POV-Ray : Newsgroups : povray.binaries.images : Down the Drain (WIP Update #1) Server Time
2 Aug 2026 10:46:28 EDT (-0400)
  Down the Drain (WIP Update #1) (Message 21 to 26 of 26)
Subject: Re: Down the Drain (WIP Update #2)
Date: 28 Feb 2006 08:20:00
Message: <web.44044d66deabc3a2210581b00@news.povray.org>
Tim,it will be nice...
Regards.
Hasan
Date: 28 Feb 2006 10:17:23
Message: <44046983@news.povray.org>
> 1) Raise the ambient lighting a little. I think the image is a little
dark.
That's often a problem with what monitor you're watching it on. Personally,
I like it like it is, but I might try to make it a tad brighter. I'm not
sure if that creates a wash-out on the already bright parts, but I'll
certainly look into it.
> 2) The taps only have two knobs... I've never seen taps like this... Taps
of
> this style seem to always have four knobs.  I think this would also round
> out this area of the image.
Yeah, should give that a try. I always like doing things slightly off what
you're expecting, but you're right, maybe it would balance that section of
the image.
> 3) Where is the plug? In sinks like this, the plug is usually chained to a
> attachment just above the overflow... This would give you the opportunity
> for some real nice chain.
Actually, I do have a plug fitting the drain. But then I decided to leave it
away, as if to say that there's no way to keep that drop going down the
drain. Might have to create the chain in any case, to make the absence of
the plug more obvious.
> 4) I think there is a little too much focal blur in this... the soap is a
> bit too blurred.
It's a difficult choice. I kinda like how the tab gets blurred, but then the
soap gets blurred to much. I surely will toy around with those settings,
they were the latest addition and haven't been tweaked as much as other
stuff.
Thanks for the feedback!
Tim
aka "Tim Nikias v2.0"
Date: 28 Feb 2006 10:17:39
Message: <44046993@news.povray.org>
Thank you!
Tim
Subject: Re: Down the Drain (WIP Update #1)
Date: 28 Feb 2006 11:25:00
Message: <web.440476f6f586906143a5e2560@news.povray.org>
> Bob Hughes wrote:
> > Trying to remember about twisting directions... I know it is commonly
> > thought that the northern and southern hemispheres of the planet have their
> > own direction but it's apparently just a random thing instead. I forget.
> > Something about no relation to weather that is influenced by earth rotation
> > instead.
>    I wondered how long it would take for someone to bring this up.
>    The rotation of the water has nothing to do with the rotation of
> the Earth or anything like that. It's purely a question of geometry
> of the sink, the pipes, initial water movement, etc.
Everything you ever knew about spinning water that ain't so:
     http://www.ems.psu.edu/~fraser/Bad/BadCoriolis.html
A similar fallacy leads some New-Agers to believe that the tides affect our
body fluid.  It's sometimes scary all the things we take for granted that
are totally bogus. Here's a bunch:
     http://tag.povray.org/povQandT/misconceptions.html
Date: 28 Feb 2006 12:55:07
Message: <44048e7b$1@news.povray.org>
Hi Tim,
It's looking excellent.
In terms of dramatic effect, have you considered placing the heart deep in
the vortex, just on the brink of going down the plug-hole? The drop forming
on the tap looks like it leaves a glimmer of hope that one could salvage the
situation by plugging the hole. You could even have a faint red spiral
coming back off the heart and maybe a dagger inside the water drop ready to
fall and slice the heart into pieces before it finally drops out of sight.
Hope these ideas raise your spirits ;o)
All the best,
Chris B.
Date: 28 Feb 2006 17:17:37
Message: <4404cc01@news.povray.org>
Thank you very much!
forming
the
to
Initially, I wanted to place something near or even in the vortex. As for
the plug, Rarius mentioned that it seems missing. I'm currently thinking
about adding part of a chain to the faucet, which should show more clearly
that the plug is in fact missing, there is no hope for rescue by plugging
the vortex.
As for the dagger - I like and want an image which, overall, gives the
impression of a nice, clean and bright environment, and a friend of mine
today told me as much. The heart is the tiny drop that'll tell the story
behind the title "Down the drain".
Well, the image and the work on it is more of a distraction. I'm too much of
a thinker.
Tim
