POV-Ray : Newsgroups : povray.binaries.images : cobblestone Server Time
15 Nov 2024 04:22:41 EST (-0500)
  cobblestone (Message 1 to 10 of 12)
Subject: cobblestone
Date: 6 Mar 2006 06:53:35
Message: <440c22bf@news.povray.org>
first test of a cobblestone street
stones are isofunctions (f_superellipsoid + f_rigged_mf) placed on a heightfield
generated based on a pigment.
the sand between the stone still needs work (texture, debris, grass)
light is a simple point light (it's just a geometry+texture test)
any suggestions ????
... dave
Download 'cobblestone_test.jpg' (101 KB)
Preview of image 'cobblestone_test.jpg'
Subject: Re: cobblestone
Date: 6 Mar 2006 07:13:45
Message: <440c2779@news.povray.org>
SORRY ...
posted the wrong image.
THIS is the on with isofunctions (f_superellipsoid + f_rigged_mf) the former
contains only superellipsoids.
Hope the difference is noteable ...
...dave
Download 'cobblestone_test2.jpg' (106 KB)
Preview of image 'cobblestone_test2.jpg'
Date: 6 Mar 2006 08:25:01
Message: <web.440c378d1e090c9e578f59590@news.povray.org>
Hello.
 Yes. The second one looks "nibbled by years" :)
 I like sand, it looks very real. But I think, the stones colour and
grainnes should vary slightly.
 Sincerely Yours,
 Alex  Kluchikov.
Date: 6 Mar 2006 10:48:22
Message: <440c59c6@news.povray.org>
"Alex Kluchikov" <klk### [at] ukrnet> wrote in message
news:web.440c378d1e090c9e578f59590@news.povray.org...
> Hello.
former
>  Sincerely Yours,
>  Alex  Kluchikov.
The texture is interesting, but perhaps more castlewall, or decorative
paver.
Real cobblestones are somewhat rounded and used to bear traffic.
Originally they were derived from local river stone.
e.g.
http://www.pmb.ox.ac.uk/images/tour/TourOutside1.jpg
They age/wear to become smoothe and shiny. See e.g.
http://www.miksang.net/galleries/gal_waynewilliams/pages/Dublin-Cobble-Stone.html
For a description of distinctions between cobbled other forms of flint stone
paving see
http://www.jbsv.co.uk/norfolkflint.htm
DLM
Date: 6 Mar 2006 13:28:32
Message: <440c7f50$1@news.povray.org>
> ... dave
look my last irtc participation at:
http://www.irtc.org/ftp/pub/stills/2005-06-30/untitled.jpg
my isosurfaces were placed using trace() over an height_field i made with
photoshop
I hope that perhaps it serves as inspiration or aid you.
light_source{0,1}#macro C(r,p)cylinder{x*-2,x*2,.9 pigment { rgb
p} /* B Gimeno estoeslarealidad */ rotate p*90 } #end difference
{box {-1,1} C(z /* http://usuarios.lycos.es/game2413 */,x)C(x,y)
C(z,z) pigment{rgb 2} rotate 45 translate z*4} // www.povray.org
Date: 6 Mar 2006 14:59:39
Message: <440c94ab$1@news.povray.org>
Both images are impressive.
It looks like it could do with more AA (or just a bigger image size),
but basically... it looks pretty good!
Date: 7 Mar 2006 00:35:41
Message: <440d1bac@news.povray.org>
David El Tom spake:
> heightfield generated based on a pigment.
> ... dave
The stones look a bit grainy - how about turning up AA (as another poster
suggested) and maybe fiddling with the texture to remove the black bits?
Stefan Viljoen
Polar Design Solutions
Date: 7 Mar 2006 01:10:00
Message: <web.440d238a1e090c9eb3ed5a4f0@news.povray.org>
> SORRY ...
> ...dave
I think the overall shape of the stones is great, but the finishing could be
a bit better. I think that the stones would be more polished after being
used a bit. Making them a bit smoother and shinier should do the trick.
Date: 7 Mar 2006 02:40:47
Message: <440d38ff$1@news.povray.org>
> paver.
To be honest, the texture is lend from stones1.inc (pigment in T_Grnt17a with
slight modifications).
The original render had far more less dynamic in colors. I raised it with before
posting it in order to see more details.
> e.g.
> paving see
wow, thanks for the references. Gives me good point where to start, even when
the Dublin reference seems to be basalt (nearly homogeneous black) instead of
granite.
It happend that I saw some worker's building a cobblestone sideway. Of cause
they used freshly broken stones. This was probably the main influence I had in
mind  as I searched for the right look.
I have to play with the parameters of the rigged_mf function to get this
polished look on top and a little more grainish look inside the ditches.
I'm not sure if a supperellispoid is the appropiate base shape for a "pillowed"
cube. Maybe I've to blob a sphere with superellispoid or so.
... dave
Date: 7 Mar 2006 02:42:44
Message: <440d3974@news.povray.org>
yepp, you're right. Finish still needs work (especialy if it comes to be a
slightly wet look)
... dave
