POV-Ray : Newsgroups : povray.binaries.images : My turn for RSOCP Server Time
11 Sep 2025 15:40:46 EDT (-0400)
  My turn for RSOCP (Message 1 to 2 of 2)
Subject: My turn for RSOCP
Date: 5 Apr 2006 04:37:43
Message: <443381d7@news.povray.org>
Originally, I had created what I called "naked primitives" by using
cylinder elements in blobs to create sort of a wire frame of a cube,
pyramid, and a sphere, with some radiosity for effect.  The blobbing
created a bit more mass at the vertices, which was the effect I was
going for.  Then, I noticed that the sphere didn't much resemble a
sphere, but rather this odd shape that looked kind of cool.
Then I decided to take the sphere-like shape on its own, make an array
of them, make every other one reflective, put it over a checkered plane,
and add some focal blur.  And this is the result.
I don't like it though...the focal blur isn't quite right.  The settings
I used were 200 samples, confidence 0.99, variance 1/100000, aperture 4,
with the focal point in the very center of the sphere.  The problem is
that the focal blur still looks grainy, and there are couple black
pixels.  I'm assuming the black pixels are from the max_trace_level
being reached.  I'm using the default.
What also gets me is some of the edges in the checker pattern are abrupt
in the focal blur.  What would cause that?
Download 'rsocp_fp.png' (251 KB)
Preview of image 'rsocp_fp.png'
Subject: Re: My turn for RSOCP
Date: 7 Apr 2006 19:41:36
Message: <4436f8b0$1@news.povray.org>
DJ Wiza nous apporta ses lumieres en ce 05/04/2006 04:33:
You may try with a lower aperture value, like in the 1~2 range. Smaler aperture should
make the
grainyness less apparent, or you can increase the sample number, along with the render
time.
You probably need to increase Max_trace_level, and maybe use a larger adc_bailout.
For the black leaking on the white, you may try using Gray05, Gray10 or Gray15 for the
dark squares.
Don't know if it will help.
Coming soon: Windows for Nintendo!
