POV-Ray : Newsgroups : povray.binaries.images : Tango (renders + photos) Server Time
15 Nov 2024 02:25:11 EST (-0500)
  Tango (renders + photos) (Message 1 to 8 of 8)
Subject: Tango (renders + photos)
Date: 9 Apr 2006 08:54:53
Message: <4439041d@news.povray.org>
First off, sorry about the file size - these images didn't compress very well!
Those who have been keeping up with the 3.7 betas may have noticed "tango.pov"
included with the recent release as a test of the BSP improvements.
Tango.pov is actually a cut down version of a design (called, funnily enough,
Tango) which I was working on for a kiteboard manufacturer, and the final
versions of the full scenes were rendered in the past week, with the first board
being finished on Friday.
Attached are scaled down versions of the top and bottom sheet renders, and also
some (pretty bad) photos of the first board.  The white balance in the photos
isn't right and the high gloss (on the top, the bottom is matte) made it hard to
take a good shot, but you get the idea :)
Lance.
thezone - thezone.firewave.com.au
Download 'tango_renders.jpg' (364 KB) Download 'tango.jpg' (305 KB)
Preview of image 'tango_renders.jpg'
Preview of image 'tango.jpg'
Subject: Re: Tango (renders + photos)
Date: 9 Apr 2006 12:50:03
Message: <e1bds3$snc$1@chho.imagico.de>
Very nice.  But don't you think the purple 'thing' in the gray version
would look better with more interesting shading?  It looks somewhat flat
IMO.
http://www.imagico.de/ (Last updated 14 Mar. 2006)
Date: 9 Apr 2006 20:36:54
Message: <4439a8a6$1@news.povray.org>
news:e1bds3$snc$1@chho.imagico.de...
> don't you think the purple 'thing' in the gray version would look better
It kinda fits, though. Get it? "flat"?  ;)
I really do think it goes with the overall design. The photo shows it looks
good.
I wouldn't have guessed the tango.pov was being applied to a kiteboard. I
rendered it immediately after getting the files, comparing it in 3.6 where
it is very slow going. Unfortunately, I wasn't finding anything else
rendering so much faster in the beta by using +b2 so I haven't been checking
into that again yet.
Date: 10 Apr 2006 04:15:04
Message: <e1d42t$iu4$1@chho.imagico.de>
Bob H wrote:
> "Christoph Hormann" <chr### [at] gmxde> wrote in message
> good.
Yes, but i still think it *might* look better with a different shading.
  A contrasting motive can look very good too.
Date: 11 Apr 2006 03:35:01
Message: <web.443b5b6110abaad6acc8f35f0@news.povray.org>
Nice work!
I hate to be so *naive* about this, but...how did you transfer your final
images to the boards?  I'd like to try something like this on one of my
guitars.
Ken
Date: 22 Apr 2006 08:07:34
Message: <444a1c86$1@news.povray.org>
also
photos
hard to
> IMO.
Actually it's supposed to look flat, because their logo is flat-shaded :)
Lance.
Date: 22 Apr 2006 08:27:15
Message: <444a2123$1@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> wrote in message
news:web.443b5b6110abaad6acc8f35f0@news.povray.org...
also
photos
hard to
> Nice work!
> guitars.
Hey Ken - the process uses dye sublimation.  It's the same principle as other
dye sublimation applications (e.g. those used to transfer colour photographs to
various products) only on a much larger scale.  The design is printed using a
set of sublimation dyes/inks on to a "carrier" sheet.  This sheet is attached to
the final sheet of plastic (which is a type of polyester called "PBT",
poly-butylene terephthalate), and then both sheets are pressed together under
high pressure in a heat press.  The heat causes the sublimation inks to vaporise
and the vapor is then forced into the plastic, binding to the polyester.  The
sublimated PBT sheets are then attached to the board's core using resin, and
vacuum bagged to bind everything together.
Without a lot of expense this couldn't be done as a "one off "at home, but there
are probably some other solutions that would work if you wanted to put graphics
on a guitar.  It would be very difficult to sublimate directly on to a finished
object however (and a limitation of dye sub is that the surface receiving the
ink must be synthetic).
Lance.
Date: 22 Apr 2006 11:34:27
Message: <444a4d03@news.povray.org>
news:444a2123$1@news.povray.org...
there
graphics
finished
the
I didn't try but what about a iron-on transfer sheet (as for the t-shirts)
before applying the finish on the guitar wood?
Could be tested on a sanded piece of wood before.
Marc
