: Preview 08: Imperial Carrier
Date: 29 Apr 2006 23:19:44
Message: <44542cd0@news.povray.org>
Here: Front view of the imperial carrier SENECA.I have started to add
neccessary details such as superstructures to the side bays, but much
more to come!
Date: 29 Apr 2006 23:20:28
Message: <44542cfc@news.povray.org>
Larry,
thanks for your answer. I am going to change beginning from the upcoming
"Preview 09" the format from HTML to Text.
Greetings,
Sven
"Larry Hudson" <org### [at] yahoocom> schrieb im Newsbeitrag
news:445410fd$1@news.povray.org...
>> Hello Roman,
>> Sven
> The problem is that there is a difference between embedding and attaching
> an image.  You are embedding them, which makes them an integral part of
> your HTML messages.  You should attach them instead, because apparently
> some software has problems with embedded images. Outlook Express does
> text instead of HTML.  It seems that HTML is rarely used in newsgroups --
> at least in the ones I'm familiar with.  That choice can be selected in OE
> as well.
> One other minor quibble...  All your images have been posted with the same
> name "SpaceCarrier", so if anyone saves your images (as I do) they all
>      -=- Larry -=-
Date: 30 Apr 2006 02:49:49
Message: <afn85258h7klnuekg6h88tqlu52q4o35tl@4ax.com>
On Sat, 29 Apr 2006 18:21:00 -0700, Larry Hudson <org### [at] yahoocom>
>> Hello Roman,
>> Sven
>in OE as well.
>      -=- Larry -=-
Just for info.  I use Agent 3 and have no problems seeing these
images.
John
Date: 30 Apr 2006 05:35:00
Message: <web.445483bfdda5ea50b0fabcce0@news.povray.org>
"Roman Reiner" <lim### [at] gmxde> wrote:
> Hi Sven
> I'm viewing this newsgroup with a web browser (i tried FireFox and IE6)...
> When i download this files they contain html code...
> here.
> Regards Roman
I'm having the same problem, using Netscape Communicator as my browser.  But
I think Larry Hudson's suggestion to Sven will solve it.
Looking forward to seeing the images, Sven!
Ken W.
Subject: Preview 08 (attached): Imperial Carrier
Date: 30 Apr 2006 07:11:06
Message: <44549b4a@news.povray.org>
neccessary details such as superstructures to the side bays, but much more
to come!
Download 'SpaceCarrier.jpg' (235 KB)
Preview of image 'SpaceCarrier.jpg'
Subject: Re: Preview 08 (attached): Imperial Carrier
Date: 30 Apr 2006 12:00:45
Message: <4454df2d$1@news.povray.org>
High!
> to come!
Cool Earth-like desert moon, that 68 Cyg XIV-7! Did you make it also
with PoV-Ray?
And, yes, I really would like to know how long (in kilometers) the
SENECA carrier is altogether...
See you in Khyberspace!
Yadgar
Now playing: Ciel Ouvert (Yello)
