POV-Ray : Newsgroups : povray.binaries.images : Down the Drain (WIP Update #1) Server Time
2 Aug 2026 09:23:19 EDT (-0400)
  Down the Drain (WIP Update #1) (Message 17 to 26 of 26)
Subject: Re: Down the Drain (WIP Update #1)
Date: 27 Feb 2006 17:22:29
Message: <44037ba5$1@news.povray.org>
"Tim Nikias" <JUSTTHELOWERCASE:timISNOTnikias(at)gmx.netWARE> wrote in
message news:4403297a@news.povray.org...
>> The water should form a spiralling whirlpool as it goes down the drain.
> Here's an attempt at that. Quite honestly, the refraction and viewing
> angle
> obscure the view on the mesh so much that I don't think the extra workload
> is needed. I've written a small script to generate an array of points
> which
> aren't spread evenly like in a heightfield, but are closer together at the
> center where the vortex is, and further apart at the edges, where there's
> less detail. I then twisted the vortex's axis a little with it being
> displaced, so the vortex doesn't go straight down, but swirl towards the
> drain.
> Might be that I've got to add another lightsource for highlights to show
> the
> displacement on the vortex, but if that doesn't do much, I think I'll go
> stick with the simpler heightfield. Some of the caustics
> (non-photon-mapped)
> are more pleasing to me visually in the old version.
Without reality-checking here it looks much like I'd expect it to. I don't
think there's ever much visibilty for something like this. Might be larger
than usual for the depth, if anything. Seems to me that the vortex is
typically very thin, hardly breaking the surface, until the surface gets
near the drain. So maybe this sink would be a little scary for people with a
phobia about such things (sister's daughter did).  :)
Trying to remember about twisting directions... I know it is commonly
thought that the northern and southern hemispheres of the planet have their
own direction but it's apparently just a random thing instead. I forget.
Something about no relation to weather that is influenced by earth rotation
instead.
Bob H
Date: 28 Feb 2006 01:17:34
Message: <4403eafe$1@news.povray.org>
> instead.
   I wondered how long it would take for someone to bring this up.
   The rotation of the water has nothing to do with the rotation of
the Earth or anything like that. It's purely a question of geometry
of the sink, the pipes, initial water movement, etc.
Subject: Down the Drain (WIP Update #2)
Date: 28 Feb 2006 03:31:24
Message: <44040a5c@news.povray.org>
So, here's a quick (heh, 7hours and not done yet ain't quick!) test with
focal blur.
The render wasn't complete yet, so the lower 120 lines or so are basically
just a blurred version of the standard antia-aliased render.
Anyways, I think the focal blur adds a lot and I'll keep it for the final
render. Now I'm getting to the spot where I'm unsure if I want to add
anything and I *really* should give it a rest for a day or two, and take
some more comments and suggestions. A good friend of mine wants to say
something as well, but as she's not here at the moment, I have to wait for
her as well.
The tiles behind the sink required a little change in the spotlight's
point_at, which in effect caused a little more lighting variance in the
lower left corner. I'm thinking about pushing it a little further (either
via texture or via lighting changes), but we'll see. As it is now I think
I'll be experimenting with some "less shiny-new-clean" textures to check if
it enhances the mood I'd like to create. I also want to try and add some
waterdrops onto the surface of the faucet near its base and on the sink.
And for those wondering, the waterdrop is now modelled with Silo like
everything else in the image besides the heart, the water in the sink, and
the foam on the soap.
Tim
aka "Tim Nikias v2.0"
Download 'DtD_wip6.jpg' (115 KB)
Preview of image 'DtD_wip6.jpg'
Subject: Re: Down the Drain (WIP Update #2)
Date: 28 Feb 2006 05:14:36
Message: <4404228c$1@news.povray.org>
I can only congratulate for a STUNNING image... I do have a couple of
suggestions though:
1) Raise the ambient lighting a little. I think the image is a little dark.
2) The taps only have two knobs... I've never seen taps like this... Taps of
this style seem to always have four knobs.  I think this would also round
out this area of the image.
3) Where is the plug? In sinks like this, the plug is usually chained to a
attachment just above the overflow... This would give you the opportunity
for some real nice chain.
4) I think there is a little too much focal blur in this... the soap is a
bit too blurred.
I agree with you about using some dirty textures rather than the too shiny
ones...
Even as a WIP this image is bloody impressive... you have more patience than
I do!
Rarius
Date: 28 Feb 2006 08:20:00
Message: <web.44044d66deabc3a2210581b00@news.povray.org>
Tim,it will be nice...
Regards.
Hasan
Date: 28 Feb 2006 10:17:23
Message: <44046983@news.povray.org>
dark.
That's often a problem with what monitor you're watching it on. Personally,
I like it like it is, but I might try to make it a tad brighter. I'm not
sure if that creates a wash-out on the already bright parts, but I'll
certainly look into it.
of
Yeah, should give that a try. I always like doing things slightly off what
you're expecting, but you're right, maybe it would balance that section of
the image.
Actually, I do have a plug fitting the drain. But then I decided to leave it
away, as if to say that there's no way to keep that drop going down the
drain. Might have to create the chain in any case, to make the absence of
the plug more obvious.
> bit too blurred.
It's a difficult choice. I kinda like how the tab gets blurred, but then the
soap gets blurred to much. I surely will toy around with those settings,
they were the latest addition and haven't been tweaked as much as other
stuff.
Thanks for the feedback!
Tim
Date: 28 Feb 2006 10:17:39
Message: <44046993@news.povray.org>
Thank you!
Tim
Date: 28 Feb 2006 11:25:00
Message: <web.440476f6f586906143a5e2560@news.povray.org>
> > instead.
Everything you ever knew about spinning water that ain't so:
     http://www.ems.psu.edu/~fraser/Bad/BadCoriolis.html
A similar fallacy leads some New-Agers to believe that the tides affect our
body fluid.  It's sometimes scary all the things we take for granted that
are totally bogus. Here's a bunch:
     http://tag.povray.org/povQandT/misconceptions.html
Date: 28 Feb 2006 12:55:07
Message: <44048e7b$1@news.povray.org>
Hi Tim,
It's looking excellent.
In terms of dramatic effect, have you considered placing the heart deep in
the vortex, just on the brink of going down the plug-hole? The drop forming
on the tap looks like it leaves a glimmer of hope that one could salvage the
situation by plugging the hole. You could even have a faint red spiral
coming back off the heart and maybe a dagger inside the water drop ready to
fall and slice the heart into pieces before it finally drops out of sight.
Hope these ideas raise your spirits ;o)
All the best,
Chris B.
Date: 28 Feb 2006 17:17:37
Message: <4404cc01@news.povray.org>
Thank you very much!
forming
the
to
Initially, I wanted to place something near or even in the vortex. As for
the plug, Rarius mentioned that it seems missing. I'm currently thinking
about adding part of a chain to the faucet, which should show more clearly
that the plug is in fact missing, there is no hope for rescue by plugging
the vortex.
As for the dagger - I like and want an image which, overall, gives the
impression of a nice, clean and bright environment, and a friend of mine
today told me as much. The heart is the tiny drop that'll tell the story
behind the title "Down the drain".
Well, the image and the work on it is more of a distraction. I'm too much of
a thinker.
Tim
